Grinding noise on downstroke
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
My bike is making a grinding/scraping noise on the downstroke on both sides. If I coast and pedal lightly the noise stops, When I start applying pressure to the pedals again the noise comes back. Does this sound like a BB issue?
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Try wiggling a crank arm and then the pedals. If nothing wiggles (no play) then I would be looking at the chain and cassette. Have you lubed the chain lately?
Quoted: 229 Post(s)
Liked 119 Times
I recently got it back from a full tune-up at the LBS. I assume they lubed everything up. But you know what they say about assuming... I'll oil the chain again just to make sure. It only makes the noise on the down stroke.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
If it's the Rossetti you probably have sealed bearings.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
This was happening to me so I changed the BB from the plastic Shimano one to a Works with angular bearings. Noise gone, thankfully! I was rather sure it was the BB. I lube the chain often and clean the pulleys. The chain was good, and the rear derailleur was rather new. The noise was coming more when putting down power on the uphill, so I was pretty sure it was the BB.
In my experience, that's indicative of the bottom bracket. I do know from another post that the OP just had the bike thoroughly gone over though if I'm not mistaken. Could be a myriad of things not tightened or overly tightened. I'd take it back to the shop and have them look at it.
Likes For Outrider1:
Quoted: 229 Post(s)
Liked 119 Times
Well, it turned out to just be a dry chain. Lubed it up, put a couple drops between the cranks and BB, and it's just about silent now. I guess it just shows that sometimes those LBS tune ups aren't very thorough.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,991 Times
At least at my shop a lot of the techs are huge fans of Triflow which is way too light of an oil to be using for chains ATMO. Your shop could be in the same boat. I prefer to use wax lubes or a wet lube personally but especially for customers who may not lube their chains often.
Quoted: 229 Post(s)
Liked 119 Times
Likes For pgjackson:
I took the crank off and tightened up the chainrings and replaced the BB Bearings, they were 3 years old. Grinding noise stopped. He was right the chain was grinding on the FD, but not because of frame flexing.
Edit: Glad you fixed it.
Quoted: 229 Post(s)
Liked 119 Times
I had the same. I had some dude telling me it was cause chain was rubbing on the FD due to frame flexing. Yeah that was BS.
Clark W. Griswold
Liked 3,991 Times
I am curious what they are using. Jeff Bezos sells a 55 gallon drum of sex lube that is blue and there is a smaller spray lube for motorsickles and Finish Line makes a bike product that you can spray which they claim is one step but was mentioned above as not really working.
The cleaner is going to remove the lube so how exactly can you now in the same spray also lube with a cleaner?
Likes For veganbikes:
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
I'm OCD about waxing my chain. I even dip parts like spare cassettes, sprockets, you name it if I'm just throwing them in the parts bin and don't want them to rust. But all BS aside, I enjoy waxing my chains. It's like down time and very relaxing. While I wait on the wax to melt in the crockpot I will put on some tunes and shoot a few games of pool. It's all good.
