Trek 2100 (Bonded Carbon)- loose DT shifter boss?
Working on an early 90s trek 2100, one of the ones with the carbon tubes bonded to the aluminum lugs. The left side downtube shifter boss is loose and I can't figure out why. Anyone seen this before or know how these attach? There's what looks like a little flat head screw in there but I can't seem to get it to turn.
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
One side of the mount was fixed and part of the other rotated and tightened on threaded shaft that went right through tube .
I wonder if this is the case with yours ?
I have an assembly somewhere off a busted frame I should take a pic of too .
Quoted: 1635 Post(s)
Liked 824 Times
The epoxy bond between the down tube and the boss had failed which caused the FD cable tension to pull up the leading edge of the boss to where it is, most likely, bending the screw that goes through the down tube, between the two bosses.
Getting the loose boss off the frame for re-gluing with epoxy, will be quite difficult, because of that bent, and possibly, corrosion seized screw.
Vitus used an almost identical design for their 979 and Carbone frame bonded on shifter bosses, and I still see replacement sets for sale on eBay, once in a while. You might consider getting a set to repair your frame, if you end up damaging the ones on your frame.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 82 Post(s)
Liked 141 Times
It's the same deal with their all-aluminum frames from the same era. Along with other forum peeps, I had good luck with JB Weld, bought me another two seasons. I never replaced the screw, and ultimately it failed again, and it's awaiting some sort of bizarre 1x bar-end build at the moment. Talked with a bike shop owner a while ago who had one and he said he got that repair kit with the screw and it worked as advertised.
This is only somewhat related, but does anyone know if you can use those bolt-through ones on a steel frame? Like if there were no frame builders in your area and you were reasonably competent at marking and drilling holes, is the steel on a bike that much thinner that it wouldn't suit this kind of attachment?
