Ergon GP3 Grips - any advice/experience?
Old 05-06-20, 03:02 PM
Gaarci
Quoted: 5 Post(s)
Liked 5 Times in 2 Posts
Hello - NOOB question here - I am considering changing out my stock grips with Ergon GP3 grips - these look to molded to fit the hand and seem like they would be much more comfortable than my regular bike grips that came with my Schwinn DSB bike which are not very comfortable at all - but I have never changed out grips on a bike before and don't know how difficult the process would be - thank you!
Gaarci is offline
Old 05-06-20, 03:33 PM
Digger Goreman
Quidam Bike Super Hero
Digger Goreman's Avatar
Quoted: 272 Post(s)
Liked 306 Times in 212 Posts
I have the Ergon GP2 and they are flat feakin AWESOME! Excellent wrist support and additional positioning helps
To remove old grips: take your thinnest allen wrench and, if you need the assist, isopropyl alchohol. Insert allen between grip and bar, lean bike handle a bit downward, and dribble/splash in a little alcohol. Keeping allen in, rotate gently around, then twist off the grip (should be easier now).
When putting on the Ergons, place the cap end on the grip before putting grip on the bar. Slide onto the bar till the cap end just starts to back out of the grip. Push the cap end into the bar. Holding one palm against the cap, push the grip back, all the way, against the cap. It will now be exactly at the end of your bar. Rotate where you want and tighten.
On my commuter....
Be sure to get the right grips according to your shifters (grip shift/trigger shifters).
Digger Goreman is offline
Likes For Digger Goreman:
Old 05-06-20, 05:05 PM
SlvrDragon50
Quoted: 45 Post(s)
Liked 13 Times in 9 Posts
They are very comfy! Changing the grips can be super easy or super painful, all a matter of luck. Above instructions are very good.
SlvrDragon50 is offline
Likes For SlvrDragon50:
Old 05-06-20, 09:28 PM
Archwhorides
Archwhorides's Avatar
Bikes: Death machines all
Quoted: 296 Post(s)
Liked 75 Times in 57 Posts
Ergon GP3 grips are excellent - have had them on a number of bikes.
Work is the curse of the drinking classes - Oscar Wilde
Archwhorides is offline
Likes For Archwhorides:
Old 05-07-20, 06:50 AM
Gaarci
Quoted: 5 Post(s)
On my commuter....
Thanks for that excellent advice and tutorial - I used that system you suggested and installed the grips - you're right - they are fantastic - thanks!
Gaarci is offline
Old 05-11-20, 08:33 PM
alias5000
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, 2007 Trek 6000, Circe Morpheus
Quoted: 164 Post(s)
Liked 8 Times in 7 Posts
I have GP3's on my commuter / former touring bike. Best grips I have ever had.
alias5000 is offline
Old 05-15-20, 07:31 AM
kayakindude
Bikes: 1987 Cannondale SR600/BioPace, 1991 Cannondale Road Tandem,1994 Giant Iguana MB, 2009 Airnimal Chameleon, 2016 Dahon Vybe C7A
Quoted: 96 Post(s)
Liked 61 Times in 38 Posts
Best I can give is use an air compressor if you have one. The air will make taking your old grips off super easy.
kayakindude is offline
