Preferred Youtube video(s) for basic fitting?
There are approximately 9,975 youtube videos on bike fitting, including videos telling me every other method is doing it wrong and everything anyone else says is a myth. There is contradictory information, and videos implying you can't get a good fit without going to Cat 1 physical therapist with 20 years of bike fit experience and $10k in motion sensor hardware.
I"m pretty overwhelmed and suffering from paralysis from analysis.
What's a good video or videos on bike fit? I'm just trying to get close for now - since I suspect a professional fit is in my future.
Thanks.
Thanks.
just another gosling
Quoted: 3340 Post(s)
Liked 1,274 Times
Thanks.
Thanks.
https://www.bikeforums.net/21296948-post3.html
which can get you started.
There's also another DIY thing: Google bikefastfit. It's an iPhone app. There's a review of it here: https://www.dcrainmaker.com/2013/10/...comment-page-4
There's also a way to get the app to work on an Android phone, here: https://baixarapk.gratis/en/app/710935084/bike-fast-fit
If you're going to be your own bike fitter, might was well go about it methodically. It's just about getting your joint angles within ranges which have worked for most people and getting balanced on the bike at the same time.
Results matter
Results matter
Likes For BigSilver:
OM boy
Bikes: a bunch
Quoted: 282 Post(s)
Liked 291 Times
not really having watched many (more like 5-6) videos on 'fitting' position to a road bike.
I can only help on reducing that number of 'possibles' to a more manageable level...
If, the first thing they do, is anything else but NOT discuss how you should take your important body dimension measurements.... knock that video out, don;t bother going further...
Ride On
Yuri
Ride On
Yuri
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 93 Post(s)
Liked 163 Times
My input, no matter which guide/video/random internet advice you pick, stick to only one until you determine whether or not it works for YOU (hint: this takes time as you adapt to new positions). IMO nothing worse than trying to combine multiple (and often conflicting) simultaneous fit guides into your personal use case.
Also - don't make large position changes all at once, if you follow a guide that says your ideal saddle height is 25 mm different than present, make several incremental adjustments to get there over a period of time, don't do the whole adjustment at once.
