Removal of Dura Ace FH-7400 freehub
Old 02-04-18, 02:45 PM
johnlink
Bikes: 1988 Centurion Ironman
Quoted: 107 Post(s)
Liked 7 Times in 6 Posts
What tool is needed to remove a Dura Ace FH-7400 freehub? Does it fit into the four notches (two of which are visible in the picture) or into the eight notches further into the hub?
File Type: jpg
johnlink is offline
Old 02-04-18, 03:14 PM
johnlink
Quoted: 107 Post(s)
I learned that what's required is the TL-FH10 removal tool. I just bought a brand new one, in the bag, for $74.
Who says time travel is not possible?
johnlink is offline
Likes For johnlink:
Old 02-04-18, 03:23 PM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1088 Post(s)
Liked 484 Times in 373 Posts
I was surprised Bicycle Research didn't have something.
For those of more meager means, this may also help, although it's not the same tool as the one above? Seems this goes into the upper two/four notches while the tool pictured goes into the lower notches:
https://www.ebay.com/itm/302099316296
Then there's always RJ the bike guy's innovation...
francophile is offline
Old 02-04-18, 03:29 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2095 Post(s)
Liked 955 Times in 700 Posts
My packaging is not as pretty, but it's good to know what they can go for.
thumpism is offline
Likes For thumpism:
Old 02-04-18, 03:32 PM
johnlink
Quoted: 107 Post(s)
What's that?
https://www.youtube.com/watch?v=1qBk5pePGRg
RJ the Bike Guy always seems to have a solution.
johnlink is offline
Old 02-04-18, 03:35 PM
CliffordK
CliffordK's Avatar
Quoted: 14479 Post(s)
Liked 2,439 Times in 1,816 Posts
That should disassemble the freehub, but probably won't remove the retention bolt which appears to need some kind of a specialized torx style wrench.
One might try some larger Torx wrenches just to see if they fit, but someone probably chose to make it harder than necessary. Is that 9 point or 10 point?
CliffordK is offline
Old 02-04-18, 03:44 PM
johnlink
Quoted: 107 Post(s)
The TL-FH10 tool will remove the freehub.
It's eight.
johnlink is offline
Likes For johnlink:
Old 02-04-18, 03:54 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1998 Post(s)
Liked 835 Times in 511 Posts
Originally Posted by johnlink View Post
What's that?
Bicycle Research is a company that used to make a wide variety of specialty bike tools, like freewheel removers, bottom bracket tools. It used to be if a manufacturer made something odd Bicycle Research would have a tool to work on it. I think this freehub body mounting system was too short lived for anyone but shipmano to make tools for it.
Bianchigirll is offline
Old 02-04-18, 04:02 PM
johnlink
Quoted: 107 Post(s)
Here's another one on eBay, this one with excellent pictures.
https://www.ebay.com/itm/TL-FH10-Fre...SsLqnuRIQsy8tQ
johnlink is offline
Old 02-04-18, 04:04 PM
johnlink
Quoted: 107 Post(s)
Is this it? BicycleTool.com
johnlink is offline
Old 02-04-18, 04:06 PM
Bianchigirll
Bianchi Goddess
Yes I think that is them now.
Old 02-04-18, 04:09 PM
francophile
PM me your cotters
What BG ^ said. Hand-machined out of California, Bay Area if I recall correctly. They have some excellent remakes of Shimano tools no longer around, especially the old freewheel (not necessarily freehub) pullers
Link: BicycleTool.com
Old 02-04-18, 04:41 PM
T-Mar
Quoted: 4056 Post(s)
Liked 1,602 Times in 1,149 Posts
The tool with two prongs is designed to adjust/remove the bearing cup from the freehub. It does not remove the freehub body. Using it to remove the freehub body is analogous to using a pin tool on a freewheel dust shield/outer cone in an attempt to remove a freewheel from a hub. You're just going to end up with a lot of very small bearings escaping and rolling all over the place.
Last edited by T-Mar; 02-04-18 at 04:56 PM. Reason: corrected notches to prongs -D'oh!
T-Mar is offline
Likes For T-Mar:
Old 02-04-18, 05:00 PM
johnlink
Quoted: 107 Post(s)
Here are two videos from RJ the Bike Guy dealing with freehubs.
johnlink is offline
Likes For johnlink:
Old 02-04-18, 05:28 PM
CliffordK
CliffordK's Avatar
Well, remind me to avoid those DA freehubs.
Can the mounting bolt be replaced with standard Shimano mounting bolts?
Old 02-04-18, 05:48 PM
Ghrumpy
Quoted: 379 Post(s)
Liked 3 Times in 3 Posts
If I may ask, why do you want to remove the freehub in the first place?
Ghrumpy is offline
Old 02-04-18, 05:56 PM
Ghrumpy
Quoted: 379 Post(s)
Cool. More for me. Those things are pretty bombproof (which is why I asked the OP why he wants to remove it.)
Nope. That's the only downside to them. They aren't future-proof because you can't retrofit a later freehub body. Well, you could put a 7s D-A freehub on a 6s D-A shell. But that's as far as it went.
That's how Dura-Ace rolled back then. Incompatible with everything but itself.
Ghrumpy is offline
Likes For Ghrumpy:
Old 02-04-18, 06:30 PM
johnlink
Quoted: 107 Post(s)
I thought that my chain was skipping, but I eventually determined that it was my freehub that was skipping and not the chain. So I want to remove, clean, lube, and replace the freehub as shown in one of RJ the Bike Guy's video above.
johnlink is offline
Old 02-04-18, 06:56 PM
Ex Pres
Cat 6
Ex Pres's Avatar
Quoted: 468 Post(s)
Liked 105 Times in 74 Posts
there is a hack as an alternative to the correct tool. It was posted here a while ago. It involves a square bar of the right size and a file. I don't recall the exact details, though, but a search may yield the answer.
Ex Pres is offline
Old 02-04-18, 07:10 PM
Kontact
Kontact's Avatar
Quoted: 2148 Post(s)
Liked 7 Times in 7 Posts
Dura Ace has always been incredibly undersupported by Shimano. Try finding a replacement 103mm Shimano BB for a 7410 crank or parts to rebuild a "serviceable" 7700 Octalink BB. They treat the group as a test bed, not a pro group.
Kontact is offline
Likes For Kontact:
Old 02-04-18, 07:28 PM
Ghrumpy
Quoted: 379 Post(s)
You might just have to do it in situ. Spray some Triflow or equivalent into the gap between the bearing race and the freehub shell and spin it around. Flip it over and let it drain. Repeat a few times, then see if that helps. If you can hear a grinding instead of the pawls just clicking into place, the freehub might be toast.
Don't worry about greasing the inside of the freehub. I recommend you not do it at all. You could practically run it dry, in fact. The only time the freehub turns is when it has no load on it, so it's not like the hub bearings. A light machine oil is all it needs. Same for all freewheels, by the way.
This only applies to pawl-type mechanisms. Some freehubs use different mechanisms, like drive rings or plates. Some share the space with the hub bearings, and in those cases the above does not apply. Follow manufacturers' specs for those types of freehubs.
Ghrumpy is offline
Likes For Ghrumpy:
Old 02-04-18, 07:40 PM
johnlink
Quoted: 107 Post(s)
I won't have to do so, because I bought the TL-FH10 removal tool on eBay today (see the pictures in post #2 above). On the other hand, it would have been good to do what you suggest below before I put the bike back together.
johnlink is offline
Old 02-04-18, 07:51 PM
Ghrumpy
Quoted: 379 Post(s)
Cool, let us know how it goes.
Ghrumpy is offline
Old 02-05-18, 04:32 PM
BluesDaddy
I got 99 projects
BluesDaddy's Avatar
Quoted: 42 Post(s)
This is why I stop at Ultegra. Dura Ace is too frequently incompatible. Most Shimano freehub bodies can be removed with a simple 10mm Allen.
BluesDaddy is offline
Old 02-05-18, 08:48 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1555 Post(s)
Liked 1,002 Times in 468 Posts
No need to stop at Ultegra, although it is lovely in its own right. Just avoid 740X shifting components. Everything else is fully compatible with all Shimano SIS amd indexing components below ten speeds.
rccardr is offline
