This why I hate threaded headsets
Old 06-07-21, 12:55 PM
grizzly907la
Grouchy Old man
grizzly907la's Avatar
Bikes: Diamond Back Insight 2, Gravity Basecamp mountain bike, GMC Denali Road Bike
Quoted: 75 Post(s)
Liked 49 Times in 36 Posts
This is why I hate threaded headsets. Granted it would've came out if the previous owner had maintained it, though I am sure that there are some who had similar experiences with threadless headsets. Sprayed it down with PB blaster, used the heat gun but to avail, it was completely rusted on. Ended up using the dremel tool, cut it to the point where I can knock it off with my mallet. Hammer mechanics for the win!
The cut off stem
The fork
grizzly907la is offline
Likes For grizzly907la:
Old 06-07-21, 01:03 PM
rsbob
Sniveling Weasel
Bikes: Orbea Orca, Fondriest Racing, Bianchi Trofeo, Bianchi Infinito, Schwinn Varsity, Trek mtn
Quoted: 548 Post(s)
Liked 814 Times in 512 Posts
The winner and still champion!
Rick S
“He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche. “An argument based reasoned fact, beats one based on emotional rantings every time” Anon
rsbob is offline
Likes For rsbob:
Old 06-07-21, 01:04 PM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022, '21 Tsunami SNM-100
Quoted: 1363 Post(s)
Liked 1,314 Times in 706 Posts
If you had been a grouchy old man before this, I cringe to imagine how grouchy you've become as a result...
Phil_gretz is online now
Old 06-07-21, 01:12 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
At this point I am used to it, and I almost expect when working on older bikes. Not a big deal in the greater scheme of things. I am grouchier about the fact that many people neglect their things, don't appreciate them and are wasteful. To be fair I was a grouchy old man when I 10. Working in IT has exacerbated my grouchiness. I've been described as a lovable grouch. It's all part of my stately charm.
Old 06-07-21, 01:13 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
The surgery was a success put the patient didn't make it.
Old 06-07-21, 01:24 PM
pdlamb
Quoted: 1616 Post(s)
Liked 841 Times in 523 Posts
If brute force doesn't work, you need a bigger hammer!
pdlamb is offline
Old 06-07-21, 01:53 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
I also add "give me a big enough level, and I could move the world." The rest of the bike was relatively pain free to disassemble. I had to take the heat gun to the pedals, but they came out, and the BB was almost hand tight...maybe the heat on the pedals got to the bb. There's a little surface rust on the brakes, and the chainrings need to come off, and be replaced. Par for the course.
Old 06-07-21, 07:58 PM
veganbikes
Clark W. Griswold
Quoted: 2458 Post(s)
Liked 1,487 Times in 993 Posts
Me thinks they probably didn't bother using grease from the BD factory originally which can be quite common. Shame they couldn't just spend an extra 10¢ on a squirt of grease.
veganbikes is offline
Old 06-07-21, 08:06 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1706 Post(s)
Liked 1,355 Times in 876 Posts
Easy part's done. Now you have to get the stub out of the steerer.
dedhed is offline
Likes For dedhed:
Old 06-08-21, 02:47 AM
Lazyass
Quoted: 2315 Post(s)
Liked 430 Times in 273 Posts
I've had more quill stems than I can remember and only one was frozen. I have a racing jack (for cars) with a long aluminum hollow handle. I put a rod through the stem, heated it with my heat gun, attached my jack handle to it as a long breaker bar and popped it pretty easily.
So really you needed a long breaker bar.
Lazyass is offline
Old 06-08-21, 07:07 AM
Maelochs
Maelochs's Avatar
Quoted: 6301 Post(s)
Liked 1,242 Times in 713 Posts
What you hate is bad maintenance, not a particular headset style.
I once removed a stuck bottom bracket---I used a breaker bar long enough to bend the handle on my ratchet. Eventually I won .... I took out the bottom bracket and the threads from the shell, but I got that BB out.
I'd have hated the idiot who let the BB get stuck .... if it hadn't had been me, many years earlier, before I knew better.
Maelochs is offline
Old 06-08-21, 07:29 AM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 937 Post(s)
Liked 767 Times in 423 Posts
A product that seizes up from corrosion is the product of poor design
The threadless headset-quill stem combination is a poor design.
Ride, Rest, Repeat
terrymorse is offline
Old 06-08-21, 09:40 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 6109 Post(s)
Liked 3,252 Times in 1,875 Posts
What moving or bolted parts dont have the potential to seize up from corrosion though? Hubs, bottom bracket, chain, m5 mounting bolts, etc all can seize up from corrosion.
mstateglfr is offline
Likes For mstateglfr:
Old 06-08-21, 09:44 AM
Maelochs
Maelochs's Avatar
Galvanic welding, I think they call it ...... who hasn't wondered if the seat post was ever coming out of the frame?
Maelochs is offline
Likes For Maelochs:
Old 06-08-21, 11:32 AM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 937 Post(s)
Those parts may seize up, but they:
1. do not have salty water collection and holding built into their design
2. are not a huge hassle* to remove and replace in the rare case where they do seize up
(*) - A seized threaded bottom bracket can be a hassle (use press fit). As can a seat post (avoid metal post in metal frame).
Ride, Rest, Repeat
Old 06-08-21, 12:52 PM
Korina
Happy banana slug
Korina's Avatar
Bikes: 1992 Specialized Rockhopper Sport, 2016 Giant Liv Rove Lite, 1995 Trek Singletrack 930, 1994 Trek Multitrack 750
Quoted: 886 Post(s)
Liked 568 Times in 383 Posts
Korina is offline
Likes For Korina:
Old 06-08-21, 01:39 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2688 Post(s)
Liked 1,397 Times in 868 Posts
Or poor maintenance.
JohnDThompson is offline
Likes For JohnDThompson:
Old 06-08-21, 01:41 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 937 Post(s)
A well designed product continues to function with poor maintenance.
Ride, Rest, Repeat
Likes For terrymorse:
Old 06-08-21, 02:38 PM
Bill in VA
Bill in VA's Avatar
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 204 Post(s)
Liked 188 Times in 129 Posts
A man of honesty.
Been there done that with a French BB for cottered cranks. Not sure which bugged me the most, the BB issues or the PITA cotters. I succeeded with the BB after using ever swear work I knew and some I invented, all to forever banish the cottered crank. Hint: The solution for the BB was patience for me, not a strong point as a young man.
Bill in VA is offline
Likes For Bill in VA:
Old 06-08-21, 03:14 PM
JohnDThompson
Old fart
A stuck stem will continue to perform its function. It's only if you want to remove it that it becomes an issue.
Old 06-08-21, 03:23 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 937 Post(s)
Only for a limited definition of function.
Arguably, ability to raise or lower a stem, and to replace it with a stem of a different length, are functional requirements.
Arguably also, the ability to remove and replace a component is an essential feature.
Ride, Rest, Repeat
Old 06-08-21, 04:01 PM
dedhed
SE Wis
dedhed's Avatar
Fortunately had enough thread to install the new one but told him it was the LAST BB that was going into this frame.
dedhed is offline
Likes For dedhed:
Old 06-08-21, 05:28 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1010 Post(s)
Liked 574 Times in 372 Posts
Oddly enough I'm surprised that a painted stem would corrode to the point of seizing. I'd almost place my bets on the stem being slightly oversized, and "persuaded" into the steering tube.
I'm with Terry here, consumer designs that are more forgiving to neglect are better, all other things equal. For one thing, neglect could start at the factory. Does it mean getting rid of the old stuff, or merely treating it with the knowledge and respect for its failure modes? That's an individual judgment call. I'm willing to keep some old bikes despite needing a bit of TLC and care in reassembly, not others. I grease everything.
Gresp15C is offline
Likes For Gresp15C:
Old 06-08-21, 06:04 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
TBH I don't think it's that. The bike is 2009 model, and the person I bought it from, didn't seem very bright...then again most people don't work on their bikes or have them serviced. I event didn't think it was that big of a deal, but then I start doing amputations on bike parts, and that changed my mind very fast. Galvanic corrosion is real. They think that a bike will never break down. It goes the same for computers. They don't expect a PC to break down or have software problems, that just come out of the blue.
Old 06-08-21, 06:06 PM
grizzly907la
Grouchy Old man
Quoted: 75 Post(s)
HAHAHA!!!! I wouldn't even know where to start on that one.
