Frame/Cassette gap Tiny Dork Disk ???
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
I'm pushing the rated Capacity of my Shimano Di2 drivetrain and twice now I've dropped the chain between the frame and cassette.
Is there a tiny Dork Disk for the Frame/Cassette gap?
Google has failed me. And believe me I searched rather than come here and ask questions about Dork Disks!
Not tough to make, but a purchase would be quicker.
Thanks
Barry
Thanks
Barry
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I'm not all that familiar with Di2 but I hope to learn something here. Can I assume that you don't have hi and lo stops to set with the electronic setup?
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
But by pushing the RD Capacity over the spec's, lack of chain tension can become an issue.
Di2 full sync stops me reaching the 34t - 11t combo, so no problem there
But the 50t - 11t combo + a good bump + light pedaling and the chain has jumped into the gap beyond the 11t cog.
Barry
OH, and I do know a bent hanger can also be a cause, so I've accurately reset the alignment.
I don't think the bozo that installed the new hanger (me) ever aligned it from new.
Likes For Barry2:
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Di2 has the same H,L stops as the mechanical derailleurs.
Barry
Barry
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
Mix-n-match compatibility of Di2 offerings is a bit of a mystery to me.
I'd have to go with RD-RX805 to have a clutch and I don't think that combo'ed with an FD-R8050 is D-Fly compatible.
A $5-$10 disk/bushing is far more attractive.
Barry
Barry
Likes For Barry2:
Quoted: 645 Post(s)
Liked 797 Times
you could probably fit a thin disk under the cassette lockring, however a plain flat disc would likely not allow sufficient chain clearance in the 11t, so you'd have to offset it somehow. Someone with some metal fabrication capability could probably make something like this pretty easily
Some old 5 or 6spd freewheel Schwinn bikes had a double dork disc on both sides of the cogs. Don't think I've encountered that setup anywhere else.
https://www.ebay.com/itm/15453675606...Cclp%3A2334524
Likes For wesmamyke:
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
Likes For Barry2:
Hello
Thanks
Barry
Thanks
Barry
Search for a "spoke protector" with a diameter some value slightly bigger than your cassettes biggest cog.
Example: Here is a 5.5" diameter spoke protector: https://www.amazon.com/Sunlite-Casse...NPWQ9DXYJYNBFG
None of my current bikes have a spoke protector, However I had a road bike with a small un-obstrusive disk that I just left on, even though I compulsive about ensuing my limit screws are set properly
LR÷P=HR
Quoted: 864 Post(s)
Liked 1,198 Times
