Dangerous Dan's Road Tubeless Screw You Sealing Demonstration
Old 07-01-21, 03:44 PM
DangerousDanR
Bikes: Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 125 Post(s)
Liked 127 Times in 71 Posts
As promised, when I needed to change a tire I would do a small experiment to demonstrate how well or poorly a road tubeless tire will seal up after being punctured with s drywall screw. Except I decided to use a cement backer board screw because that was the bucket that was closest at hand.
I use Orange Seal because they make a winter version that is still a liquid in fairly cold temperatures. I am not sure what flavor of Orange Seal was in the tire to begin with, but I topped it up with 50 ml of Orange Seal Endurance seal.
With the preliminaries out of the way, let me introduce the guest of honor. This is a Conti GP5000 TL with cord showing where there should be tread. The tires were inflated to the setting I use on the tandem, 90 PSIG.
The first test was a single screw directly into the tread...
When the screw was removed and the tire was spun, the stream of sealant fizzled out fairly quickly, about 20 seconds. The result was an orange spot on the tire and a pressure reading of 61.5 PSIG, so while we could ride on that we would probably stop and pump it up.
That was too easy. The main event was the infamous double puncture through tread and sidewall. I had to slightly deflate the tire to make that happen. Then I ran the pressure back up to 90 PSIG with the screw in place
This pair took a lot longer to seal, but when the spitting stopped the gauge read 14.5 PSIG. Not enough to ride, but I pumped it up to 90 PSIG and both the sidewall and tread punctures remained sealed.
So, would I knowingly ride on this tire? If I had to, yes. But since it was going in the bin anyway, to the bin it went. The replacement was fairly easy to put on the rim.
Good tools help make it an easy job. With my two spare hands the tire was on the rim and holding air pressure without sealant in about 5 minutes.
Am I going to stick with road tubeless tires? Of course. Yes, they are harder to mount (at least GP5000s are), but that tire ran a lot of miles on some very bad roads with zero flats. For anyone who wants to gloat and say "but you don't have a work stand, those clamps and a compressor when you are touring", well yeah... but so what. I have also not had any punctures that I was aware of with the GP5000s but not the previous Schwalbe Marathon tires, which are a pretty good touring tire.
Last edited by DangerousDanR; 07-01-21 at 03:47 PM. Reason: remove duplicate photo
DangerousDanR is online now
Old 07-01-21, 03:53 PM
tomato coupe
Quoted: 1436 Post(s)
Liked 2,139 Times in 886 Posts
Okay. What did we learn from this?
tomato coupe is offline
Likes For tomato coupe:
Old 07-01-21, 04:11 PM
DangerousDanR
Quoted: 125 Post(s)
My intent was to demonstrate that road tubeless and good sealant is not as fragile as some people like to say.
I have had 4 tubeless fails. All involved failure of the sidewall. Three of them were large slices in Schwalbe Pro One tubeless while commuting. I walked all three home. One was a Conti GP5000 which had the bead separate from the rest of the tire. I also walked it home. In all four cases, the tire stayed seated on the rim. I consider that to be a big safety feature.
If I ever have to repair a tubeless tire on the road I will be stuffing a tube in it, so I can inflate it with my hand pump. At home, I have a compressor so I use it.
Old 07-01-21, 04:24 PM
tomato coupe
People cite different reasons why they don't like tubeless, but fragility is not one of the common reasons.
And yet, this makes tubeless seem kind of ... fragile.
Old 07-01-21, 05:57 PM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 425 Post(s)
Liked 227 Times in 138 Posts
Over the past couple years I’ve been switching to tubeless on most of my bikes. Sometimes they are a pain to set up initially. I’m getting better at it and usually don’t have much trouble now.
For me, the biggest reason (and the only really compelling one) is puncture resistance. Or more accurately, puncture self-sealing properties.
There are are other pros and cons that have been discussed ad nauseum. For me it comes down to this: I used to get a lot of flats. The only way around this seemed to be using super heavy tires, super heavy tubes, or other heavy, clunky devices to keep thorns from getting through. Or usually a combination of two or three of these stupid solutions. I live in a desert, and we have a lot of goat head thorns. These were the cause of 90% of my flats, and there’s almost no way to avoid picking them up frequently.
On all my tubeless tires, the thorns are not even a concern. If for no other reason than this, tubeless setup is a totally worthwhile investment for me.
Thanks for the fun test/demonstration, DangerousDanR
Broctoon is offline
Likes For Broctoon:
Old 07-01-21, 06:12 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2568 Post(s)
Liked 2,823 Times in 1,508 Posts
I'm impressed the Orange Seal filled holes that large.
shelbyfv is offline
Old 07-01-21, 06:17 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3913 Post(s)
Liked 961 Times in 643 Posts
I'm starting to think that if there's a way to mold hardened Orange Seal into a complete tire, the industry might be on to something.
Sy Reene is offline
Old 07-01-21, 07:43 PM
Chandne
Bikes: 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Yeti SB4.5, Pivot Shuttle
Quoted: 326 Post(s)
Liked 49 Times in 34 Posts
I like Orange Seal the best. This is a good test. Thanks Dan! One nice thing about road tubeless is that if you get a puncture on a fast twisty downhill, the chances of crashing are reduced. I'm waiting for my Zipps and will convert to tubeless when they come in.
Chandne is offline
Old 07-01-21, 09:17 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1361 Post(s)
Liked 592 Times in 417 Posts
Although, when you ride over a screw, it's just punched through the tyre like a nail, and I presume that was too difficult to reproduce for a test, right?
The hole left by a screwed-in screw versus a nailed-in screw is gonna be a lot tidier, I bet.
Kimmo is offline
Old 07-01-21, 09:30 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 15178 Post(s)
Liked 6,331 Times in 3,587 Posts
I got two flat Pro Ones, both sidewall cuts, almost back to back.
Seattle Forrest is offline
Old 07-01-21, 09:33 PM
rsbob
Sniveling Weasel
Bikes: Orbea Orca, Fondriest Racing, Bianchi Trofeo, Bianchi Infinito, Schwinn Varsity, Trek mtn
Quoted: 530 Post(s)
Liked 787 Times in 497 Posts
Picked this up last week, lost 3 lbs pressure. After spending 10 seconds checking it out, I rode it home 4 miles before extraction and plugging. Conti 5000 TL with Orange sealant. Plugged it and took on a 40 mile ride with zero pressure lost. Tubeless are a marvel. No issue seating on my Nir rims.
Rick S
“He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche. “An argument based reasoned fact, beats one based on emotional rantings every time” Anon
rsbob is offline
Likes For rsbob:
Old 07-02-21, 07:34 AM
WhyFi
WhyFi's Avatar
Quoted: 17345 Post(s)
Liked 6,059 Times in 3,129 Posts
People that use OS (and some other good sealants) have been saying this for years - it works on relatively bad punctures and it holds at road pressures. The shitshow caused by early adopters carrying over Stan's from the MTB world, and the subsequent parroting of "tubeless doesn't work for road!" has been tough to overcome.
WhyFi is online now
Old 07-02-21, 08:38 AM
himespau
himespau's Avatar
Quoted: 2824 Post(s)
Liked 1,374 Times in 812 Posts
So, is it better to remove the item right away? I'd be afraid that, if I left the screw/nail in there, it would damage the rim.
himespau is offline
Old 07-02-21, 08:49 AM
WhyFi
WhyFi's Avatar
Yeah, definitely. I don't see an upside to leaving something in, but there's certainly downside, like rim damage or making the tire damage worse. I suppose that, if you're not too confident in your sealant, you might leave something in until you're in a better location to deal with it, but I don't think that I'd personally go any further than the next shady spot that's clear of the traffic lane.
WhyFi is online now
Old 07-02-21, 10:43 AM
DangerousDanR
Quoted: 125 Post(s)
Riding the tandem to puncture the worn out rear tire only would have been a trick that I didn't want to attempt, so I put those screws in with a screw gun. They spun in the tire when they bottomed out. Backerboard screws have very sharp threads and the holes were about what you would expect if I had used a drill bit of that diameter instead.
When I first used road tubeless I had a lot of trouble with leaking in two places:
1) valve leaks
2) tape failures
Using the Orange Seal has eliminated both.
And mostly I did this because I told DiabloScott that I would:
Maybe. Convince me. How would I have handled this situation had I a tubeless system?
1. Put a tube in a tubeless tire - might work but messy and a hassle.
2. Attempt to repair with more sealant - unlikely to be successful
3. Call for a ride.
As it was, I changed the tube and put in a dollar bill boot and rode home. Put on a new tire when I got back.
No, this is not a "normal" flat, but it's valid to include it in the mix.
I use sealant in my tubular tires, because "why not?". But I still bring a spare.
I offered that I would run a drywall screw through a tubeless tire that was wearing out and voiced my opinion that the tire would hold air. The answer to this question is that at least one GP5000 32X700C that was completely worn out after two years on a tandem did indeed hold air when some fool went at it twice with a screw gun and backer board screws.
So DS...
Thanks. I will eat my words and soften my position if that's true.
Do you like them baked or fried?
Likes For DangerousDanR:
Old 07-02-21, 02:35 PM
tomato coupe
Have you ridden on the wheels after the screw experiment?
On edit: Never mind ... I forgot that you installed new tires.
Old 07-02-21, 02:37 PM
tomato coupe
Clearly, one of the problems with Orange Seal is that it turns your hubs, nipples, and valves orange.
Old 07-02-21, 04:09 PM
DangerousDanR
Quoted: 125 Post(s)
I did not, but it held 90 PSI for about 10 minutes before I swapped the tire. I have absolutely no doubt that the punctures would not have prevented me from using that tire.
Old 07-02-21, 04:53 PM
tomato coupe
Holding pressure for 10 minutes might not be enough. On several occasions I've had punctures on my road bike that sealed up and got me home without any problems. (Other than the mess, of course.) They seemed fine when pumped back up to normal pressure, however, the puncture re-opened within a mile when I rode on them. So, although they were rideable with sealant alone at low pressure, they needed to be plugged to work at normal pressure. YMMV.
Old 07-02-21, 06:07 PM
WhyFi
WhyFi's Avatar
I've only had a couple punctures open back up and they were both right on the edge of that 5-6mm limit of Orange Seal. Both rode fine for hundreds of miles until smacked just right by a bridge seam and pothole, respectively. This was at 70-75psi, though, so the puncture size threshold might be a little smaller at 90.
WhyFi is online now
Old 07-02-21, 07:56 PM
rsbob
Sniveling Weasel
Quoted: 530 Post(s)
That was my concern as well and checked the tire pressure every mile or so to make sure the rim was not being damaged. If I had lost considerable pressure, I would have removed the nail immediately and plugged it road-side. Since I had never plugged a tubeless before, I wanted to do my trial run at home. After plugging which was far easier than the old way of replacing a tube or patching, I would not hesitate to pull the nail/screw and plug on the road.
Rick S
rsbob is offline
Old 07-03-21, 06:52 AM
PeteHski
PeteHski's Avatar
Quoted: 739 Post(s)
Liked 720 Times in 477 Posts
I've been using Pirelli TLR tyres recently (Cinuturato for training rides and a couple of local Sportives and now P-Zero Race for faster summer Sportives). Both these tyres are super-easy to fit on my Giant SLR carbon rims without tools, not even a plastic tyre lever. Seating them does require a boost track pump (or compressor), so that's the only minor downside for anyone with only a regular track pump. Just out of curiosity I did try to seat them with a normal track pump and failed miserably. I haven't had to plug one of these tyres yet, but my experience of plugging mtb tubeless has been 100% successful over many years. Which is why I was always keen to go road tubeless. I used to regularly get flats with tubes (maybe once or twice a month) and with tubeless I now don't. I'm 2 years in now with road tubeless and yet to experience a single flat. I almost want to get a flat just so I can test my Dynaplug repair tool.
PeteHski is offline
