Hydraulic brakes need to be bled?
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
For the last month or so, the front brake lever on my Kona has been inching closer to the bar. @ rest, the lever is closer to the bar than it should be. Now, when engaged, it almost bottoms out. Is it a leak? I cant see a leak. It works, but lever is too close. Rear brake is fine. Brakes have never been serviced; 5K miles at most. There is no noise. pls advise
My sram rivals tend to have less travel on the first few rides after a pad replacement, and then the travel returns to normal, which to be honest, is too close to the bars for my taste, but it can't be adjusted.
Probably air in the line. Air compresses, liquid doesn't.
Most manufacturers suggest bleeding approximately every year. 5k sounds like a totally normal interval for bleeding. That's a couplea chains for most people, a few sets of pads, etc. If you're mechanically inclined, it's not amazingly hard.
https://www.universalcycles.com/shop...s.php?id=88214 would be right for your Kona's Tektro brakes. Weird it doesn't include a bleed block, but you can just put a 10mm hex wrench into the caliper.
Quoted: 623 Post(s)
Liked 396 Times
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
If the lever isn't returning to normal "open" position, there may be a mechanical or hydraulic blockage, maybe in the master cylinder. I agree, the first step would be normal service--replace fluid and bleed. Clean and check operation of the master cylinder without hydraulic pressure. Clean and check the wheel caliper pistons and seals as well. Disclosure: I've worked on way more auto brakes than bike brakes.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 6187 Post(s)
Liked 4,803 Times
Have you checked both the disc and pads for wear? If you've worn them way beyond limits then maybe a problem just adding more hydraulic fluid will only make worse.
Likes For epnnf:
Likes For epnnf:
Quoted: 268 Post(s)
Liked 80 Times
PS update: I think the caliper is leaking.
After four rides (bout 200mi), the front brake lever is feeling spongy. Im not gonna ride it again. I looked around the other calipers, and they are dusty. The front caliper is not dusty, but I cant call it damp either. OK, maybe a tiny bit damp. How to detect a leaky caliper? I cannot see a leak. I assume the only fix is replace (upgrade? ) the caliper, lever & hose? btw, when I clean the disc, (using alcohol pads) the outside is very dirty.
Bikes: 2021 Trek Verve 2 Disk
Quoted: 130 Post(s)
Liked 119 Times
