pino morroni track bike
Old 07-05-21, 04:06 PM
konakai
Quoted: 7 Post(s)
Liked 18 Times in 7 Posts
hello could anyone share any information or back story on this bike. I'm mainly interested in old wood rim racers and old pacing bikes. I'm not too versed on the newer stuff. I am somewhat familiar with the mad genius of pino morroni. there's got to be a story behind this bike. sometimes the stories are as interesting as the bikes.....thanks in advance
konakai is offline
Old 07-05-21, 04:34 PM
Dylansbob
2k miles from the midwest
Dylansbob's Avatar
Quoted: 268 Post(s)
Liked 387 Times in 193 Posts
I've seen that style handlebar-to-forkcrown support only on Stayer bikes. Pretty wild.
Dylansbob is offline
Old 07-06-21, 08:14 AM
konakai
Quoted: 7 Post(s)
yea, the bike has a stayer or pacing vibe, with the extra rear bracing, stem support, smaller front wheel, and clearance to run with the fork reversed... still looking for a backstory on this bike. anyone with any info, I'm sure it's traded hands a time or two....thanks
konakai is offline
Old 07-06-21, 08:25 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022, '21 Tsunami SNM-100
Quoted: 1363 Post(s)
Liked 1,314 Times in 706 Posts
Oh my. I look at the stiffening elements and think that the builder expected a ton of power to be laid down, or, some riding surface irregularities that might cause impulse inputs at the hubs. Interesting.
Also the length of the rear stay openings suggests that substantial changes in gearing were anticipated.
I love it.
Phil_gretz is offline
Old 07-06-21, 10:08 AM
repechage
Quoted: 1960 Post(s)
Liked 800 Times in 620 Posts
Pino had definite ideas. I have seen some of these on other frames, this one has quite a number of them. The transverse tube eruptions in the main tubes are for stiffening torque tubes.
the added stays are interesting, would require A -B testing to decide on utility.
the long slots are not for gear accommodation but for his view that different tracks suggested different wheelbases.
the hubs are interesting- double ended threaded spokes- Magic would do this 15-20? Years later. Not shown are the probable nuts on the threaded spike nipples- wheel tensioned with the tire off, then the nut locks the spoke to provide support always.
he was an innovator.
Merckx used his ti stem for the Hour Record.
quite innovated there too, the steerer expander was buried deep in the quill. Shimano would use that concept ( albeit more complicated) on the AX stems.
repechage is offline
Old 07-06-21, 10:42 AM
konakai
Quoted: 7 Post(s)
thanks for the reply and info so far, some I already knew, some I didn't. interesting comment on the long rear drops to change wheelbase for different tracks. I would have never thought of that. still looking for info on this particular bike. there is and old Pic on classicrendevous of this bike
konakai is offline
Old 07-06-21, 10:54 AM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 207 Post(s)
Liked 134 Times in 98 Posts
the real detail is the stuff inside - Pino made bottom brackets, quick releases and other components.
Looks like this bike has the Pino stem and seatpost.
Is that bike for sale or on offer somewhere ?
there are probably less than 10 of those out there
mpetry912 is offline
Old 07-06-21, 11:58 AM
onyerleft
onyerleft's Avatar
Bikes: Pedaling for the Lord!
Quoted: 500 Post(s)
Liked 185 Times in 132 Posts
I can't tell you how much of a rare, great frame that Pino Morrino is! Although I would probably not want it for myself (too large.
onyerleft is offline
Old 07-06-21, 02:07 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1829 Post(s)
Liked 973 Times in 655 Posts
ooof!
clubman is offline
Old 07-06-21, 02:09 PM
repechage
Not sure on the seatpost, the unit I saw way back was kind of klunky, of magnesium. the cinelli saddle rails were flat stock with a series of holes for adjustment, no micro adjust, unless I was missing something.
No telling what he did later.
Old 07-06-21, 04:48 PM
clubman
Youngman Grand
clubman's Avatar
I want to know if those are Pino hubs with the spoke hub ends cut and threaded into the flanges. Tough build? Wouldn't that be a be-atch to true? Or easier. I'm confused
clubman is offline
Old 07-06-21, 04:56 PM
konakai
Quoted: 7 Post(s)
I'm pretty sure their pino hubs, like a previous poster said the spokes are nutted
konakai is offline
Old 07-06-21, 04:58 PM
clubman
Youngman Grand
clubman's Avatar
Ah, missed that. Still, superb.
clubman is offline
Old 07-06-21, 06:41 PM
repechage
On a track wheel set, wheels that are extra effort to service are not that outlandish.
Rarely did I need to true the track wheels up. Now, later when there was a mismatch in the surface between turn 3 & 4 at Encino, and Detroit...
Yeah more service.
Northbrook was smooth but a useless track for other than pursuiters, way too little banking.
The theory with the double ended threaded spokes was that the spoke at the bottom of the wheel would act as a thin column.
Old 07-06-21, 07:53 PM
clubman
Youngman Grand
clubman's Avatar
Looked up thin column stresses. Cool.
clubman is offline
Old 07-07-21, 05:12 AM
SJX426
SJX426's Avatar
Quoted: 1098 Post(s)
Liked 802 Times in 494 Posts
I don't know anything much about track or pursuit bikes. What are the holes in the main tubes used for?
SJX426 is offline
Old 07-07-21, 06:31 AM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 727 Post(s)
Liked 984 Times in 463 Posts
Pino had definite ideas. I have seen some of these on other frames, this one has quite a number of them. The transverse tube eruptionsin the main tubes are for stiffening torque tubes.
Yeah, I was wondering too.
thinktubes is offline
Old 07-07-21, 06:48 AM
konakai
Quoted: 7 Post(s)
I believe the stem and hubs are pino, but not the seat post, although there's a pino seat post or two on ebay....it's my bike
konakai is offline
Likes For konakai:
Old 07-07-21, 12:08 PM
SJX426
SJX426's Avatar
Whoosh! went right by me! Thanks
SJX426 is offline
Likes For SJX426:
Old 07-07-21, 07:35 PM
thinktubes
thinktubes's Avatar
Quoted: 727 Post(s)
Just don't ask me to explain it
Old 07-08-21, 06:56 AM
konakai
Quoted: 7 Post(s)
I appreciate the observations and the information. I was hoping for yea that was my bike, what do you want to know, or so and so owned it and was raced in LA LA land. I like the old, old stuff and the history behind it, if I can tie an old racer to a previous owner it excites me, especially if the rider was of some note. I thought since this bike was only 35 40 years old and pretty distinctive it wouldn't be too hard. I realize most people have no idea of pino morroni, just like pop brennan or Joe kopsky. once again thanks for looking it was 16 pounds of cool innovation at the time
konakai is offline
Old 09-06-21, 03:40 PM
konakai
Quoted: 7 Post(s)
I'll keep trying anyone remember this bike back in the day. looking for any history or information on it...thanks
konakai is offline
Old 09-07-21, 07:43 AM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1078 Post(s)
Liked 481 Times in 371 Posts
Have you tried checking in with CR to see who gave the photo(s) they've posted on their site?
Likewise, have you tried posting at CABE?
francophile is offline
Old 09-07-21, 11:05 AM
konakai
Quoted: 7 Post(s)
i havent tried cr, that's an idea but I doubt they would have a record of a year's old picture. tried the cabe, even face book, pino, telavio group which I thought was my best shot, no luck....thanks
konakai is offline
