Which Derailleur? RX 800? RX810? RX812?
Old 11-05-19, 05:11 PM
cccorlew
Erect member since 1953
cccorlew's Avatar
Bikes: Roubaix Expert, Motobecane Ti Century Elite turned commuter, Cannondale F500 Mtn bike, Some old French thing gone fixie
Quoted: 97 Post(s)
Liked 17 Times in 10 Posts
Currently I have an 11-32 in back. I'd like to go 11-36, but my Ultegra derailleur will only handle 32.
So, RX 800? RX810? RX812? They all have a 34 tooth max, but I'm hoping I could stretch it to 36. Th 812 says it's only for 1x bikes, but how would it know? Why would it care?
I have a gravel bike with a 46-30 crankset. I'm planning on a week long off road tour with way too many climbs. I ride 7000 miles a year, but on the road. I wouldn't call myself strong.
Please help me pick a new derailleur that will work for me. I have Shimano 11 speed brake/shifters, so it has to be one of these I think...
Thanks
cccorlew is offline
Old 11-05-19, 05:16 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1371 Post(s)
Liked 603 Times in 451 Posts
Thanks
Chain wrap capacity.
A 1X only has to wrap the difference between the smallest & largest cogs/
Add a ring and it also has to wrap that additional difference.
Bill Kapaun is offline
Old 11-05-19, 06:53 PM
HTupolev
Quoted: 1788 Post(s)
Liked 964 Times in 476 Posts
They don't all have a 34T max; the RD-RX812 has a 42T max
The RD-RX812 is a 1x derailleur in two ways.
First, it's only designed to wrap enough chain to handle a 42-11 cassette, which is 42-11 = 31 links.
Whereas an RD-RX810 is designed to handle up to an 11-34 cassette along with a 48-31 crank, which is 34-11+48-31 = 40 links. To handle this, the RD-RX800 and RD-RX810 use a longer tension cage than the RD-RX812.
Second, on the RD-RX812, there's a lot of distance between the tension cage pivot and the jockey wheel. This causes the position of the jockey wheel to be heavily dependent on how much chain is currently being wrapped. When the drivetrain shifts to a bigger cog, the tension cage swings counter-clockwise (when viewed from the drive side), lowering the jockey wheel. This means that the derailleur will actually adapt itself to the cassette somewhat; if you switch to a smaller cassette, the jockey wheel will stay close to the cassette when you're in the now-less-big big cogs, so shifting won't degrade much when you switch between different cassettes.
HOWEVER
Front shifting ruins this scheme. When you shift to a bigger chainring up front, the rear derailleur swings counter-clockwise and pulls the jockey wheel away from the cogs, affecting the rear shifting. This obviously isn't desirable. So, the RD-RX800 and RD-RX810 keep the jockey wheel close to the cage pivot, so that front shifting has a minimal effect on rear shifting. Instead, they rely mostly on the geometry of the parallelogram to manage the distance between the jockey wheel and the cogs.
HTupolev is offline
Likes For HTupolev:
Old 11-05-19, 09:00 PM
cccorlew
cccorlew's Avatar
Quoted: 97 Post(s)
Thanks all! This is info that is very useful. I feel educated.
cccorlew is offline
Old 11-05-19, 09:03 PM
Bill Kapaun
Me too-
Old 11-06-19, 12:49 PM
sch
Quoted: 279 Post(s)
Liked 94 Times in 75 Posts
Ditto. However there have been a number of posters on this and other forums that have used Ultegra 11spd
(both Di2 and cable pull)
on 11-36 cassettes, some with and a few without the $10 (on Amazon) RD mount extenders popularized by
Wolftooth (who ask $20 for theirs). FWIW I recently rebuilt my 2008 tandem with the Shimano RD7800
long cage left on but extended with a Wolftooth and it functions fine with a 10 spd 11-36 cassette.
Might be worth saving $100 and try an extender instead. (based on $110 prices for the RD RX810)
sch is offline
