Were these cantilever brakes assembled wrong?
Old 07-20-21, 03:57 AM
robertj298
robertj298's Avatar
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 556 Post(s)
Liked 257 Times in 122 Posts
Just noticed this on my Super Strada. Seems to me the cables on the rear brakes should run inside
the rear racks frame instead of to the outside where they rub the rack?
robertj298 is offline
Old 07-20-21, 04:16 AM
Colorado Kid
Quoted: 172 Post(s)
Liked 29 Times in 19 Posts
Yep, their done backward. The cable should run inside the rack, not outside.
Colorado Kid is offline
John Nolan
Bikes: Raleigh Classic 15, 84; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 131 Post(s)
Liked 59 Times in 36 Posts
Inside is more usual. Note that one often has to balance straddle cable length and position. Would moving the cable inside eliminate rubbing, or just move the rub to the inside?
John Nolan is offline
Old 07-20-21, 04:41 AM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '07 Stumpjumper
Quoted: 199 Post(s)
Liked 222 Times in 134 Posts
Yes...
...try to readjust the cable hanger to where the bottom of it is basically where the cross bar is and then the single brake cable wire goes between the two rack supports.
mechanicmatt is offline
Old 07-20-21, 05:19 AM
SJX426
SJX426's Avatar
Quoted: 1098 Post(s)
Liked 805 Times in 495 Posts
Straddle cable is too long.
Straddle Cables Done Right – Rene Herse Cycles
SJX426 is offline
Likes For SJX426:
Old 07-20-21, 05:26 AM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
The original owner only rode this bike a few times so I'm fairly certain the bike
was set up by the shop where it was purchased.
Old 07-20-21, 06:19 AM
SJX426
SJX426's Avatar
@robertj298 - send the link to the shop! The length of the straddle cable negates the purpose of having a brake that works correctly, much more important than it rubbing on the rack.
SJX426 is offline
Old 07-20-21, 06:39 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022, '21 Tsunami SNM-100
Quoted: 1363 Post(s)
Liked 1,321 Times in 711 Posts
Optimal straddle length will create a 90 degree bend from the line that connects pivot-to-binder bolt and the binder bolt-to-straddle yoke. Normal angle pull gives the most leverage to the pivot. Set it up as close 90 degrees that you can achieve without rubbing on the rack.
Phil_gretz is offline
Old 07-20-21, 08:47 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3031 Post(s)
Liked 1,085 Times in 741 Posts
Perhaps they were trying to avoid the scenario where the brake cable snaps and allows the straddle cable to fall and catch on the tire?
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 07-20-21, 10:32 AM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1830 Post(s)
Liked 974 Times in 656 Posts
That would be cutting one's nose off...
clubman is offline
Old 07-20-21, 10:38 AM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
So thats why they put that rack on the back?
Likes For robertj298:
Old 07-20-21, 10:54 AM
ThermionicScott
I mean, that was my best guess. I'd do it differently.
RUSA #7498
Old 07-20-21, 11:14 AM
noobinsf
noobinsf's Avatar
Quoted: 819 Post(s)
Liked 624 Times in 411 Posts
I had an 85 Viva Touring, which was a level down from your bike, that was very low mileage and still had the original set up. You can see in this pic that the cable hanger was lower and the straddle cable inside the rack struts.
noobinsf is offline
Old 07-20-21, 01:29 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
As suggested I changed the cables to this which I think is much better
Old 07-20-21, 09:45 PM
canklecat
canklecat's Avatar
Quoted: 4272 Post(s)
Liked 2,240 Times in 1,444 Posts
Yeah, my first thought was "Were they trying to rig up a straddle cable catch?"
My Univega was missing the front and rear stalks that served the dual purpose of holding reflectors and as straddle cable catchers. I thought about replacing those. But after recabling the bike I realized the odds of those massively thick brake cables snapping were nil. Those cables are much thicker than road bike brake cables, and I've never had one of those snap. I've had a few shifter cable fray, usually around the shifters themselves. But never a brake cable.
canklecat is offline
Old 07-21-21, 04:11 PM
Sluggo
Sluggo's Avatar
Quoted: 40 Post(s)
Liked 93 Times in 44 Posts
These appear to be cantilevers with horizontal (90*) arms. If that is the case, straddle cable length does not matter ( see canti-geometry.pdf (circleacycles.com) ). Set the length to whatever length is needed to clear the rack on the inside.
You might be able to simply unhook the straddle cable from the arms and feed the cable to the inside.
Sluggo is offline
Old 07-21-21, 04:44 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1110 Post(s)
Liked 571 Times in 404 Posts
If those are the bike's OEM radial tires(?), you will experience a massive improvement in steering feel and overall handling if you install non-radial tires.
90-degrees to the line of action between the transverse cable anchor point and caliper pivot is not the optimum when greatest leverage is needed. Generally the power/leverage increases as the transverse straddle cable is made shorter, because the tension in the straddle cable increases for any given pull/tension at the lever.
dddd is offline
Old 07-21-21, 06:21 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 2308 Post(s)
Liked 1,031 Times in 519 Posts
The cantilever angle in that paper refers to the angle between the plumb line (ZP) and the line from the attachment point through the pivot point (AP). As cantilever's get wider, that angle approaches 90 degrees, but on these brakes it's not there.
My Bikes
Andy_K is offline
