cheap Garmin Varia radar entry point?
Old 11-03-20, 03:55 AM
justslow
Quoted: 43 Post(s)
Liked 31 Times in 20 Posts
I've been reading lots about the Garmin Varia radar units and would like to get started with one.
I see the Garmin Varia RVR315 advertised for $139. I have an old but perfectly functional Samsung Galaxy S5 with an outdated version of Android.
Is this combo sufficient to get started using the radar unit?
Would I need to download RideWithGPS (or similar) just to get the display of cars approaching?
justslow is offline
Old 11-03-20, 08:27 AM
crn3371
Quoted: 28 Post(s)
Liked 16 Times in 11 Posts
Pretty sure that a phone won’t work with the Varia, you’ll either need a compatible computer or the dedicated Garmin radar display unit.
crn3371 is offline
Likes For crn3371:
Old 11-03-20, 11:00 AM
Elvo
Quoted: 583 Post(s)
Liked 306 Times in 169 Posts
You would need Ride with GPS or the Varia app on your phone. There's also the varia display unit:
https://buy.garmin.com/en-US/US/p/582636
Elvo is offline
Likes For Elvo:
Old 11-03-20, 12:04 PM
crn3371
Quoted: 28 Post(s)
I stand corrected, didn’t realize it was compatible with phones.
crn3371 is offline
Likes For crn3371:
Old 11-03-20, 06:00 PM
bikebikebike
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 138 Post(s)
Liked 65 Times in 55 Posts
The very early models go for $60 used on Ebay and are ANT+ only.
Mid models can be found new for same price as used.
Newer models have BT, so will work with phones, as only a few Android phones have ANT+, no Apples do.
Software for BT on phones may be an issue.
Not sure if the ANT+/BT bridges work with the Varia *, but would add $50.
Too great a demand for discounts and for many used ones to be out there.
Seems folks tend to hang on to them. Hmmm
Edit
DCRainmaker has good review
https://www.dcrainmaker.com/2020/05/...ar-review.html
* Comment in May 2020 says bridge not working with the Varia RTL500
bikebikebike is offline
Likes For bikebikebike:
Old 11-03-20, 07:55 PM
justslow
Quoted: 43 Post(s)
The replies have been most helpful. Thanks to each.
Does anyone use a Varia without RideWithGPS or similar? It seems like overkill just to use the radar functionality. However, it's a no cost solution.
If I start considering a Varia RVR315, bike computer, HRM, cadence and speed sensors and multiple mounts (2 bikes) it quickly adds up to about $600. I can't afford the whole package so I'm looking for a way to get started on a budget. Looks like the RVR315 and using an old phone is the lowest $ entry point. I'm happy with my Cateye devices so I can keep using them.
justslow is offline
Old 11-03-20, 07:58 PM
justslow
Quoted: 43 Post(s)
Well dang that's a good display unit price at $99. It might be better than trying to keep an old phone/old Android version working.
justslow is offline
Old 11-04-20, 04:07 PM
John_V
John_V's Avatar
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 407 Post(s)
Liked 121 Times in 85 Posts
The RTL 510 and RTL 515 radars are both offered as a bundle with the display unit. Check to see if the RTL 315 is also offered as a bundle. My riding buddy has the RTL 510 bundle and he really likes the display unit. Kept him from having to buy a compatible GPS computer to replace the Bryton he already has.
As for having to purchase separate mounts for different bikes, take a look at the post on this forum about using the Varia with a DIY saddlebag mount. The mount and radar simply slides into the loop in the rear of the saddlebag while an O-ring keeps it from falling out.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Likes For John_V:
Old 11-04-20, 04:19 PM
wgscott
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,251 Times in 1,123 Posts
Originally Posted by crn3371 View Post
I stand corrected, didnít realize it was compatible with phones.
I have had the radar since version 1 was introduced, and I did not know this either.
wgscott is offline
Old 11-04-20, 04:21 PM
wgscott
Occam's Rotor
I bought an Edge 25 to use as a head unit when I got my radar. I eventually upgraded to a 130. Both of those aren't much more pricey than the display-only unit.
wgscott is offline
Old 11-04-20, 07:24 PM
justslow
Quoted: 43 Post(s)
Good idea about looking for bundles. I will research.
I found the discussion about the saddlebag mount using the included band and device mount. Since I could use the mounts included in the product that would be perfect. If it works well, I could get another for the other bike. Thanks.
justslow is offline
Old 11-04-20, 07:36 PM
justslow
Quoted: 43 Post(s)
I'm checking on the Edge 25 right now. I sure like the simplicity and form factor. The price is good too!
I don't know if my current Cateye sensors will pair with anything but Cateye head units. I have a full wireless Cateye suite on each bike - HRM, cadence and speed. If my Cateye sensors won't pair with (e.g.) an Edge 25 then the cost grows to include new sensors all around. I'm hoping to find an "upgrade path" whereby my initial outlay is limited but over time I can get to one platform. I can continue to use the Cateye devices until I can afford new sensors, and then get rid of the Cateye entirely. Not that I dislike the Cateye but one ecosystem is enough.
Did you have other sensors paired with the Edge 25?
Anyone every pair Cateye sensors with other head units?
Thanks for the reply.
justslow is offline
Old 11-04-20, 08:11 PM
wgscott
Occam's Rotor
I've never paired either my 25 (RIP, went through the laundry) or 130 with anything other than the radar, but I think you can pair them with speed and cadence sensors, heart monitor, etc. So they might work. The 25 I seem to recall only uses the speed/cadence sensors when you are on a trainer, which is kind of an idiotic limitation.
There is a HUGELY useful resource for this stuff, if you haven't come across it: DC Rainmaker
Here is his review of the Edge 25
also, the Radar
I think the Edge 25 is at the end of its lifetime. My main complaint is the battery lifetime.
wgscott is offline
Likes For wgscott:
Old 11-06-20, 08:35 AM
John_V
John_V's Avatar
Quoted: 407 Post(s)
The newer RTL 515 and RVR 315 are compatible with cell phones since they now have Bluetooth. Earlier versions of the radar are not phone compatible.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Likes For John_V:
Old 11-08-20, 09:32 AM
kissTheApex
kissTheApex's Avatar
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times in 199 Posts
I’d recommend the 515 as it’s also a rear light. Since you don’t mention a head unit, I assume you have a mount of some sort for your phone. That way, you can run Varia app, or ridewithgps. I agree 315 might get you going for less, but 515 has a very good light that also goes into a different flash mode when it detects a vehicle behind.
kissTheApex is offline
Likes For kissTheApex:
Old 11-08-20, 10:50 AM
crn3371
Quoted: 28 Post(s)
The Edge 25 seems too small to me, not enough real estate to capture my attention for radar notification.
crn3371 is offline
Old 11-09-20, 12:57 AM
justslow
Quoted: 43 Post(s)
Originally Posted by kissTheApex View Post
Iíd recommend the 515 as itís also a rear light. Since you donít mention a head unit, I assume you have a mount of some sort for your phone. That way, you can run Varia app, or ridewithgps. I agree 315 might get you going for less, but 515 has a very good light that also goes into a different flash mode when it detects a vehicle behind.
As I learn more, my choices are changing. The current plan is to wait a bit and get a Wahoo Bolt head unit and a Varia RTL515 radar and tail light. For speed and cadence, the Wahoo Blue SC unit looks good. I will need 2 of these because I have 2 bikes. Add in a Wahoo HRM and I'll have a good "starter" system.
All this comes to just about $650. Santa may help with some of the sensors. I ride on the road and I think the warning sensor will help me stay safe.
justslow is offline
Likes For justslow:
Old 11-10-20, 10:07 AM
John_V
John_V's Avatar
Quoted: 407 Post(s)
If you plan on using the radar with a Wahoo Bolt, I would suggest that you look around for an RTL 510 instead. They should still be available and the only difference is the Bluetooth and one extra light mode (for group rides). If you don't need either of those options on the RTL515, the 510 will save you a few bucks.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Likes For John_V:
Old 11-10-20, 11:49 AM
justslow
Quoted: 43 Post(s)
The advantage of being on a tight budget is that one can(must) go slowly with purchases. I continue to waffle and weave on my decisions which is fine for now. Your suggestion of getting the 510 over the 515 is duly noted. Thanks.
justslow is offline
Old 11-10-20, 05:28 PM
JohnJ80
Bikes: N+1=5
Quoted: 774 Post(s)
Liked 149 Times in 114 Posts
I have every version of the Varia radar that's been available going back to the original.
Here are your answers:
  1. The original and Varia 2 only work on ANT+. So unless you have specific cell phones that support ANT+, it won't work with a cell phone.
  2. You can still find the Varia 2 taillight around for $129-149. You can also find units with the head unit so you don't need a phone or bike computer at all.
  3. The new Varia 315 (no light) and the 515 with light have both ANT+ and BT connectivity. Garmin supplies a phone app for both iOS and Android that gives you a display, audio and vibration warning. This works pretty well.
Paraphrasing Ray Maker (DCRainmaker): "There are two kinds of people when it comes to Garmn's Varia Radar- those that love it and those that haven't tried it." He nailed it with that one.
Garmin, Wahoo, Hammerhead, and somebody else now are supporting the Varia directly to the head unit of the bike computer.
JohnJ80 is offline
Likes For JohnJ80:
Old 11-13-20, 03:27 PM
kissTheApex
Bikes: Yes please
Quoted: 536 Post(s)
OP. REI has a 20% off sale going on, which brings rtl515 down to $160. “Gearup2020” if I’m remembering correctly.
