Why screw-on versus circlip-style single-speed sprockets?
Old 06-22-21, 11:04 AM
Trakhak
Quoted: 958 Post(s)
Liked 757 Times in 442 Posts
A current thread where someone is debating modifying the gearing on a cruiser bike (by changing either the chainring or the sprocket) got me thinking. Why are threaded hubs the standard for single speed and track versus the hubs that take circlip-style single-speed sprockets?
Cheap 1/8" coaster-brake/circlip-style sprockets are available in a wider ranges of tooth counts than screw-on sprockets, and interchanging them requires only one non-specialized tool (e.g., a flat-blade screwdriver or the equivalent) and almost no effort versus the need for a lockring wrench, a chain tool, and lot of grunting.
I've been riding fixed-gear bikes since 1964, and I don't know why it never occurred to me before to question the logic of using screw-on sprockets that become progressively harder to remove the more you ride the bike. At nearly 70, I find that my arms and legs are weakening at nearly identical rates, such that I can still unscrew the sprocket, although just barely, but I wouldn't be averse to taking arm strength out of the equation.
I know that there are adapters available to install a slide-on sprocket plus spacers on a freehub, but there should be a high-quality fixed-gear (or single-speed) hub with the same mounting system.
Trakhak is online now
Old 06-22-21, 02:54 PM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 415 Post(s)
Liked 1,031 Times in 451 Posts
For singlespeed hubs with a screw-on freewheel, just put the FW tool in a vice (prongs facing up), lower the freehub onto the prongs, and turn the wheel like you're driving a bus. The wheel diameter gives you plenty of leverage to easily dislodge the FW.
For a fixed gear, I wouldn't trust a snap ring over a reverse-threaded lockring, especially if I was riding brakeless. I've seen too many coaster brake cogs develop play in them, and those snap rings are just cheap spring metal.
Breaking a threaded fixed cog free is usually just a matter of using a long enough lever.
Rolla is offline
Old 06-22-21, 03:04 PM
Russ Roth
Quoted: 641 Post(s)
Liked 498 Times in 378 Posts
White industries uses a spline style cog on their fixed gear and miche sells an adapter that you screw on that then takes splined cogs. If I start doing well enough to justify it I might build myself a set of the WI hubs to some light carbon rims for a faster wheelset, kinda like the idea of easy swapping.
Russ Roth is offline
Old 06-22-21, 03:07 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2684 Post(s)
Liked 1,395 Times in 866 Posts
I think it is mostly tradition. Double-threading of track hubs for a sprocket and lockring is an archaic kludge. There are modern track hubs from White Industries, Halo, and possibly others that use a splined sprocket retained by a standard right-hand thread lockring.
JohnDThompson is offline
Likes For JohnDThompson:
Old 06-22-21, 07:25 PM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 29 frames + 74 wheels
Quoted: 934 Post(s)
Liked 279 Times in 163 Posts
You can also just clamp the handle of the chainwhip in a bench vise, place the fixed cog in the chainwhip and turn the wheel. That's what I do when I can't remove a cog directly with the chainwhip.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv View Post
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Likes For TejanoTrackie:
