All Original or Period Correct
Old 07-21-21, 11:45 AM
Cactus459
Cactus459's Avatar
Quoted: 5 Post(s)
I have a bike that I started mountain biking on in the early 90's. I upgraded a couple of parts like the stem and seat, was wondering if I pull it out off storage and restore it should I try and put it back to all original or period correct? To be honest it is probably has more sentimental value than street value. I don't believe I would ever sell it, more worried my daughters are going to sell my bikes in a garage sell and not care about what they are actually worth. Ultimately want to make my first mountain bike a wall hanger.
Cactus459 is offline
Likes For Cactus459:
Old 07-21-21, 12:13 PM
SJX426
SJX426's Avatar
Quoted: 1099 Post(s)
Liked 807 Times in 497 Posts
I think you ansered your question with the wall hanger statement - original.
SJX426 is offline
Likes For SJX426:
Old 07-21-21, 12:17 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 3411 Post(s)
Liked 1,920 Times in 939 Posts
Whatever you want. It's your bike. Those that want a bike all original are treating their bike as museum pieces, not that there's anything wrong with that.
"Back in the day" there were a lot of production bikes that were purchased and upgraded before a single mile was ridden. Proof of this is my first "real" bike purchased in 1975 - Raleigh Super Course MkII.
I rejected original equipment then.
As far as period correct goes, why limit yourself? I've built up several vintage frames with more modern componentry. If a bottom bracket is pulled out, I almost always replace it with a modern sealed model. I'll use OEM or period correct parts if they're good.
You'll get many opinions here, but at the end of the day, just follow your bliss. If riding on original equipment makes you happy, do so. If you prefer the performance of a modern part, go for it.
The only rules are the ones you place on yourself.
gugie is offline
Likes For gugie:
Old 07-21-21, 12:30 PM
Erzulis Boat
3rd Grade Dropout
Erzulis Boat's Avatar
Quoted: 198 Post(s)
Liked 170 Times in 92 Posts
I vote for original. If it will be relegated to "wall hanger" status anyway, why bother faking the funk.
If I still had my original race MTB, I would surely retain the Syncros stem and seatpost that always worked loose as a constant reminder that "fancy parts" are not always good components, and that was the issue that haunted me every ride. The bars were from a box store bike because I had run out of money at the end of the build and slapped some cheapos (they were aluminum at least.........) to get by and then never bothered to upgrade as the fit was perfect. That was my bike, and swapping stuff out now would alter the history (insignificant, but hey).
Erzulis Boat is offline
Old 07-21-21, 12:42 PM
CliffordK
CliffordK's Avatar
Quoted: 14492 Post(s)
Liked 2,446 Times in 1,821 Posts
For my old Colnago... even if I could track down many of the original parts, so many have worn out over the years that putting it back to "original" would be just building a wreck.
Spokes pulled through the rim, brake levers that don't hold the cables anymore, ripped seat covers... Gawd, what happened to all those rolls of bar tape... pitted cones, broken seat post binder bolts, broken chainrings, worn chainrings, busted chains, worn freewheels, ... flatted and blown tires, ... Rear derailleur in the spokes, front derailleur cage worn in half.
I suppose I could make a good wall hanging of worn out parts.
Some parts might be able to be repaired. Who here is recommending welding cracked spoke holes? Perhaps I could get that cable attachment pivot out of the brake levers and replace.
CliffordK is online now
Old 07-21-21, 12:43 PM
squirtdad
squirtdad's Avatar
Quoted: 1439 Post(s)
Liked 775 Times in 522 Posts
Under stand sentimental value. Will you ever ride this bike....even for utility and errands? (personally I like that idea ) if so put some slicks on it, ride and remember it glory trail days.
if it was high end or unique or if you just want to and don't plan on riding go original and find the wall where it will look best
squirtdad is offline
Old 07-21-21, 12:46 PM
juvela
juvela's Avatar
Quoted: 2638 Post(s)
Liked 973 Times in 757 Posts
Gugieficazione right from the outset!
juvela is offline
Old 07-21-21, 12:50 PM
gugie
gugie's Avatar
I never could leave well enough alone.
gugie is offline
Likes For gugie:
Old 07-21-21, 01:00 PM
randyjawa
randyjawa's Avatar
Quoted: 1131 Post(s)
Liked 969 Times in 587 Posts
Wall hanger = original, absolutely! I do this sort of thing quite often. If not hung up as original it becomes just another mountain bike, in my opinion.
randyjawa is offline
Likes For randyjawa:
Old 07-21-21, 01:14 PM
juvela
juvela's Avatar
"...iffin' she ain' broke do fix 'er..."
juvela is offline
Old 07-21-21, 01:45 PM
squirtdad
squirtdad's Avatar
i resemble that
Old 07-21-21, 02:30 PM
Cactus459
Cactus459's Avatar
Quoted: 5 Post(s)
Pulled from storage
I have several better bikes, but I think if it were hanging on the wall in my garage I would have to pull it off and ride it. If just for nostalgic reasons.
Old 07-21-21, 02:48 PM
randyjawa
randyjawa's Avatar
And there is no reason not to take it for a ride, now and then. Again, original would earn my vote and this wall hanger of mine does see the road every once in a while, but not very often...
Old 07-21-21, 03:18 PM
SurferRosa
Seor Member
SurferRosa's Avatar
Quoted: 1915 Post(s)
Liked 2,182 Times in 1,212 Posts
What's a "wall hanger"? A bike you don't ride? Why? Does it not fit? Too out of shape? Dead?
SurferRosa is offline
Old 07-21-21, 03:52 PM
70sSanO
70sSanO's Avatar
Quoted: 1146 Post(s)
Liked 997 Times in 647 Posts
The real question is how much money do you want to spend?
If you only need a few components, it might not be too bad.
If you need a complete restoration, bring cash and plenty of it. The demand for 90’s mtb’s is pretty nuts. You might get lucky at a co-op or find a donor bike. But it is not going to be a process of going on eBay and finding that old XT derailleur in great shape and having a half dozen to choose from for $15-$20.
John
70sSanO is offline
Old 07-21-21, 03:54 PM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1002 Post(s)
Liked 637 Times in 442 Posts
TTIWW the OP's bike pic.
2cam16 is offline
Likes For 2cam16:
Old 07-21-21, 04:03 PM
Cactus459
Cactus459's Avatar
Quoted: 5 Post(s)
Wall hanger
I have multiple bikes to choose from when I want to go out and ride. I realized I still had my first mountain bike in storage and wanted to breathe some life back into it. I have all the original parts and was wondering what others would do with it? Leave the upgrades or put the original parts back on it? I want to leave it in the garage in working order on the wall so hopefully it will get riden once in a while.
Old 07-21-21, 04:10 PM
Cactus459
Cactus459's Avatar
Quoted: 5 Post(s)
How much money
If you need a complete restoration, bring cash and plenty of it. The demand for 90s mtbs is pretty nuts. You might get lucky at a co-op or find a donor bike. But it is not going to be a process of going on eBay and finding that old XT derailleur in great shape and having a half dozen to choose from for $15-$20.
John
That is the best part about all this, I kept all the original parts. I would still need to get new tires and maybe tubes. Otherwise I would just pull it all apart regreese everything and possibly brake pads. That is why I was wondering if anyone would put it all back together with the updated parts or the original parts... Actually I might not have the original seat.
Old 07-21-21, 04:15 PM
droppedandlost
small ring
droppedandlost's Avatar
Quoted: 295 Post(s)
Liked 362 Times in 181 Posts
If I had all the parts then definitely original
droppedandlost is offline
Likes For droppedandlost:
Old 07-21-21, 04:20 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 893 Post(s)
Liked 1,678 Times in 806 Posts
I recently debated about what to do with my old MTB race bike that has been sitting mostly unused for about 20 years. I would never consider getting rid of it. I considered updating it with a newer drivetrain, but really didn't want to invest that much into a project. I decided to go a completely different direction - SINGLESPEED! It's been a wonderful change of scenery, attitude, and approach compared with my typical diet of go-fast road rides. Most recently, my ride days have been pretty split between this bike and my road machine. So much fun!!
Eric F is online now
Likes For Eric F:
Old 07-21-21, 06:33 PM
John E
feros ferio
John E's Avatar
Quoted: 1018 Post(s)
Liked 445 Times in 325 Posts
I draw the "original" line at gearing, because I have rarely kept the original gear ratios on any bike I have ever purchased. When we sold PA-10s, PR-10s, an PX-10s at a Peugeot/Nishiki dealership, they rarely went out the door with the original 52-45 / 14-15-17-19-21 gearing. 14-26 or 14-28 freewheel substitutions were very popular, as were 40T or 42T inner chainrings on the PRs and PXs. (The PA-10s used cottered steel cranks with the Simplex 3-to-6-bolt adapters, limiting the small ring to 45T or larger. Some folks scrapped these and installed paired rings in which the outer, 3-bolt, ring carried an inner ring as small as 36T.)
When I brought my 1971 American Eagle Semi-Pro (Nishiki Competition) home, I replaced the padded vinyl saddle with my trusty old Ideale leather one, prompting my friend to remark, "All the discomforts of home." It saw numerous regearings over the years.
John E is offline
Old 07-21-21, 09:17 PM
rando_couche
Quoted: 196 Post(s)
Liked 108 Times in 72 Posts
When you reach my age (don't ask!), "all original" translates to "unrideable", mostly thanks to vintage gearing. 42x21 bottom gear? It is to laugh!
rando_couche is offline
Old 07-21-21, 10:11 PM
ShannonM
Quoted: 276 Post(s)
Liked 251 Times in 178 Posts
If it's been your bike since new, and you did some upgrades back when, have you considered building it out with all of the parts you'd have bought for it then if you'd had the bread?
--Shannon
ShannonM is offline
Likes For ShannonM:
Old 07-22-21, 01:11 AM
Cactus459
Cactus459's Avatar
Quoted: 5 Post(s)
Pictures
Sorry not an option for Noobie.
Old 07-22-21, 06:21 AM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD
Quoted: 313 Post(s)
Liked 170 Times in 128 Posts
I would keep the upgrades you made while still using the bike regularly, they are part of its history. The same goes for wear and tear on the frame. As long as it is still functioning well, I would keep the bike just as you remembered it.
Pompiere is offline
