42c gravel tire on 19c wheel, good or bad idea?
Old 06-29-21, 02:31 PM
rbrides
Curmudgeon
rbrides's Avatar
Bikes: Specialized Diverge Comp
Quoted: 66 Post(s)
Liked 8 Times in 8 Posts
42mm gravel tire on 19mm wheel, good or bad idea?
I have a set of DT Swiss r470 tubeless wheels and want to mount Specialized’s Rhombus 42mm tire for my gravel bike to do bike packing.
dtswiss’s web site says this is a possible combination with a recommended air pressure (see link).
What are the pros and cons of this wheel width/tire width combination?
one pro that motivates me; not buying another set of wheels.
https://www.dtswiss.com/pmt/00/00/00...WEB_ZZ_001.pdf
Last edited by rbrides; 07-01-21 at 12:33 PM. Reason: typos in the title. Change 42c and 19c to 42mm and 19mm
rbrides is offline
Old 06-29-21, 03:17 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 936 Post(s)
Liked 1,207 Times in 681 Posts
42mm tire on a 19mm rim. The "C" goes with the 700. And yes, it'll be fine on that rim. You probably won't be able to use the lower pressure you'd get away with on a wider rim, but it will for sure work.
cxwrench is offline
Likes For cxwrench:
Old 06-29-21, 04:56 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2578 Post(s)
Liked 2,848 Times in 1,516 Posts
Originally Posted by rbrides View Post
I have a set of DT Swiss r470 tubeless wheels and want to mount Specialized’s Rhombus 42c tire for my gravel bike to do bike packing.
I doubt you'll get any better informed guidance than that, even here on BF!
shelbyfv is offline
Likes For shelbyfv:
Old 06-29-21, 06:06 PM
Ironfish653
Dirty Heathen
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 Softride
Quoted: 561 Post(s)
Liked 297 Times in 204 Posts
That was actually a pretty normal XC setup in the 26” era; 1.95” tires on 17-19mm rims.
You can’t go crazy low with the air pressure (although I guess tubeless would mitigate that) but that’s more to prevent pinch flats, than unseating the beads.
Ironfish653 is online now
Likes For Ironfish653:
Old 06-29-21, 07:43 PM
well biked
biked well
well biked's Avatar
Quoted: 105 Post(s)
Liked 69 Times in 41 Posts
+1
My all-time favorite setup back then was Hutchinson Python Airlites in 26" x 2.0" mounted on Mavic X517's. When Stan's conversion kits became available, it was no problem to go tubeless with that same setup, either. I ran them at sub-30psi once tubeless happened.
well biked is offline
Old 06-30-21, 02:32 AM
Lazyass
Quoted: 2309 Post(s)
Liked 429 Times in 272 Posts
A couple of years ago I bought a new Swobo Accomplice single speed bike. It came with Alex AT480 622x15 rims and 42mm Kenda Euro Trek tires. The rims measure 19mm outer. An odd choice and you could tell the tire was too wide for them but it worked fine. I did swap to smaller tires after a few rides but I had planned that anyway.
Lazyass is offline
Likes For Lazyass:
Old 06-30-21, 04:10 AM
Ironfish653
Dirty Heathen
Quoted: 561 Post(s)
Originally Posted by Lazyass View Post
The rims measure 19mm outer. An odd choice for a road bike and you could tell the tire was too wide for BikeForums but it worked fine. Because it turns out Sheldon wasn’t right about everything
ftfy
Old 06-30-21, 06:13 PM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 66 Post(s)
DOH! My bad on the typo!
rbrides is offline
