Bike tire width
Old 06-24-21, 08:31 AM
nrsmd
Quoted: 29 Post(s)
Bike tire width
It seems intuitive that thinner tires should travel faster than wider tires, but maybe not.
What do you recommend for a road bike (700C) tire width and air pressure?
nrsmd is offline
Old 06-24-21, 08:38 AM
scottfsmith
I like bike
scottfsmith's Avatar
Bikes: Roubaix Comp 2020
Quoted: 121 Post(s)
Liked 115 Times in 75 Posts
Here are a couple fairly recent threads on this topic.
https://www.bikeforums.net/road-cycl...s-30-32-a.html
https://www.bikeforums.net/general-cycling-discussion/1160004-what-s-optimal-tire-width-maximum-speed-roads.html
https://www.bikeforums.net/road-cycling/1231582-rolling-resistance.html
scottfsmith is offline
Likes For scottfsmith:
Old 06-24-21, 10:55 AM
VicBC_Biker
Quoted: 110 Post(s)
Liked 69 Times in 51 Posts
If you are asking because you have a road bike, the first step is do do some measuring to find the maximum size tire that can fit in your frame (chainstays, fork). You need at least 3-4 mm clearance, according to the info I got when I put larger tires on my bike.
NB: maximum inflated tire width doesn't necessarily match the published width number... i.e. a '28 mm' tire could inflate to 30 mm or 26, depending on the brand and also the rim width.
VicBC_Biker is offline
Likes For VicBC_Biker:
Old 06-24-21, 12:05 PM
veganbikes
Clark W. Griswold
Quoted: 2457 Post(s)
Liked 1,487 Times in 993 Posts
Vibration given off by narrower tires feels like speed but may not be faster. Go with the widest tire you can fit if a road/cross bike and if a fat bike you are riding not on sand and snow go with the skinniest tire your rim can handle.
veganbikes is offline
Old 06-24-21, 12:09 PM
BikingViking793
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 2010 Raleigh Talus 3.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour
Quoted: 145 Post(s)
Liked 54 Times in 44 Posts
Wider tires are more comfortable. Go over the bumps faster.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist Ė The goal here is to help you keep cycling on a budget.
BikingViking793 is offline
Likes For BikingViking793:
Old 06-24-21, 12:29 PM
ClydeClydeson
Quoted: 299 Post(s)
Liked 442 Times in 264 Posts
All other things being equal, wider tires have similar or less rolling resistance caused by flex in the casing.
All other things being equal, wider tires are a bit heavier than the same tire in a narrower width.
These considerations are generally true when looking at the same model tire in different widths. However, if comparing two tires that are not the same make and model in different widths, often wider tires are the heavier and thicker and stiffer type which roll more slowly, while it is easier to find narrower tires with thin and supple casings which roll better.
Depending on how closely your tire width matches your rim width, a wider tire may have more aerodynamic resistance at high speeds. A big mismatch in rim/tire width (so the tire mounted on the narrow rim has an 'omega' shaped cross section will generally have more aerodynamic resistance than a rim/tire combo that are close to the same width.
A wider tire will almost always be faster on rough or loose surfaces. A wider tire at a lower pressure will glide over surface imperfections, while a higher pressure narrow tire will tend to bounce you and your bike up and down, which is a loss of forward momentum. On soft surfaces a narrow tire will tend to carve a deeper groove while wider tires will be more likely to float on top, which uses less energy.
The great thing about tires is that they are a 'wear item', so you can try a new pair every season or so, or pop new ones on and keep the removed ones as spares or for riding different conditions. I like to take the perspective that riding enough to wear out a set of tires deserves a reward, and I reward myself with a new set of tires!
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 06-24-21, 12:34 PM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 435 Post(s)
Liked 1,057 Times in 462 Posts
28mm minimum width for me. If the bike won't take that, I'd get a different bike.
Rolla is offline
Likes For Rolla:
Old 06-24-21, 12:45 PM
Flatforkcrown
Flatforkcrown's Avatar
Bikes: N+1
Quoted: 51 Post(s)
Liked 175 Times in 80 Posts
Iíd go with the biggest tire your frame will fit, and the most supple tire you can get in that size. On my bike that will fit them the 30mm vittoria corsa tubulars are heavenly.
Flatforkcrown is online now
Likes For Flatforkcrown:
Old 06-24-21, 06:32 PM
icemilkcoffee
Quoted: 446 Post(s)
Liked 317 Times in 196 Posts
The simplest rule of thumb is : Fat rider Fat tire. Skinny rider Skinny tire.
For an explanation, consult this chart:
icemilkcoffee is online now
Old 06-25-21, 04:54 AM
PeteHski
PeteHski's Avatar
Quoted: 755 Post(s)
Liked 735 Times in 488 Posts
There is not enough info here to make any specific recommendation. We need to know what frame clearance you have (older bikes often donít have enough room for modern wider tyres). Also need to know your weight and how smooth your road surfaces are.
The general trend is clearly toward wider road tyres. 28 mm is now a very common width compared to 23 mm a decade ago. If your roads are rough then 32 mm is a good choice too. Typical pressures are now in the 60-80 psi range with these wider, higher volume tyres.
PeteHski is offline
Old 06-25-21, 05:23 AM
wolfchild
wolfchild's Avatar
Quoted: 2297 Post(s)
Liked 1,099 Times in 554 Posts
Minimum of 32 mm...I won't purchase any tires smaller than 32mm....My favorite size for road and off road is something around 45mm.
wolfchild is offline
Likes For wolfchild:
Old 06-25-21, 07:23 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3875 Post(s)
Liked 1,062 Times in 742 Posts
fwiw - my road bike has 25mm tires, I weight 225lbs + bike & use approx 100-110 psi rear & 90-100 psi front. by trial & error this work for me for our local roads
rumrunn6 is offline
Old 06-25-21, 07:25 AM
pdlamb
Quoted: 1616 Post(s)
Liked 841 Times in 523 Posts
The big assumption here is that all other things are equal. Once you start looking carefully, most (not all) tire models start picking up sidewall stiffness as the width increases, usually between 25 and 32 mm wide. That's why tires wider than 25 or so often have higher rolling resistance than narrower tires. The exceptions are usually pricey.
Many road bikes older than five years are limited as to the size tire they'll take, often maxing out at 25. In that case, ride the widest tire that'll fit. Otherwise, you'll have to try a few and pick your own optimum combination of width, ride, price, and puncture resistance.
pdlamb is offline
Old 06-25-21, 07:37 AM
ClydeClydeson
Quoted: 299 Post(s)
I don't know this to be generally untrue, but there are definitely tires available in multiple widths that do not follow your description. I am a big fan of Panaracer Pasela tires, which are not expensive (although not easy to find these days), and the larger widths are definitely made with the same construction as the smaller widths. To be fair, there just aren't that many tires made in the same model that come in widths from below 30mm to above 30mm, and lightweight construction wider tires are more rare than lightweight construction narrow tires.
ANyhoo, here is a rolling test of one particular model available in many widths. They even publish stats like sidewall and tread thickness, and the wide tires seem to be very similar, if not made the same as the narrow tires. The widest tire has the lowest RR and the narrowest tire has the highest RR.
https://www.bicyclerollingresistance...000-comparison
Old 06-25-21, 07:45 AM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 545 Post(s)
Liked 192 Times in 132 Posts
Pretty funny. Berton's calc page tells me I should be running about 112PSI in the rear and about 91 in the front. This absolutely flies in the face of all those "experts" who claim I should be running pressures much, much lower! I use trial and error to arrive at a comfortable and usable pressure, as always. For my tires and wheels I ended up at 95/100 front/rear. Just because I like the way it feels.
dmanthree is offline
Old 06-25-21, 07:52 AM
livedarklions
Racerboyz' b'crat
livedarklions's Avatar
Bikes: Serotta Atlanta; 1994 Specialized Allez Pro; Giant OCR A1; SOMA Double Cross Disc
Quoted: 5068 Post(s)
Liked 4,365 Times in 2,458 Posts
What's fun is you can still find sources on the interwebs referring to 25 mm as "wide" tires.
livedarklions is offline
Likes For livedarklions:
Old 06-25-21, 08:25 AM
70sSanO
70sSanO's Avatar
Quoted: 1142 Post(s)
Liked 973 Times in 642 Posts
I think it is safe to say that a wider tire is more comfortable than a narrower tire.
As far as being faster, I think there are other variables that impact speed more than just tire width.
Personally, for a lot on non-competitive riders, I think dollars spent per mile probably has a greater influence on tire selection than getting the fastest tire available.
I should add that flats per ride might have a greater influence than the optimum rolling resistance. Fixing a flat turns the fastest tire into the slowest.
Everything is a compromise.
John
70sSanO is online now
Likes For 70sSanO:
Old 06-25-21, 09:26 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1558 Post(s)
Liked 558 Times in 325 Posts
John
That's what I think too. There's lots more to it than just tire width and air pressure.
Retro Grouch is offline
Likes For Retro Grouch:
Old 06-25-21, 10:02 AM
Cakonopka
Cakonopka's Avatar
Bikes: Cube Attain Pro 2020
I had 25s on my old bike, newer bike has 28s and omg they are much comfier. Would never go back. And give me more confidence on the road!
Cakonopka is offline
Old 06-25-21, 11:18 AM
livedarklions
Racerboyz' b'crat
John
I can notice a difference in speed based on the tread of the tire, but based on width is not noticeable at all. The speed differences are so negligible that I agree with you that except for racers, other considerations are generally going to be way more important. I like the way you sliced up the calculations.
I like the Conti GPs (4000 and 5000) because they are smooth (which I prefer) and durable.
Old 06-25-21, 11:57 AM
icemilkcoffee
Quoted: 446 Post(s)
Frankly if you have to exceed 90psi, it's probably time to consider moving up to the next wider tire. When I am rolling on 25mm tires, 90psi feels OK and 100psi feels like my dental fillings are going to come off.
Old 06-25-21, 12:17 PM
ksryder
Bikes: yes
Quoted: 1276 Post(s)
Liked 628 Times in 324 Posts
Berto's chart has been obsolete for years and people still trot it out like it's definitive fact whenever this comes up.
ksryder is offline
Likes For ksryder:
Old 06-25-21, 12:19 PM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 545 Post(s)
Lots of variables involved. Wheel type, width, frame material and type, rider weight, etc. I use what works for me and my ride, a 2017 Roubaix that absorbs road shock really well.
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 272 Post(s)
Liked 404 Times in 266 Posts
Yeah, I really have no use for anything smaller than 32. All my rides include at least some trail miles, so that is the bare minimum. I run front and rear the same and lately at 60 psi though Iíve run lower, too. Anything narrower with higher pressures would be less comfortable and less fun.
Otto
ofajen is online now
Old 06-25-21, 12:20 PM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 545 Post(s)
That was my point; there is NO definitive source when it comes to tire pressure. Until everyone is the same weight, riding the same wheels, tires, bikes, and road surfaces. Until then, just use your brain and experience to choose what works for you.
Likes For dmanthree:
