Inner tube size
Inner tube size
Old 06-10-21, 09:32 AM
bikersworld
Inner tube size
HI All
My new trek domane SL5 has 700Cx32 21mm Presta valve inner tube, it is flat now and I want to replace but not finding anything in amazon of similar size (21mm), is there a suggestion on what alternate tube I could use? This is the first time I am changing innertubes so is little confused.
Thanks.
bikersworld is offline
Old 06-10-21, 09:35 AM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 790 Post(s)
Liked 393 Times in 262 Posts
Are you wondering about the presta valve size or tube size?
any tube 700X28 or 700X32 range will work fine with no issues. The presta valve size doesn't matter at all as long as it long enough to go through the rim to add are. So you can probably get always with anything from 20mm-anysize.
sdmc530 is offline
Old 06-10-21, 09:36 AM
bikersworld
Thanks
Old 06-10-21, 09:40 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1369 Post(s)
Liked 597 Times in 446 Posts
Get a patch kit-
https://www.amazon.com/Rema-Standard...84978276&psc=1
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 06-10-21, 09:49 AM
MudPie
MudPie's Avatar
Quoted: 49 Post(s)
Liked 46 Times in 34 Posts
Originally Posted by bikersworld View Post
HI All
Thanks.
If the 21mm refers to the valve length, that seems pretty short.. 21mm = less than an inch (0.82").
Where did you get the 21mm number from?
MudPie is offline
Old 06-10-21, 10:26 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 928 Post(s)
Liked 1,202 Times in 679 Posts
The shortest presta valve we stock is 48mm. 21 is stupid short, I've never in my life seen one that size.
cxwrench is online now
Likes For cxwrench:
Old 06-10-21, 12:12 PM
veganbikes
Clark W. Griswold
Quoted: 2457 Post(s)
Liked 1,485 Times in 991 Posts
Go down to your local shop, they probably will have tubes. Agreed with cxwrench that is a super short valve. We have some 32s but that is about as short as I could fathom. 48 is plenty short.
Tubes will also have a range so you just need to make sure you tire size falls within that range and has the correct valve and you are OK. Your local shop can easily help with that and if you aren't feeling frisky you can have them replace it and you can go grab a nice frosty cold one or get riding faster.
veganbikes is offline
Likes For veganbikes:
Old 06-10-21, 12:57 PM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91, '78 Raleigh Competition GS
Quoted: 3221 Post(s)
Liked 1,826 Times in 1,295 Posts
Tubes generally are made to fit a range of tire widths. Ideally, you want the tube to fit in the tire with no excess material to cause kinks and wrinkles which will just be wear to make a near future flat. And maybe a bumpy ride because air pressure isn't supporting the tire evenly.
On the other extreme, a tube that has to stretch and expand to fill the tire will tend to act like a balloon when punctured. So when flats happen, they'll be all at once instead of slow leaks that give you time to pick where you want to stop.
Iride01 is offline
Old 06-10-21, 01:39 PM
VicBC_Biker
Quoted: 110 Post(s)
Liked 69 Times in 51 Posts
Lots of excellent advice in the posts above.
Sometimes there are 'overlapping' size ranges in tubes.
For example, Continental tubes on one website are listed in 25-32 mm and 32-42 and 32-47 sizes.
For a 32 mm tire, for example, I'd pick the smaller tube option as it seems to reduce my chances of damaging the tube when I install it
Damaging a tube while I'm installing it in the basement shop isn't a big deal, but I did that once at the roadside and it was irritating.
VicBC_Biker is offline
Old 06-10-21, 02:37 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 811 Post(s)
Liked 597 Times in 355 Posts
The 21 mm is the width of the rim. This number has little to do with the size of the inner tube. You'll want to choose a tube size appropriate to your tire size, i.e. in your case, 32 mm. The advice above to get a patch kit is excellent. Patching is reliable and quick; much quicker than trying to find a new tube.
From the Trek website:
Rim: Bontrager Affinity Disc, Tubeless Ready, 24-hole, 21mm width, presta valve
Tire: Bontrager R1 Hard-Case Lite, wire bead, 60 tpi, 700x32c
Max tire size 38c
Moe Zhoost is offline
Likes For Moe Zhoost:
