Columbus SLX
Columbus SLX
Old 07-12-21, 08:48 AM
Erzulis Boat
Le Crocodile
Erzulis Boat's Avatar
Quoted: 370 Post(s)
Liked 787 Times in 311 Posts
Columbus SLX
I have been riding my 1990 Serotta (56x55.5) and it has the SLX tubeset.
The geometry isn't really any "tighter" than my SL bikes, but I swear it has a pretty harsh (really stiff) feel. Granted it's geometry/tires/wheels/saddle etc. but it's the first lugged steel bike that has felt this way besides my steel track bikes. It's really noticeable.
I could have sworn that the word on the street of yesteryear was that SLX was for lighter riders, SL the standard, and SP for the big guys.
Anyway, the helical internal ribs on the SLX were designed for what end again?
Erzulis Boat is offline
Old 07-12-21, 08:54 AM
SpeedofLite
SpeedofLite's Avatar
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,471 Times in 999 Posts
Your answer is here: https://www.bikeforums.net/classic-v...ise-steel.html
Check page 112 in the Butting section.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
SpeedofLite is offline
Old 07-12-21, 09:17 AM
Flatforkcrown
Flatforkcrown's Avatar
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times in 159 Posts
It’s likely not the tubing. I have a SLX De Rosa and it’s not harsh riding at all.
Flatforkcrown is offline
Old 07-12-21, 09:22 AM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
I like bikes that can take a 28 c or a 32c tire. In terms of whether a bike rides “harsh” or not, I think tires matter more than the tubing.
bikemig is offline
Likes For bikemig:
Old 07-12-21, 09:33 AM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
I think it was for light riders because the really thin tubing might not hold up to a bigger/heavier rider. I don't know if that's the case.
seypat is offline
Old 07-12-21, 09:37 AM
bikingshearer
Crawlin' up, flyin' down
bikingshearer's Avatar
Quoted: 1025 Post(s)
Liked 2,525 Times in 1,055 Posts
SL, SP, SLX and SPX are all the same steel, or at least they were into the 1980s, maybe later. SLX is SL with added helical ribs at tube ends for added stiffness at the joints. SP is SL with thicker tube walls. SPX is SP plus the ribs. An SLX tubeset is heavier than an SL tubeset, an SPX set is heavier than an SP set.
If you have a Columbus -tubed frame from the 1960s up to some point in the 1970s, the sticker just says "Columbus," but it could have been the thinner/standard walled tubes (what came to be known as SL) or the thicker walled tubes (what came to be known as SP), depending on the builder's preferences for the particular frame.
bikingshearer is offline
Likes For bikingshearer:
Old 07-12-21, 09:48 AM
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
SL tubed bikes with the early stamped front derailleur braze on mount, flexed a bunch. As a mechanic, I did not like it.
Soon enough, SLX assisted it taming the distortion.
And then the mounts evolved into investment cast, the attachment wrapping around the tube more.
Problem addressed.
repechage is offline
Old 07-12-21, 10:27 AM
Erzulis Boat
Le Crocodile
Quoted: 370 Post(s)
Definitely a different lugged steel ride. I didn't have any preconceived notions with this frame, so the stiff and "dead" feel is an honest opinion. It rides very fast, and I am having a good time riding it, but boy, it has some unique qualities. I should track down the specified geometry.
My SOMEC in SL (56.5x54) with the ridiculously short wheelbase is less stiff by quite a bit.
Evidently Columbus actually had something going with the SLX/SPX tubesets besides a marketing gimmick.
Old 07-12-21, 10:32 AM
Doug Fattic
framebuilder
Quoted: 615 Post(s)
Liked 1,914 Times in 655 Posts
It is possible that your down tube (and maybe even the seat tube and top tube) were SPX instead of SLX. SL wasn't all that stiff although both the down and top tube were .9/.6/.9. It isn't uncommon to have a slightly lighter top tube with other brands. A SLX frame alone (no fork) would weigh around 1900 grams + - (I'm going on memory) while SPX would be 2100 or 2200? That is one way to tell. A tubing sticker on the frame isn't always perfectly accurate.
Doug Fattic is offline
Old 07-12-21, 10:36 AM
himespau
himespau's Avatar
Quoted: 4233 Post(s)
Liked 2,948 Times in 1,807 Posts
It was my understanding that SLX "rifling" should help with BB flex (in theory anyway), but, since it didn't extend up the whole tube and wasn't found in all tubes, probably wouldn't make the ride feel more "harsh" by itself. I'm sure that others with more experience will explain why my understanding is completely incorrect.
himespau is offline
Old 07-12-21, 11:02 AM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 985 Post(s)
Liked 2,378 Times in 891 Posts
What do you weigh? I'm 6' 2" 205 lbs. and SLX feels "springy" to me (in a good way!) - 57cm frame/700x23 tires/Illinois roads
thinktubes is offline
Old 07-12-21, 12:00 PM
Erzulis Boat
Le Crocodile
Quoted: 370 Post(s)
I'm 191, and running Vittoria Corsa 700x25 @ 90 PSI like just about all my other vintage bikes. My 531 Paramount for example is night and day different with the same tires.
Likes For Erzulis Boat:
Old 07-12-21, 12:23 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2155 Post(s)
Liked 3,403 Times in 1,204 Posts
Pure opinion: for the most part, high end frames are made/assembled by humans, which means that each one is somewhat different. For example, have owned more than a dozen Merckx frames and only two of them really ‘spoke’ to me. Kept one and really regret selling the other. Same deal with other brands and models, just bought & sold one after the other until coming upon the right one that had a great ride for ME…which may not have the same ride qualities for YOU.
Truly mass produced frames are more consistent. For example, have owned at least a dozen 87 Schwinn Tempo’s over the years and each one has been very, very good. Good enought that someone always came along and offered to buy the one I had, and good enough that eventually I’d buy another one. Not high end, Columbus seamed tubing, but they just work really well. So, there’s that.
rccardr is offline
Old 07-13-21, 06:26 AM
easyupbug
Quoted: 569 Post(s)
Liked 581 Times in 409 Posts
At my age there is little danger of seriously flexing a BB, but I must be insensitive as I have two Tommasini super prestige from the early '80s a SL and SLX and a '81 Pinarello Montello from the Levi Team SLX and had until recently a Pinarello Montello SL early 80's. While not perfectly similar builds I perceived no difference in frames, least of all the 1 oz+ difference in weight. As a keeper test I do run all bikes down a serious decline near the house at much higher speeds than I am happy with and hit some mild undulation near the bottom before a relatively sharp turn.
easyupbug is offline
Old 07-13-21, 01:04 PM
tendency
Quoted: 236 Post(s)
Liked 171 Times in 104 Posts
Problem addressed.
Investment cast lugs improved the frame stiffness compared to stamped?
tendency is offline
Old 07-13-21, 01:07 PM
tendency
Quoted: 236 Post(s)
Originally Posted by onyerleft
Despite the sticker on the tube, you really don't know what the tubes are, do you? Especially the rear triangle. A sticker is just a sticker. You're really relying on the frame builder's integrity to ensure that the tubes are what the sticker represents. Sadly, Serotta didn't have as much integrity as I would have wished. As a former Serotta owner, I know.
yikes! that's surprising I always held Serotta frames in fairly high regard.
tendency is offline
Old 07-13-21, 02:02 PM
Erzulis Boat
Le Crocodile
Quoted: 370 Post(s)
From my limited experience, the workmanship on the Serotta frame that I have was virtually flawless. The brazing and the mitering were second to none. I stripped the frame to bare metal to paint, so I really got to see everything. In comparison, the many (6+) Italian frames that I have stripped have always had cosmetic/brazing/alignment flaws.
Old 07-13-21, 04:05 PM
repechage
Too many variables. A better Chance that investment cast lugs will result in no voids, but even investment cast lugs are tweaked from time to time.
Then what?
builder skill.
