What does "Tubeless light" mean?
Old 09-07-19, 08:22 AM
SWorksRoubaix
Quoted: 64 Post(s)
Does this mean it can also be used as a tubeless tire?
SWorksRoubaix is offline
Old 09-07-19, 08:49 AM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,436 Times in 4,663 Posts
If it says "Tubeless," it can be run tubeless - there's not much ambiguity there.
As far as "Light," I would guess one of two things. First would be marketing, letting you know that this is a supple, performance tubeless tire, not one of those stiff, utilitarian jobbers. The other guess is that there are some tubeless tires that can be run without sealant - maybe the nomenclature has something to do with whether or not it was designed to work with sealant or if it's capable of running without (not that I would want to run without).
WhyFi is offline
Old 09-07-19, 09:41 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
It is the same as regular tubeless but reduced calorie for a healthier lifestyle.
-Tim-
TimothyH is offline
Likes For TimothyH:
Old 09-07-19, 01:12 PM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 218 Post(s)
Liked 145 Times in 78 Posts
-Tim-
I was thinking more like light cigarettes. Less flavor but still has all the cancer.😁
I ran a set of these for about 1k miles tubeless. The 180 tpi casing provides a very smooth and comfortable ride. Never had to plug or patch them, pulled them off because the rear wore out.
From the Specialized website.
The S-Works Turbo Road Tire serves up the ultimate in tubeless performance. It features a startlingly low rolling resistance, while also serving as a lighter weight option than other leading clincher/tube combos on the market. Not stopping there, the GRIPTON compound, along with the 180 TPI casing, means that you'll experience superior cornering traction, while expending less effort on climbs and going significantly faster on descents.
Bryan C. is offline
Old 09-07-19, 01:20 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22570 Post(s)
Liked 8,918 Times in 4,152 Posts
I have no clue, but I bet if another tire maker uses the same term, Specialized will lawyer up!
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 09-07-19, 07:30 PM
TimothyH
- Soli Deo Gloria -
I think you are onto something.
Vittoria Rubino Speed are similar. They are like the regular Rubino but lighter - 1200 miles and the rear tire is toast.
-Tim-
TimothyH is offline
Old 09-09-19, 05:48 PM
bruce19
bruce19's Avatar
Quoted: 1743 Post(s)
Liked 1,279 Times in 739 Posts
Just like they did with the Cafe Roubaix bike shop in Canada. I wonder if they know where the name Roubaix actually comes from. Not that Specialized is worried but this stupidity has caused me to decline to buy one of their bikes.
https://www.velonews.com/2013/12/bik...e-brand_310878
bruce19 is offline
crank_addict
Classic & Vintage
24
03-02-19 11:43 PM
dwmckee
Road Cycling
32
08-20-17 08:09 PM
CanadianBiker32
Mountain Biking
13
02-09-14 12:16 PM
jesseh627
Fifty Plus (50+)
20
08-06-13 10:14 PM
pablosnazzy
Mountain Biking
4
08-09-11 04:04 PM
