Do I have to take rim tape off when I put a tube in?
If I get a flat on a tubeless tire on the road and want to put a tube in, do I have to take the rim tape out?
Quoted: 336 Post(s)
Liked 309 Times
No, stuff the valve stem through hole in the tape where the tubeless valve was. The tape prevents the tube from herniating through the spoke holes and puncturing on the spoke ends or nipples.
Likes For aggiegrads:
Quoted: 194 Post(s)
Liked 204 Times
Because tubes need protection from damage by the spokes, while tubeless set-ups need to provide a seal from the spokes. There are lighter and heavier tapes and bands to protect the tube, some of which in theory could seal a tubeless set-up. On the other hand, any band/strip which seals the spokes will probably be enough to protect a tube. However, that is not to say that there is / could be a technology of sealing the spokes which would not offer sufficient protection for a tube. I suspect that if you can buy a wheel that is tubeless ready someone somewhere is offering tube/tubeless ready tapes/bands, but, as always, not all the market offering 'tubeless ready' is really ready.
Likes For Geepig:
Quoted: 1062 Post(s)
Liked 665 Times
On a historical note, the two bikes that I owned in 1983 were a Schwinn and a Trek. The Schwinn had non adhesive rim strips like shown in the picture, but made of black rubber. The Trek had white cloth adhesive rim tape. Tubeless was not even on the horizon at that point. The rubber stuff deteriorated over time -- it was brittle and shattered when I worked on a 1963 Schwinn recently. And the joint where it went around the valve hole was a point of weakness. Adhesive tape worked better, lasted longer, and I believe is preferable today, but I imagine that it took time and skill to apply.
The new plastic strips like you've shown, I'm not happy with. One bike in the family fleet with "tubeless ready" wheels, came with those strips. Given the amount of effort to mount tires on a tubeless ready rim, the added hassle of the rim strip sliding around was a nightmare, and I switched it over to a modern adhesive tape.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Maybe this isn’t correct. But I just clean the rubber strip leaving on the rim and wrap 2 wraps of electrical tape around it. 3 wraps if the rubber is deteriorating. Poke a hole where the stem goes through.
It's certainly not normal. Rim tape is used for 1. watertight surface and 2. non-expandable, which it seems you have accomplished without shelling out money for a product that isn't used for anything else.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Maybe 100/year? So maybe that idea wouldn’t work for someone who rides 5k/year. In my defense, I probably have 16 years of professional mechanic experience (not bikes though), so I can see certain concepts, theory of operation stuff that would give me an idea of it something would work or not.
The flip side is someone who rides 5k/year, or someone who commutes by bike I would think would get so good at fixing flats that they’d be ok with trying something to see if it works.
All we’re trying to do is protect the tube from the sharp edges of the spoke nipple, right? Or am I missing something?
Of course - but there's been not even an unofficial study into rim strip + electrical tape versus rim tape.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
I’ll say one thing I like about my way.
It holds the valve stem pretty tight. I know you’re never supposed to ride on low air pressure. Sometimes real life for me is different, like if my kids ride their bikes while I’m at work, I’m not going to make sure their tires are perfectly inflated. And all tires lose air pressure over time.
That would be the only advantage I see with Presta. Doesn’t presta have a nut that holds the valve stem from rocking?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The tape is mostly there to protect the tube from the sharp edge of the spokes holes in the rim, and maybe the nipple inside the hole. The spokes should not be sticking out of the nipple unless they're the wrong size...which is obviously possible. I find it hard to believe that it's not painfully obvious that there needs to be something to cover those holes and that someone would consider removing it and then installing/inflating a tube.
There are a lot of Schrader tubes that have threaded stems and lock nuts, Specialized sells millions of them.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Installing a tube without a barrier over the spoke nipples is probably a mistake someone will only make once. I think I did it once when I was kid.
