De-uglifiying my De Rosa
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,854 Times
So, after about three years of open heresy, I finally decided to address one of the glaring aesthetic problems with my De Rosa. Look carefully and see if you can spot the change:
Before:
After:
That's right, I finally ditched those awful period correct pedals and applied some dirt to the glaringly white bar tape. Just kidding, the pedals came off about a day after the last time I rode this bike at Eroica, and, of course, the bar tape stopped being that white about 100 yards into the first ride. Though the fact that it doesn't even look white in a picture anymore suggests that maybe I should at least try to clean it up a bit.
On the down side, my rear derailleur no longer doubles as a kickstand. Also, I lost a whole lot of range in my gearing. The old drivetrain went from 108 gear inches in the 52-13 all the way to a bit less than 24 inches in the 26-30. The new drivetrain is 48-42-30 with a 13-23 freewheel. The benefits are: (a) it's not dog ugly, (b) I can successfully shift from the small ring to the middle ring [with the 52-42-26, I had to shift from the small to the big and then back down to the middle], and (c) the jumps between gears are significantly smaller. I did lose a bit of low end range, but while I no longer have a 24 inch gear, I can still use my two foot gear on really steep climbs.
I took it out for a test ride today, including a grueling climb up and over Sexton Mountain. If you're not familiar with Beaverton (including those from Portland or Hillsboro who are wondering where the heck Sexton Mountain is), click the link for details of this Herculean feat. I was actually very pleased with the gearing. I did have to mash a bit more than I like to, but I was able to maintain a decent pace at grades up to about 6%. I've got a lot of bikes that will get me up much steeper hills, so I don't really mind limiting this one to mildly hilly routes. I put the absurdly low gearing it had before on there in an attempt to prepare for the climbs at Eroica California and ended up having to walk on all three of the big hills anyway. And, of course, as my friend Fernando says, "It's better to look good than to feel good."
Before:
After:
My Bikes
My Bikes
Quoted: 1601 Post(s)
Liked 2,187 Times
@Andy_K Know of Sexton Mtn. Lived on the north side of Cooper Mtn off 185th. I would commute to Hilsboro from there with nearly a 300 ft gain in 4 blocks going up 179th. Newspaper route to get up the hill! It can be done if you are in good shape!
Likes For SJX426:
feros ferio
Quoted: 1384 Post(s)
Liked 1,294 Times
As you discovered, the secret to low gearing is to realize you probably do not need the typical highest gear ratios that adorn many bicycles. You still have 100 gear-inches on top (48/13); I run mid-90s on my road bikes, anything from 45/13 to 46/13 or 50/14, and I don't miss having anything higher.
Before I gave it to my son and regeared it to his liking, I ran a very satisfying 3x6 half-step-plus-granny on the PKN-10, 48-45-34/13-24 with a short-cage SunTour Cyclone II in back and original designed-for-double Simplex up front. The secret sauce is that 48-34 = 14 teeth = 53-39, so I put the same chain wrap demands on the rear derailleur as a standard road double would.
Likes For John E:
Proud to say I noticed the change in the alien claw apparently birthing itself from the seat stay. I assume it’s moved on and seeded itself into one of your other bikes. I will also say pretty cheeky matching the Gatorade and bottle top to the frame and saddle.
Bikes: Yes
Liked 3,854 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,854 Times
My Bikes
My Bikes
Bikes: Yes
Liked 3,854 Times
You know, it’s not even the first picture I’ve posted this week where I purposely matched the Gatorade to the bike. They just have so many colors available. The blue cap matching the saddle was just serendipity.
My Bikes
My Bikes
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4670 Post(s)
Liked 5,769 Times
