Bikes you painted yourself
#126
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
#127
Strong Walker
I know what you mean. I have a $700 automotive spay gun. It's for large panels on cars but setting it up and spraying technique is quite difficult. I think I'll stick to my mini cheap gun for bikes, it does a great job with a finer nozzle and aircap for thin bike frame tubes and quicker than airbrushes.
i finished my very rough first project with it. No closeups, they would be too embarassing but i learned a lot! Next project is in the queue, which will be just a plain color on a 1920 Peugeot
btw good job on the Sakae! That was my first good MTB until a scumbag stole it from my front door...
Likes For martl:
#128
Quoted: 227 Post(s)
Liked 390 Times
Your Iwata is a great gun, definitely don't need any better than what you have. Ultimately it's going to be how it's setup
My Devibiss mini is a cheap gun that can do well too but one of the things that make it cheap is no adjuster knob markings and the adjusters are hyper sensitive. The build quality is good enough as I don't use it much so will last.
My photo shows the size difference between full size and mini. I can do good bike frame spraying with the big one but there's lots of paint wastage in the air because it's for large panels and the pot size makes manoeuvring around a frame in tight spots difficult. I've decided to make it the ultimate mini gun though I've ordered a 100ml pot, a T110 air cap "again" and a 1.2 fluid tip. It won't get much better spraying frames anymore then can swap the parts back for automotive jobs.
#129
Quoted: 227 Post(s)
Liked 390 Times
Looks alright to me Must have been a lot of work marking off for different colors.
I don't know if you've seen this dude before. I like the way he paint the graphics and lines, I'd like giving his methods a try, of course it would take me awhile to complete a frame.
https://www.youtube.com/user/EtoEGermany/videos
Likes For jbchybridrider:
#130
#131
Quoted: 227 Post(s)
Liked 390 Times
Looking at my mini gun I'm not sure the pot size, it doesn't say on it but looks 200ml. I'd use half that as a first light coat frame and fork then 2 pots in total to complete the job "400ml" There's about 3 coats in there. I'd call that a thin paint job with good coverage, I'd usually have 10-20% left over just while checking the frame for to light or missed spots and struggle to finish it all. Clears another 400ml at least.
I think 1 rattle cans enough for primer colour then clear "3 cans".
My big guns a 1 litre pot. Not sure about using an air brush but probably less paint required.
#132
Not trivial at all. If I haven't done a frame in a long while I have to have a good think about how much to mix.
#133
Strong Walker
@JBChy thanks for the kind words! I really used the bike as a learning lab - first time using a proper gun, using 2k colors, doing a multi color job, painting a cfk fork, using an airbrush to fix chip damage, etc.
Given the circumstances I was working in (a very moist, dirty and dusty cellar hole) I'm happy with the result, it's my beater bike and I may redo it next winter for funsies.
And yes I did spend a lot of time masking off - not as much as for sanding though hehe.
I did rattle can paint jobs before but with a gun it just is so much nicer. Also the Iwata uses almost no paint at all. I bought 0.375l cans of each the blue and green and I could paint another 5 bikes with what I've got left.
With rattle cans I always needed 2 cans per frame and the frames looked like the plastic coating one can find on plier grips
#134
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Paint is finished and some of the lettering done as well. I have chosen to paint the lettering as opposed to decals. Still need to clear coat as well. Anyone have thoughts on cable housing? Thinking on sticking with white.
#135
Quoted: 227 Post(s)
Liked 390 Times
I tend to play it safe with colors so can only recommend black or grey housings.
#139
Bikes: Currently: Tommasini Sintesi, Concorde Astore (OTW), Gazelle Champion Mondial (1979)
Liked 7 Times
A lot talent in this thread. Anyone painted an 80's team livery?
Regards
Johnny
Regards
Johnny
#140
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
I bought this 1981 Fuji S12-S LTD last fall for a winter project and finished it last Sunday. It had a rough respray and I didn't care for the original color, so I chose cobalt blue metallic Rustolium with a clear coat. New decals from Velocals. Some of the original parts were missing, so I did the best I could with what I had in the bin. 32 miles this morning showed it was worth the effort.
1981 Fuji S12-S LTD
331 Chromolly frame
Before: Rough rattle can paint and homemade decals.
1981 Fuji S12-S LTD
331 Chromolly frame
Likes For Pompiere:
#141
Friendship is Magic
Bikes: old ones
Quoted: 26412 Post(s)
Liked 10,378 Times
Before "before" it was a frame that showed up as a donation to the co-op..
...after
...before
Likes For retrofit:
#147
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
I painted this with Krylon Jade , It's satin . Then clear coat , came out nice and glossy . I never compared it to a stock Bianchi paint from the time period . I liked it though .
IMG_0674 by mark westi, on Flickr
Likes For markwesti:
#148
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
DIY spray can job using Montana Gold brand on this rusty GT. Before, during and after. Tried my hand at fades but got too ambitious and ended up with Ariel’s bicycle Under the Sea. Scrapped it all, started over and went for a solid pink. Just sold it off this weekend.
#149
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Here is a '87 Ciocc Designer 84 that I painted a few years ago. DuPont urethane base coat (Porsche Guards Red), then clear coat. Decals from Cyclomondo. ~2000 miles later, the paint has held up really well. That said, I think the best part of this picture is the tractor seat mounted on a bar stool. It was my Dad's.
IMG_1832
IMG_1832
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
#150
Quoted: 1372 Post(s)
Liked 1,751 Times
In post #61 I showed a couple of bikes I painted myself and one in progress. Since then, I completed the one in progress...
And, using a brush, painted another one. They both turned out great, in my opinion...
