When internal cable routing sucks
Old 07-19-21, 05:07 PM
jayp410
Quoted: 24 Post(s)
Liked 21 Times in 14 Posts
Just had to replace a broken shifter cable on my externally-routed road bike. (Luckily, the cable broke on the bike stand when I was adjusting the shifting, which had gotten bad...and now I know why). Being externally routed, it was easy: pull the cable through and replace. On the road, I could install a spare cable, or, if not carrying a spare, could at least anchor the broken cable to a downtube cage bolt, adjust, and ride home.
This got me thinking that with an interally-routed cable, that wouldn't work so well. It probably wouldn't be easy to pull it through out the bottom bracket to anchor the cable to the frame, and after doing so, it might require taking out the fork and/or bottom bracket to route the new one. If you carry a spare cable and some thin Spectra fishing line, could tie the line to the old and new cables and pull the new one through. I did this on my new internally-routed bike build, after accidentally cutting the new RD cable too short. However, my bike also has internal plastic sleeves that run through the plastic BB cable guide, which are barely larger than the cable itself, and even with a cleanly-cut cable and the very thin fishing line, it was not easy to pull it through. If the cable end was frayed, the end would be considerably larger and might be almost impossible to pull through. So to fix this on the road, I'd have to also carry one of those heavy cable cutters to get a clean cut. Yeah, that's not happening.
So it seems that I'll either need to remember replace the shifter cables regularly (before they show symptoms of fraying). When I inevitably forget to do that, it will mean a call to the wife to come pick me up.
How do you deal with this?
jayp410 is offline
Old 07-19-21, 05:32 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 15573 Post(s)
Liked 3,527 Times in 1,763 Posts
I have 2 road bikes. One is externally routed, easy peasy. One is internal.
The internally routed one requires more time and patience. How do I deal? Let’s say it invokes a lot of words I can’t say here.
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 07-19-21, 06:08 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2690 Post(s)
Liked 1,400 Times in 870 Posts
Probably easier to describe when it doesn't suck.
JohnDThompson is offline
Likes For JohnDThompson:
Old 07-19-21, 06:13 PM
Metieval
Metieval's Avatar
Quoted: 1171 Post(s)
Liked 265 Times in 187 Posts
Preventive maintenance.
Metieval is offline
Likes For Metieval:
Old 07-19-21, 06:14 PM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 937 Post(s)
Liked 767 Times in 423 Posts
In the plus column, internal cable routing is an iron-clad excuse to buy yet another tool.
Ride, Rest, Repeat
terrymorse is offline
Likes For terrymorse:
Old 07-20-21, 07:17 AM
jacobjones
jacobjones's Avatar
I had the same situation. It's annoying
jacobjones is offline
Old 07-20-21, 07:06 PM
ShannonM
Quoted: 276 Post(s)
Liked 246 Times in 175 Posts
When looking at the bike.
And at no other time.
--Shannon
PS: I have always had a soft spot for the rear derailleur cable routing on the late 80s steel Treks. Love the look, even though replacing one (1) of them gave me PTSD... so sanitary.
ShannonM is offline
Old 07-20-21, 07:43 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 2917 Post(s)
Liked 2,273 Times in 1,113 Posts
Sram eTap... problem solved.
GlennR is offline
Likes For GlennR:
Old 07-20-21, 10:18 PM
jackb
Bikes: Trek Domane 5SL Disc; REI Maza,ma; Specialized Langster, Kona, Honzo
Quoted: 101 Post(s)
Liked 69 Times in 35 Posts
I've been cycling for 45 years and have never had to replace a cable. Keep your bikes dry and properly lubricated to reduce the chances of a broken cable.
jackb is offline
Likes For jackb:
Old 07-20-21, 10:34 PM
ShannonM
Quoted: 276 Post(s)
This reminds me of an episode of Car Talk, when some dude called in and told Tom & Ray that he and his wife had a Honda Accord, (early 1990s, IIRC,) with like 245,000 miles on it.
They'd never changed the oil. Just checked it every so often and added some when it got a bit low.
Dude's question was "so, should I do an oil change?" To which Click and Clack both responded with some version of "Dear God, No!!! If you do, your car will be dead in a week!", followed by much existential angst about "everything we know is wrong" and "have we been ripping off our customers for all these years?"
Seriously, you've been riding the same cables for 45 years??? Man, I ain't been livin' right!
--Shannon
ShannonM is offline
Likes For ShannonM:
Old 07-21-21, 02:28 AM
Lazyass
Quoted: 2319 Post(s)
Liked 436 Times in 279 Posts
I have a Diamondback Podium and both shifter cables come out under the BB. What I do is bend the last inch or so of the tip of the cables a little less than a 90 degree angle. When I push the cable through and it contacts the BB area I twist and push the cable and can fish it out pretty easy. I also do it on my frames with an internal rear brake cable. It's kind of hard to explain it but when you do it you'll see what I'm talking about.
But I prefer external routing.
Lazyass is offline
Old 07-21-21, 02:35 AM
Branko D
Quoted: 161 Post(s)
Liked 180 Times in 110 Posts
It's one of those things which sounds like a much bigger problem than it is.
The first time I was replacing cables on my internally routed bike which did involve a fair bit of swearing, I put in these thin cable liners and left them there, and subsequent cable changes were an absolute breeze. If you don't want to leave them in the bike, you could carry the cable liners to make the job easier (they're lighter than a cable) if you wanted to do it in the field, but I never carry a spare cable anyway.
I change the cables preventively once a year or two, though. My preference is for internal cables, overall.
Branko D is offline
Likes For Branko D:
Old 07-21-21, 05:53 AM
TiHabanero
Quoted: 1265 Post(s)
Liked 614 Times in 329 Posts
Had to route rear brake line from the caliper to the lever completely internally routed. Could not have done it alone as it required two people, one to guide the hose to the opening in head tube and the other person twisting the hose to get it past the internally routed rear derailleur cable where the hose was getting hung up. Complete bulls**t.
Internally routed cables and hoses are for boy racer wannabes. They solve nothing and add a level of complexity not necessary for one of the simplest transit machines.
TiHabanero is offline
Likes For TiHabanero:
Old 07-21-21, 07:19 AM
Milton Keynes
Milton Keynes's Avatar
Quoted: 2086 Post(s)
Liked 1,365 Times in 749 Posts
--Shannon
Sorry, I don't believe that a car with 245,000 miles has never had an oil change, unless it kept burning off the old oil and they replaced it with fresh oil. I've changed the oil in a car which was 30,000 miles (!) overdue for an oil change, and the oil just totally glopped out of the drain pan in chunks. The owner kept driving it without changing the oil and it eventually burnt up on the side of the road. Did another oil change on a truck which I don't know how far overdue it was, and the "oil" was pretty much all sludge. It's really a surprise when you remove the drain plug and nothing comes out. And the oil filter was pretty much full of solid sludge. How it was still running, I have no idea. But we put some oil system cleaner in it and got most of the sludge out, fresh oil and it's back on the road.
In that Honda Accord, I'm guessing that the drain pan and oil filter are just totally full of solid sludge. Keep cooking the oil for 245,000 miles and that's what happens.
Milton Keynes is offline
Likes For Milton Keynes:
Old 07-21-21, 07:32 AM
WhyFi
WhyFi's Avatar
Quoted: 17402 Post(s)
Liked 6,126 Times in 3,157 Posts
You expect me to deal with ugly-ass, plebeian external cables because there's the possibility that, once in a decade or two, I might pop a cable mid-ride? Nah.
WhyFi is offline
Likes For WhyFi:
Old 07-21-21, 08:27 AM
Troul
:D
Troul's Avatar
Liked 1,102 Times in 790 Posts
Cables become a schedule interval service for replacement when they are internally routed, for any of my bicycles.
-Oh Hey!
Troul is offline
Old 07-21-21, 10:42 AM
Milton Keynes
Originally Posted by TiHabanero View Post
Internally routed cables and hoses are for boy racer wannabes..
I have a bike with internal cables, and I'm definitely not a boy racer wannabe. The bike just came like that. And frankly, it is a cleaner look though I hope I don't ever have to replace the cable.
Old 07-21-21, 11:27 AM
zandoval
zandoval's Avatar
Bikes: Univega, Peu P6, Peu PR-10, Ted Williams, Peu UO-8, Peu UO-18 Mixte
Quoted: 196 Post(s)
Liked 227 Times in 166 Posts
Broken Cable... So what? Take Steps to Prevent this problem and Quit Whining...
No... Honestly it can be hard to route those little buggers but its just a thing ya gotta do and even if you have done it allot... Its still a thing...
zandoval is offline
Old 07-21-21, 11:30 AM
kommisar
Liked 2 Times in 1 Post
Internally routed cables are a "feature" that reduces the functionality of the bicycle and are something I like to avoid when purchasing a new frame. Hard to install, hard to fix, no apparent practical benefit.
kommisar is offline
Likes For kommisar:
Old 07-21-21, 11:50 AM
WhyFi
WhyFi's Avatar
I question the mechanical aptitude and creativity of anyone that kvetches about the difficulty of internally routed cables and brake lines. It's not that difficult to get some thread or dental floss through the frame. Once a lead is in place, it's trivial to pull cables and brake lines through. If you're not starting from a bare frame, even easier - just use the existing cable as the lead.
Given the (in)frequency of need, and the low level of difficulty, it's really not a big deal, IMO. ​​​
WhyFi is offline
Likes For WhyFi:
Old 07-21-21, 01:49 PM
Ogsarg
Quoted: 534 Post(s)
Liked 809 Times in 347 Posts
Let me get this straight. You're bashing a feature based on something that may happen to you someday that might involve you calling for a ride.
Ogsarg is offline
Old 07-21-21, 02:16 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 6127 Post(s)
Liked 3,273 Times in 1,888 Posts
By riding externally routed bikes. Its easy to not have to deal with something that isnt applicable.
mstateglfr is online now
Old 07-21-21, 03:52 PM
tempocyclist
tempocyclist's Avatar
Quoted: 54 Post(s)
Liked 139 Times in 66 Posts
Brakeless fixie.
Problem solved?
tempocyclist is offline
Old 07-21-21, 07:03 PM
TiHabanero
"I question the mechanical aptitude and creativity of anyone that kvetches about the difficulty of internally routed cables and brake lines. It's not that difficult to get some thread or dental floss through the frame. Once a lead is in place, it's trivial to pull cables and brake lines through..."
Question no more!
Externally routed cables are easily replaced in a few minutes, same with some, but certainly not all internally routed cables. Internally routed brake hose is whole other animal and a total PIA to deal with because externally routed housing is simply simple to deal with and goes quickly in comparison. Creativity and aptitude has zero to do with it. I have routed ebrake cables on autos in less time than some internally routed brake hose.
For what it is worth, which ain't much, I am a trained bike wrench, motorcycle wrench and car wrench. Was certified ASE long ago. Been wrenching my whole life and certainly have seen my share of creative moments!
Old 07-21-21, 07:48 PM
WhyFi
WhyFi's Avatar
Question no more!
You kvetch about internally routed frames and can't figure out the "Quote" button, but you want me to accept your competence? Okay.
WhyFi is offline
