Do you rotate your front and rear tires?
Old 12-11-20, 08:00 PM
cubewheels
Bikes: A really old BMX bike, Phantom 20 kid's MTB, Jackal Mio Gravel Bike
Quoted: 764 Post(s)
Liked 365 Times in 293 Posts
Or just buy a new tire for the rear first if that has worn enough?
cubewheels is offline
Old 12-11-20, 08:01 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4900 Post(s)
Liked 1,707 Times in 949 Posts
As a front tire typically lasts as long as two rear tires, I see no point in rotating them. For me. So no. I do not.
DrIsotope is offline
Likes For DrIsotope:
Old 12-11-20, 08:15 PM
Quoted: 13737 Post(s)
Liked 6,599 Times in 3,357 Posts
Its going to be a long winter.
BTW...Search thread titles. There are 8,000 threads on the subject.
indyfabz is online now
Likes For indyfabz:
Old 12-11-20, 08:19 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 2913 Post(s)
Liked 2,263 Times in 1,107 Posts
I never thought of do it.
GlennR is offline
Old 12-11-20, 08:22 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 6070 Post(s)
Liked 3,226 Times in 1,864 Posts
I've done it a couple times. Most recently, it was because I had waited too long and couldn't decide what new tires to buy. I knew it'd be a couple weeks before I would choose and receive the new tires. These were gravel tires with tread.
Swapping probably isn't too beneficial in most situations.
mstateglfr is offline
Old 12-11-20, 08:31 PM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 805 Post(s)
Liked 112 Times in 92 Posts
It used to be generally a bad idea. Now tires are way better. The rear will develop a flat center.
I have rotated my Marathon Plus tires, since they last 10,000 miles easily now. I started my second tour with the same tires. The front one died half way, it ran over a damn staple cartridge.
GamblerGORD53 is offline
Old 12-11-20, 08:35 PM
siclmn
Quoted: 14 Post(s)
Liked 10 Times in 7 Posts
Once I put on a very squared tire on the front. On that ride it would try to steer itself in different directions when the road changed. That ended that experiment. It is a very bad idea. Don't do it.
siclmn is offline
Likes For siclmn:
Old 12-11-20, 09:02 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 548 Post(s)
Liked 315 Times in 221 Posts
Rear to trash, front to back, new tire on front.
With losing front tire traction leading to low side crashes, you want the freshest rubber in front to minimize the risk of punctures and blow outs.
Drew Eckhardt is offline
Old 12-11-20, 09:14 PM
blakcloud
blakcloud's Avatar
Bikes: Trek Domane SL7, Rivendell Sam Hillborne, Winter Cycles flat bar road bike, Brompton S/M3L (modified)
Quoted: 597 Post(s)
Liked 327 Times in 210 Posts
I never rotate, new rubber front and back. Just makes life easier.
blakcloud is offline
Likes For blakcloud:
Old 12-11-20, 09:21 PM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 526 Post(s)
Liked 575 Times in 319 Posts
I buy my tires (usually yellow/black Rubino Pros) in sets of 3. I run the front tire in the time I go through 2 rear tires, usually ~7000 mi front, ~3500 mi each rear. I swap in the 2nd rear tire, or replace the pair, when the rear tire starts showing threads. I usually start looking for the next set of 3 when Im half way through the 2nd rear.
Litespud is offline
Old 12-11-20, 09:45 PM
rsbob
Sniveling Weasel
Bikes: Orbea Orca, Fondriest Racing, Bianchi Trofeo, Bianchi Infinito, Schwinn Varsity, Trek mtn
Quoted: 538 Post(s)
Liked 799 Times in 502 Posts
Typically I replace both. Prudent for flat protection and front wheel grip? Perhaps. Economically prudent? Perhaps not.
Rick S
He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.- Fredrick Nietzsche. An argument based reasoned fact, beats one based on emotional rantings every time Anon
rsbob is offline
Old 12-11-20, 09:56 PM
flangehead
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 244 Post(s)
Liked 334 Times in 196 Posts
Originally Posted by drew eckhardt View Post
rear to trash, front to back, new tire.
+1
flangehead is offline
Likes For flangehead:
Old 12-11-20, 10:30 PM
SurferRosa
Seor Member
SurferRosa's Avatar
Quoted: 1900 Post(s)
Liked 2,139 Times in 1,198 Posts
I have. Yes. Depends. Not always.
SurferRosa is offline
Old 12-11-20, 10:36 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 934 Post(s)
Liked 1,203 Times in 679 Posts
This is the correct answer, and the right reasons.
cxwrench is offline
Likes For cxwrench:
Old 12-11-20, 10:42 PM
Danhedonia
Quoted: 237 Post(s)
Liked 173 Times in 92 Posts
What are "Yes Depends?" And why do you have them?
Danhedonia is offline
Likes For Danhedonia:
Old 12-12-20, 12:29 AM
SurferRosa
Seor Member
SurferRosa's Avatar
I'll give a 2/10 for your real stretch at an adult diaper joke, but only because I'm a really nice guy.
Old 12-12-20, 01:17 AM
GamblerGORD53
Quoted: 805 Post(s)
Yer all wimps. LOL. Here's my front tyre after I rode 1,930 miles, after I bought a 1973 CCM. I changed both tubes and put the tyres back on, after I SANDED the rough hard edges by the bead. LOL. It is at least 30 years old, likely 40. See how tyre is spelled on the sidewall. I decided this was the last ride, so I rode it down the highway 36 miles out and back. 25 miles from home it got a wire flat. So half of the crumbling was from mounting. It wobbled all the way home. LOL I guess some more of the crumbling was when I took it off for good. The second last ride was around Jasper and the north 12 miles of the Columbia Icefields Parkway. I had to vacuum up the crumbs.
Old 12-12-20, 02:37 AM
alo
Quoted: 528 Post(s)
Liked 254 Times in 185 Posts
I don't. Bike tires are so cheap, it is easy to put a new one on. I know, some people have expensive tires. There is also the chance of damaging a tire or tube when swapping them.
alo is offline
Old 12-12-20, 02:47 AM
alo
Quoted: 528 Post(s)
I use the front brake unless I am turning. In some situations, both are sometimes needed. I find, using the front brake much more than the back brake, front tires wear out almost as fast as back tires. It also depends on where you are riding, and how much you need to use your brakes.
alo is offline
Likes For alo:
Old 12-12-20, 02:53 AM
alo
Quoted: 528 Post(s)
It depends where you are riding. Where I am, I often ride through mud. While having good tread on both tires is ideal, having good tread on the back tire is most important. Without tread, tires can just spin in the mud. You can get away with partly worn tread on the front.
alo is offline
Likes For alo:
Old 12-12-20, 02:59 AM
Trevtassie
Quoted: 1034 Post(s)
Liked 939 Times in 526 Posts
I do on my touring bike if it's coinciding with tours. But I've been having terrible wear issues with the Surly ETs such that the rear only lasts 1500 miles anyway.
Hopefully the Schwalbe Moto-x will last long enough to make rotating them worthwhile.
Trevtassie is offline
Old 12-12-20, 03:44 AM
wolfchild
wolfchild's Avatar
Quoted: 2285 Post(s)
Liked 1,093 Times in 550 Posts
I rotate my tires . Have been doing it for a very long time, never had any issues. Just make sure to inspect the tires before rotating.
wolfchild is offline
Likes For wolfchild:
Old 12-12-20, 04:16 AM
cubewheels
Quoted: 764 Post(s)
Good point. I often ride early in the morning where the moist road can sometimes have very poor traction. The biggest problem if it's a steep climb and the rear wheels spin.
I have used worn (relatively squared) tires on the front wheel (knobby tire that has worn its knobs at the center) after rotating the front and rear. Never exprienced handling issues except when braking in poor traction conditions.
Old 12-12-20, 04:19 AM
cubewheels
Quoted: 764 Post(s)
I'll do that from now on!
Old 12-12-20, 05:51 AM
Lrdchaos
Quoted: 83 Post(s)
Liked 18 Times in 13 Posts
I dont, I slap on a new rear and keep rolling with the front.
Lrdchaos is offline
