Changing crank from 50/39/30 to 44/32/22
Hi, I'm quite new to the whole technical part of biking. Up to now I only rode them.
The problem I have is that I have to prepare my bike for my first road trip and I'm quite a bit limited by time.
My bike has a
Shimano Sora FC-R3030 50/39/30 crank
BB: Shimano Tiagra BB-RS500
FD: Shimano Sora FD-R3030-F
with a friction shifter
and at the back a Shimano Alvio 9 (11-34).
This has worked well without luggage but I'm afraid it won't work so well with luggage and hills.
I haven't found any smaller chainrings for the Sora crank but from what I have read a 44/32/22 crank should work well enough.
The only available option I found though was a Shimano Alivo FC-T4060 44/32/22 crank which I have ordered but not received yet.
In the meantime I have found out that the difference in chainline will make problems (45 old crank, 50 new).
Would be awesome if anyone of you has an idea what I could do to make this work in a short amount of time.
Thanks, Phil
My bike has a
Thanks, Phil
Likes For 10 Wheels:
Quoted: 3458 Post(s)
Liked 1,465 Times
I threw Shimano Sora FC-R3030 into google and found a four arm crank and a five arm crank.
https://bike.shimano.com/en-EU/product/component/sora-r3000/FC-R3030.html
https://bike.shimano.com/en-EU/product/component/sora-r3000/FC-R3030-CG.html
One option would be to get a smaller innermost chainring and install that on your existing crank, but I have no clue if you have a four or five arm crank.
This link appears to be pertinent:
https://dassets.shimano.com/content/...3030-4153A.pdf
That link lists both cranks as having a 74mm bolt circle diameter (BCD), thus you could try to find a 24 or 26 tooth granny gear to use.
I use a 24T granny gear, five arm 74mm BCD, so I know they are available for five arm, but not sure about a four arm asymmetric bolt pattern.
Unfortunately I have the 4 arm and I couldn't find any smaller 4 arm chainrings with 74mm.
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
My bike has a
Thanks, Phil
My bike has a
Thanks, Phil
It isn’t much of a problem. Most likely the road front in the current configuration won’t move far enough out to get to the outer ring. Remove spacers on the bottom bracket from the right side and add them to the left. That will move the crank inboard enough. You may want to get some thinner spacers (they come in 0.75mm thickness) if you need to fine tune.
Stuart Black
Stuart Black
Liked 1,465 Times
Using a nickel is a GREAT idea. I always eyeballed it and often had to re-adjust. Thanks.
I received the new crank today, replaced it and everything works perfectly.
The old crank had a 6.5mm spacer (number 11 in the pdf link above) on the drive side which I haven't used anymore. On the other side I used an O-ring which I had lying around as a spacer.
Thanks all for your help!
Edit: And by the way, the new configuration feels so much better. Fast enough downhill but also quite capable uphill.
Liked 4,212 Times
Stuart Black
Stuart Black
Likes For cyccommute:
