Bicycle Weight limit: does it include bicycle weight?
Old 06-29-22, 11:24 AM
lazurm
Quoted: 12 Post(s)
After searching for its definition via Google I can't find a definition for bicycle weight limits in terms of whether the definition includes the weight of the bicycle or not.
So, if the weight limit is 275 pounds, is that 275 pounds added weight or 275 pounds including the weight of the bicycle or is the definition something else?
lazurm is offline
Old 06-29-22, 11:30 AM
AlgarveCycling
Quoted: 167 Post(s)
Liked 291 Times in 163 Posts
My Wilier has a weight limit of 176lbs. Wilier are clear that this includes bike, rider and accessories combined. My Trek is 275lbs but it is also a combined weight according to Trek.
AlgarveCycling is offline
Old 06-29-22, 11:41 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 6532 Post(s)
Liked 6,871 Times in 3,518 Posts
176 lbs? Geez! Don't take that second water bottle.
genejockey is offline
Likes For genejockey:
Old 06-29-22, 11:53 AM
AlgarveCycling
Quoted: 167 Post(s)
It is low!
I come in at 156lbs combined. The bike is only 13lbs so it came with low weight strings attached to get the warranty at the time.
It's done over 13000 miles and I've taken it off-road on gravel a few times too; seems to be holding up!
Old 06-29-22, 11:54 AM
phughes
phughes's Avatar
Quoted: 766 Post(s)
Liked 831 Times in 485 Posts
This is a question for the manufacturer. Surly says their weight limit of 300 pounds is the rider and cargo, not the bike as well. I would venture to guess most manufacturers list their weight capacity that way. To do otherwise is odd, but some may list it including the bike. Sort of a dumb way to list it if you ask me, though of course no one did.
phughes is offline
Likes For phughes:
Old 06-29-22, 12:10 PM
phughes
phughes's Avatar
Quoted: 766 Post(s)
I just looked at Trek's site, and looked for a weight limit. On their Cruiser Lux 7D Step Thru it says. "This bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg)." Seriously a bizarre way to specify weight capacity, but then again, people ass different seats, etc.
Once again, ask the manufacturer.
phughes is offline
Likes For phughes:
Old 06-29-22, 12:23 PM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Quoted: 4639 Post(s)
Liked 3,144 Times in 2,190 Posts
I'd ask the manufacturer. I don't know of any standards for such that every bicycle manufacturer must abide by.
Iride01 is online now
Old 06-29-22, 12:34 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 SoftRide, 1989 Klein
Quoted: 709 Post(s)
Liked 585 Times in 363 Posts
Unless it's a super-light build, like AlgarveCycling's Willier, or a bike that's got a lot of carbon bits on it, usually the wheels are the limiting factor as far as weight capacity goes.
For a 'typical' road or touring bike, the frame weight is a pretty small fraction of GCVW, so it really isn't much of a factor, but if you're talking about an e-bike or cargo bike, with a much more substantial frame (75-100# isn't uncommon) then the weight of the bike itself should be taken into consideration.
Keep in mind, too, that for recreational / utility bikes, the weight limit will have a lot more of a 'safety factor' built in than a light-weight, high-performance racing bike.
Ironfish653 is offline
Old 06-29-22, 12:38 PM
njkayaker
Quoted: 3603 Post(s)
Liked 979 Times in 683 Posts
Any indicated weight limit is going to be conservative. That is, the "real" limit is likely going to be substantially higher.
It's not like it's going to be "fine" at exactly 275 lbs (or less) and break at 275.1 lbs.
njkayaker is offline
lazurm
Quoted: 12 Post(s)
Answering my own question: the great majority of bicycle's weight limit excludes the weight of the bicycle. So, the weight limit is rider (and items carried by the rider, including clothing) and cargo. In addition to calling my bicycle dealer I also read this here: https://www.thegeekycyclist.com/tips/weight-limits/ .
However, in confirming the other definition (written here in the comments) I'm still not 100% certain for my bicycle (the Specialized Creo SL but with 700x38 tires).
lazurm is offline
Old 06-29-22, 01:27 PM
livedarklions
High Performance Noodler
livedarklions's Avatar
Quoted: 7054 Post(s)
Liked 7,132 Times in 4,005 Posts
Sounds more like a Won'tlier than a Wilier.
livedarklions is offline
Likes For livedarklions:
Old 06-29-22, 01:32 PM
genejockey
genejockey's Avatar
It's stretch, but I'll allow it.
livedarklions
It is low!
I'd break it just by the weight of my gaze.
Amazing you can ride that on gravel. How does it feel?
Old 06-29-22, 01:39 PM
zandoval
zandoval's Avatar
Quoted: 527 Post(s)
Liked 801 Times in 523 Posts
I wonder what component we are really talking about.
Frame Failure
Spoke Failure
Hub and Wheel failure
On what terrain
Maybe a little common sense. I am not going to get my 250 pounds on a nice carbon road bike with 28 spoke wheels and ride on one of my local torn up asphalt roads.
zandoval is offline
Old 06-29-22, 01:51 PM
genejockey
genejockey's Avatar
Frame Failure
Spoke Failure
On what terrain
Ah, you say that, but I had a custom wheelset built 28F/32R, at the builder's suggestion despite being about 220 then (and more subsequently, though less now). and in maybe 10,000 miles they haven't even needed truing.
Old 06-29-22, 02:17 PM
AlgarveCycling
Quoted: 167 Post(s)
I'm pushing it by taking it on gravel with its 25mm tyres. I do have to be careful, I can't ride it like I would on the road - or, at least I don't want to try. It's just that there are a lot of gravel roads near me so sometimes I'll take one.
But, it seems to handle ok, easy to flick about, accelerates rapidly and not uncomfortable.
Likes For AlgarveCycling:
Old 06-29-22, 06:15 PM
Rick
Quoted: 411 Post(s)
Liked 262 Times in 171 Posts
I asked the manufacture of our new ebikes and was told that the wheels are mostly the issue with more weight. So I ordered Ryde Andra 40 rims and Sapim Strong spokes. I have a Carla Cargo Trailer to haul the groceries, dogs or both.
Rick is offline
Old 06-29-22, 08:01 PM
mschwett
please no more flats
Bikes: aethos, creo, vanmoof, public ...
Quoted: 492 Post(s)
Liked 574 Times in 325 Posts
itís a bit ironic that some of the weight limits include the bike Ö but they donít tell you how much the bike weighs 😂😂
mschwett is online now
Likes For mschwett:
Old 06-29-22, 08:03 PM
phughes
phughes's Avatar
Quoted: 766 Post(s)
Once again... Ask the manufacturer. You are searching for everything but the answer, then guessing.
phughes is offline
Old 06-29-22, 08:23 PM
phughes
phughes's Avatar
Quoted: 766 Post(s)
I'll give you a hint. Owners manual... Appendix A.
phughes is offline
Old 06-29-22, 09:05 PM
70sSanO
70sSanO's Avatar
Quoted: 1709 Post(s)
Liked 1,788 Times in 1,108 Posts
Originally Posted by mschwett View Post
it’s a bit ironic that some of the weight limits include the bike … but they don’t tell you how much the bike weighs 😂😂
Or what it really weighs. Especially in a rideable configuration.
And… “Oh, you’re not riding the 46cm frame?”
John
70sSanO is online now
Old 06-30-22, 11:20 AM
phughes
phughes's Avatar
Quoted: 766 Post(s)
The answer is in the OP's user manual in Appendix A. If the OP doesn't have one, they can get it online from the manufacturer's site. The OP though would rather look ask others to look, and look for themselves everywhere but the most logical place, the owner's manual, or the manufacturer's website. The OP now claims they have the answer, which they found themselves, but it really isn't the answer since they found info about "most bikes," then guessed based on calling the dealer. The info they are using to extrapolate the answer is incorrect, based on what is found in the OP's owner's manual. So, no OP, you haven't answered your question, at least not correctly,
phughes is offline
