Best Spoke Prep?
Best Spoke Prep?
Old 07-17-21, 06:05 PM
Keefusb
Keefusb
Bikes: 62cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 61cm 1985 Raleigh Competition (project bike)
Quoted: 13 Post(s)
Liked 13 Times in 7 Posts
Best Spoke Prep?
Going to be building my first wheels from scratch. I'm trying to decide which spoke prep to use. I have heard that linseed oil is best, or blue Locktite, or plain old oil works best. There are also several purpose-made spoke prep compounds.
Looking for input and/or opinions on what to use.
Keefusb is offline
Old 07-17-21, 06:14 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3011 Post(s)
Liked 1,336 Times in 934 Posts
Being the first self made wheel set I strongly suggest LockTite is not used. Many, including me, have used oil or grease on tens of thousands of wheels with no issues. For customer wheels I generally use Spoke Prep more because they expect it. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 07-17-21, 06:48 PM
gearbasher
gearbasher's Avatar
Quoted: 247 Post(s)
Liked 134 Times in 99 Posts
I've always used Wheelsmith spoke prep on the threads and a dab of Anti-Seize on the shoulders of the nipples.
gearbasher is offline
Old 07-17-21, 07:57 PM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 601 Post(s)
Liked 145 Times in 114 Posts
I just finished building a couple of sets and used grease on both threads and the outside of the nipple. Seems to work fine but then I don't heavily stress my wheels so I make no claim to this being best practice. What I do know is that I keep my wheels around for quite a while and when the nipples stick to the spoke threads it makes truing a pain in the butt.
Anyway, here is November Dave's Youtube channel. He's got a couple wheel building videos that you can take to the bank as far as technique is concerned.
https://www.youtube.com/channel/UClG...ByZcAOEZKw3u6w
Nessism is offline
Old 07-18-21, 05:35 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2688 Post(s)
Liked 1,397 Times in 868 Posts
I like linseed oil. It lubricates while you're building the wheel, then hardens over the course of a couple days into a varnish that locks the threads, but not so much that the wheel can't be trued again, if needed. A few bucks buys a lifetime supply, and you can use it on furniture as well.
JohnDThompson is offline
Likes For JohnDThompson:
Old 07-18-21, 08:34 AM
Dean51
Dean51's Avatar
Bikes: '83 YKonno Allez, '82 Ron Cooper, '87 Ciocc Designer 84, '95 Trek Saturn, '86 Tommasini Racing, '98 S-Works Hardtail Mtn., Klein Quantum Singlespeed
Quoted: 177 Post(s)
Liked 101 Times in 53 Posts
30 weight motor oil for the 30+ wheels I've built. 'Haven't had a problem with any of them.
Dean
Roll Me Up and Smoke Me When I Die
Dean51 is offline
Old 07-18-21, 10:01 AM
TheoMcD
Liked 5 Times in 3 Posts
Rock N Roll Nipple Cream - This stuff is awesome
TheoMcD is offline
Old 07-18-21, 10:26 AM
Rick
Quoted: 346 Post(s)
Liked 191 Times in 127 Posts
I just use oil on the wheels I build. Over seven years ago my new custom bicycle that I specked the specific rims for. Came with what the shop decided. I ordered in the new spokes and rims of my choice and preceded to disassemble the wheels. The black stuff they had put on the nipples was more like glue then spoke prep. I finished disassembly and completed the rebuild of the wheels on my now custom bicycle. I have not had to true the wheels and when I checked there trueness with my dial indicators a few weeks ago there had been no movement out of true in over 7 years.
Rick is offline
Old 07-18-21, 11:57 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3023 Post(s)
Liked 1,068 Times in 730 Posts
I really need to try that. Apart from my first wheel build, where the spokes came with spoke prep applied, I've only used oil.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-18-21, 12:53 PM
tendency
Quoted: 120 Post(s)
Liked 45 Times in 35 Posts
Always used triflow myself never had an issue.
tendency is offline
Old 07-18-21, 04:46 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 812 Post(s)
Liked 597 Times in 355 Posts
I'm not a pro, but have built dozens of wheels. The only thing I use is a drop of motor oil on the threads. I've never had an issue with nipples loosening so I see no need for anything that acts as a thread locker.
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 07-18-21, 06:53 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 937 Post(s)
Liked 1,212 Times in 683 Posts
I've used oil, linseed oil, spoke prep, tri flow. They all work if you tension the wheel properly. I put a drop of tri flow on the nipple/rim interface once it's laced, prior to tensioning. I also usually put a drop of spoke freeze on the spoke/nipple when done.
cxwrench is offline
Likes For cxwrench:
Old 07-18-21, 07:14 PM
Keefusb
Keefusb
Quoted: 13 Post(s)
Seems like regular old oil is the consensus. I might go with Linseed oil on the rear NDS spokes, since they will have the least amount of tension on them.
I appreciate all the input!
Keefusb is offline
Old 07-18-21, 08:34 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2989 Post(s)
Liked 1,583 Times in 1,050 Posts
I use marine grease on both the spoke threads and the nipple seats on the rim. (Q-tips are perfect for those seats.)
The big plus - the nipple turn guaranteed. Number of years, weather, road salt ... absolutely doesn't matter.
79pmooney is offline
Likes For 79pmooney:
Old 07-18-21, 09:38 PM
davidad
Quoted: 525 Post(s)
Liked 130 Times in 110 Posts
Loctite 567 thread sealer. It sets up firm and you can readjust the nipple later if necessary.
davidad is offline
Old 07-18-21, 11:08 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 441 Post(s)
Liked 213 Times in 169 Posts
You should lubricate the nipple rim interface and the spoke threads. In the interests of efficiency I like to immerse all the nipples in oil before building to accomplish both tasks at once. For aluminum on carbon anti seize on the rim eyets may help with galvanic corrosion. I like a little dt spoke freeze or light threadlocker dripped into the nipples after building as additional assurance against spoke loosening. Spokes will only loosen on a well built wheel if it's loaded beyond its design intentionsóbut things happen and it's not a terrible idea to have some mild thread locking. This is especially true on mountain bikes where sheer trauma to the rim is common. You should be able to make adjustments later if you do this.
cpach is offline
Old 07-19-21, 02:22 AM
Lazyass
Quoted: 2312 Post(s)
Liked 429 Times in 272 Posts
In the 90'so I built a set of wheels and used Militech gun oil since it was all I had and they never went out of true. That's all I've used since.
Lazyass is offline
Old 07-19-21, 07:19 AM
pdlamb
Quoted: 1616 Post(s)
Liked 841 Times in 523 Posts
Linseed oil on rear NDS and front wheel. Rear DS gets Finish Line Wet because that's usually the chain oil that's in the house, saving me a trip to the garage. That might change when I finish up the bottle in the garage, though.
pdlamb is offline
Old 07-25-21, 07:24 AM
TheoMcD
between the rim and the nipple, I have used SAE-10W, and it was still on there after a few years when I pulled the first wheelset I built apart.
TheoMcD is offline
