12 speed friction shifting
Old 07-17-21, 08:47 PM
BikingViking793
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 2010 Raleigh Talus 3.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour
Quoted: 145 Post(s)
Liked 54 Times in 44 Posts
I noticed on my 81 Schwinn Super Le Tour that I can get all the rear gears when on the inner chainring, but can't get the inner most cog when on the outer chainring in the front. I messed around with it for a while but wasn't able to fix it. Any ideas? I assume it's harder to get in from the out chainring, but it should be able to? No experience really messing with friction shifting and couldn't find any good tuning tips.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist Ė The goal here is to help you keep cycling on a budget.
BikingViking793 is offline
Old 07-17-21, 09:02 PM
SurferRosa
SeŮor Member
SurferRosa's Avatar
Quoted: 1905 Post(s)
Liked 2,148 Times in 1,201 Posts
That's called cross chaining, and it's not recommended. Also not recommended that you ride in the small/small.
SurferRosa is offline
Likes For SurferRosa:
Old 07-17-21, 09:20 PM
BikingViking793
Quoted: 145 Post(s)
I thought maybe it would be an issue, but wasnít sure with only 6 in back. And then all 6 work with the inner chainring. So outer chainring and inner cog is too much and shouldnít work?
Old 07-17-21, 09:26 PM
canklecat
canklecat's Avatar
Quoted: 4265 Post(s)
Liked 2,222 Times in 1,435 Posts
As noted, you should avoid cross-chaining. It can cause premature wear. And the excessive friction is less efficient.
But under stress it's easy to unintentionally cross-chain. I've done it a few times on fast group rides on roller coaster terrain, forgetting to shift from the big to small chainring, while quickly shifting up and down the cassette. Or, with indexed brifters, I don't want to risk dropping the chain to shift from the big to small chainring on a short, steep, fast, punchy sprint-climb -- could be dangerous for anyone drafting my wheel if I suddenly lose momentum and need to veer off to the roadside to horse the chain back onto the chainring (usually I can do it without stopping, just by shifting and carefully moving the pedals without force). When it's noisy outdoors -- from wind, traffic, other cyclists -- it's almost impossible to hear the telltale warnings of cross-chaining, with slightly increased chain noise.
So I always ensure my chain is long enough to safely shift into the big chainring and largest rear cog. Some folks cut their chains a link or two shorter, but this can damage the rear derailleur, potentially damaging the wheel, frame and injuring the rider. So I'd rather risk a little chain slap from a slightly longer chain. Covering the chainstay on the frame will help protect it from chain slap. Usually there's already tape on the chainstay, but we can add tape (some folks use "helicopter" tape), or even wrap it with handlebar tape, strips from old inner tubes, even twine.
Regarding shifting across the entire range in both chainrings and across the entire freewheel or cassette, it's a matter of setting the travel limit screws to enable full range of shifting without overshifting and pushing the chain into the wheel and damaging the spokes, or getting the chain trapped between the smallest cog and frame cluster where the seat stay, chainstay and dropout meet.
You'll find good tutorial videos for derailleur adjustments on the YouTube channels for Park Tools, Art's Cyclery and a few others. It's easy to do once you've watched a mechanic walk the viewer through the process. Especially with friction shifters since you don't need to worry about the more finicky adjustments needed for index shifting setups.
canklecat is online now
Likes For canklecat:
Old 07-17-21, 10:06 PM
madpogue
Quoted: 1802 Post(s)
Liked 848 Times in 642 Posts
The large/large and small/small combos are probably very close to some other combinations, if you do the math, you can figure out which alternate gear combo to select to avoid cross-chaining.
madpogue is offline
Old 07-17-21, 10:43 PM
70sSanO
70sSanO's Avatar
Quoted: 1142 Post(s)
Liked 973 Times in 642 Posts
Everyone screams don’t cross chain, but it is not the demon everyone makes it out to be especially on a 2x6 setup. Old wive’s tale from a time when cogs were super thick and chainstays were long.
People are running 1x11 setups that are designed by the mfg’s that have a greater angle than your large-large. On another thread I asked what is the maximum chain angle and all I got were crickets. With a decent modern chain you’ll be fine with a 2x6.
I think there is some merit not cross chaining with a triple and 8, 9, or more cogs.
There is probably a good chance your chain is too short and doesn’t want to climb onto the lowest cog. If that is the case it is a good thing because you don’t want to destroy your rear derailleur forcing your chain onto the largest cog.
John
Edit Added: If the chain is the correct length, it could be an issue with top jockey wheel interfering with the large cog. If you rear derailleur is pre-B screw, you will need to move the wheel forward in the horizontal dropouts to get more clearance. This will help a slight bit with chain length if it is close.
70sSanO is offline
Old 07-17-21, 11:56 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1106 Post(s)
Liked 565 Times in 398 Posts
What 70s SanO said.
Also, you didn't mention what kind of rear derailer you're using. Any derailer with an offset top pulley (offset from the cage pivot), such as all Shimano and most racing derailers, will have a larger "chain gap" (between top pulley and freewheel cog) when it's on the big ring. This reduces the motivating force for the chain to grab the largest cog (or any cog).
If you can adjust the chain gap by perhaps sliding the axle forward or using a longer chain, then the shifting response will be more effective. Many derailers feature adjusting screws or nuts to adjust chain gap to better suit a particular size freewheel on a particular bike, which is why I was wondering what derailer you have.
Modern chain is more flexible, so is more sensitive to too large of a chain gap.
Most any derailer can be adjusted for chain gap if one is willing to tinker with it's spring tensions, whether or not any direct adjustment screws or nuts (as with Simplex) are provided for this purpose.
dddd is offline
Old 07-18-21, 01:12 AM
randyjawa
randyjawa's Avatar
Quoted: 1131 Post(s)
Liked 968 Times in 587 Posts
You probably can't go big ring to big cog because your chain is not long enough to do so. That said, I agree with avoid cross chaining. Cross chaining does put unnecessary strain/wear on the chain and sprocket teeth, in my opinion.
randyjawa is offline
Old 07-18-21, 03:30 AM
P!N20
P!N20's Avatar
Quoted: 671 Post(s)
Liked 812 Times in 444 Posts
Slightly disappointed this thread wasnít about someone pairing downtube shifters with a 12 speed block.
P!N20 is offline
Likes For P!N20:
Old 07-18-21, 05:27 AM
nlerner
Quoted: 2391 Post(s)
Liked 2,251 Times in 1,116 Posts
As others have said, your chain is likely too short or go with an 8-speed chain, which will have more flex than what you have now.
Fwiw, on several bikes in the fleet that are 2x8 or 2x9, I can ride big-big with no problems. But those are with compact double cranksets, which might play a role.
nlerner is offline
Old 07-18-21, 09:26 AM
Schlafen
Quoted: 55 Post(s)
Liked 48 Times in 31 Posts
It's your bike, you can ride whatever combo you want, but, if you don't use components that work together it will wear your drivetrain really fast on top of very poor performance.
Use a modern mtb chain, which is designed to flex more on 1x10, 1x11 even 1x12 setups. This will wear your components at both far ends if you ride that combo alot, but not any faster than any modern 1x setup.
Even though 2x6 doesn't have the same spacing as half of an 11 speed or 12 speed cassette, it's not too far off.
Schlafen is offline
Old 07-18-21, 04:33 PM
John E
feros ferio
John E's Avatar
Quoted: 1013 Post(s)
Liked 440 Times in 322 Posts
Assuming a long-enough chain, if small-small works much better than large-large check your driveline alignment. With a 2x6, the chainrings should align with the third and fourth cogs. To bring them into better alignment you either need to move the cogs to the right, assuming sufficient clearance at the dropout, or move the drive side crank to the left, assuming adequate chainstay clearance. I had a 2x5 Nishiki Competitoin from the early 1970s, and I never could get large-large to work without grinding.
John E is offline
Old 07-18-21, 06:12 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3024 Post(s)
Liked 1,069 Times in 731 Posts
That's what I was expecting, too!
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-19-21, 11:54 AM
BikingViking793
Quoted: 145 Post(s)
https://www.youtube.com/watch?v=UkZxPIZ1ngY
https://www.youtube.com/watch?v=wQncKmddahk
is there a good video that is friction shifter specific? Iím pretty good with indexed shifting.
Old 07-19-21, 12:45 PM
Schlafen
Quoted: 55 Post(s)
- set H (small cog) and L (big cog) limits
- take the slack out of the cable.
- done.
You have mastered friction shifting adjustment.
Bike mechanics had it so tough back in the days smh.
Schlafen is offline
Likes For Schlafen:
Old 07-19-21, 01:09 PM
OldRailfan
Old enough, hmmm?
OldRailfan's Avatar
Bikes: DeVinci, Bianchi, Nishiki, RBSM Mud Adder
Quoted: 37 Post(s)
Liked 48 Times in 36 Posts
You could make a table of which combinations overlap and use that to get the most efficient way to use the gears.
OldRailfan is offline
Old 07-19-21, 10:06 PM
canklecat
canklecat's Avatar
Derailleur adjustments are pretty much the same regardless of shifter: friction, indexed downtube, bar-end, integrated brake/shifter brifters.
With indexed downtube or bar-end shifters, I have to add one step to center the pulleys under the middle cog, using the barrel adjuster. That's unnecessary with friction shifters, and the most crucial steps are eliminating most cable slack, and setting the travel limit screws.
The feel of a friction shift lever depends on the design. Up until the late 1980s, most used metal washers, and some contained some variation of the retrofriction design with springs, so it was possible to finesse the shifting feel without excessive friction or tension. Later indexed shifters with an optional friction mode used more plastic and it was harder to finesse the bolt tension to get the desired friction. I gave up trying to use my Suntour GPS Accushift levers in friction mode because the feel was mediocre. I had to crank the tension really tight to avoid ghost shifts under pressure. Every time I'd stand to pedal it would ghost shift both front and rear derailleurs, unless I cranked down the bolt so much it was hard to shift at all.
But I have some Shimano L-422 Light Action shifters, which are friction only, with a retrofriction type design and little springs to help ensure light but even tension. They're a pleasure to use in friction mode. The only tricky bit was minimizing cable slack before clamping down the cable clamp bolt. I had to redo that a time or two before I got it right. And despite being nominally a 6-speed shifter, it pulled enough cable to work with my 7- and 8-speed freewheels and cassettes.
And the Shimano bar-end shifters on my hybrid aren't bad in friction mode. They don't use a retrofriction design, but there are micro-detents with slight but palpable clickstops, so the shifters don't creep under pressure. Even the cheap but very functional SunRace SLM10 thumb shifters have a pretty good friction feel with micro-detents to prevent creeping
Old 07-19-21, 10:28 PM
70sSanO
70sSanO's Avatar
I donít know if they are a best kept secret, but L-422ís are just marvelous. I used Simplex Retrofriction for years, but those spring loaded L-422 were just about as nice. I removed the ratchet ring out of mine and they were so smooth.
John
70sSanO is offline
Likes For 70sSanO:
Old 07-19-21, 10:42 PM
canklecat
canklecat's Avatar
John
Yup, those L-422 shifters are so nice I'm thinking about getting another steel frame to set up for friction shifting. I think I already have a set of older Shimano 600 derailleurs from the 6-speed era. One of the local clubs I occasionally ride with hosts an old school steel ride once in awhile and it's fun to see what other riders bring.
