Can tires "grow" over time?
I have spent a fair amount of time restoring/modernizing a Specialized Sirrus from 1987. When I went to put the 28mm tires on it I had thought I would, I discovered there's nowhere near enough space for them under the rear brake bridge. I then replaced them with some 25mm tires, and I thought all was good. There was a very, very small amount of clearance (~1mm) but it cleared the brake bridge.
I haven't ridden much in the last few weeks, but I got it out and noticed that not only is the clearance completely gone, but the little bulge under the brake bridge has been worn down considerably. Despite this, the tire, which was not rubbing a few weeks ago, now rubs on the brake bridge (which is actually worn down a bit, which should provide MORE clearance).
How is this possible? Can tires "grow" over time? What happened to my clearance? It's gone from having 1mm of clearance without rubbing to having rubbed off a significant amount of steel and despite the additional clearance that should have provided, is now rubbing when it didn't.
I guess the simple fix is to replace this replacement tire that has less than 100 miles on it with a 23mm tire and hope for the best. It's like the frame is shrinking or something. I can't explain it.
Great. And I wisely chose a model of tire that only comes in 1 size: the Continental Grand Prix Classic. So I can't just get a narrower rear tire and pretend they match. Ugh.
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 41 Post(s)
Liked 55 Times
I sort of had a similar situation on my '97 trek 370 with a Specialized Tracer Sport rubbing the chainstays. Found out that by lowering the tire's pressure to my safest low (45-55psi, depending on surface/terrain) I'm able to ride without the issue (and, although the resistance has increased, so has the comfort). Maybe try this first and see?
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 364 Post(s)
Liked 456 Times
Yes, tires can grow a little over tire or change shape slightly.
I had a Gatorskin on the front of an old 27" Schwinn Traveler. I guess the wheel the slightly out of true and the tire grew a little, and one ride I heard the tire rubbing once per Revolution on the top of the fork. About a minute after stopping my ride the tube exploded. My guess is that light rub caused enough friction to heat the rubber in that spot.
Quoted: 83 Post(s)
Liked 64 Times
They do stretch, height and width, more so with high pressure. FWIW - Helped my daughter build & repaint an ‘88 Sirrus from a garage sale into her fixie. We could only fit 23’s.
I think I'll run them at 100psi for now instead of the 120psi on the sidewall. If all else fails, 23mm tires will have to be ordered.
Quoted: 667 Post(s)
Liked 529 Times
Any chance the whole wheel shifted slightly? I take it no adjustment is possible in the rear dropouts?
Likes For Pop N Wood:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
One other consideration is that tires back in the 80's and 90's often measured small, like a 700x28C might actually measure 24mm, or a 700x25C might have only been 21mm! Nowadays, tires measure truer to their nominal size, so the crusty old tires on the frame (or the "700x25C" Specialized Turbo listed in the catalog) might not be a good indication what'll actually fit now...
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
Also, why not file your brake bridge a bit?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Quoted: 835 Post(s)
Liked 1,053 Times
You could buy/make your own dropout spacers to give a little more room. You would only need a few millimeters spacing. https://www.ebay.com/itm/Rear-Drop-O...item1ea3ad0428 I believe your bike has vertical dropouts which will also work with spacers.
Really Old Senior Member
Quoted: 194 Post(s)
Liked 204 Times
I have not done the math, but since older bikes sometimes get stretched to fit in newer, wider rear hubs, would this affect the clearance by much?
Liked 2,560 Times
Quoted: 4194 Post(s)
Liked 2,911 Times
How tight is your rear skewer? I had one that I I thought was tight enough, but was using an adapter to pull a trailer and it didn't "bite" leading to the wheel getting unevenly pulled forward in the dropouts (on the drive side) and rubbing the NDS chainstay.
Good thought, but I'm pretty sure the OP's bike has horizontal dropouts. I can't find a 1987 catalog, but the 1988 catalog shows horizontal dropouts: https://www.retrobike.co.uk/gallery2...PQ4BN.jpg.html
To answer your question, though, my skewer is almost too tight. The powder coat paint is super, super slick and if I don't crank it down tight, it will slip. This is not the issue unfortunately.
The joys of a vintage bicycle.
I did have to cold set the rear out from 126mm to 130mm. 4mm more width would only shorten the effective seat stay length by a fraction of a millimeter. Pretty much impossible to detect.
In all seriousness, I confess I did file the brake bridge down a bit. There's a lot of steel there, and it mostly needs the strength in the forward/back direction, so I figured a couple of millimeters of steel filed off the bottom of the round bulge they brazed into the brake bridge isn't likely to do much of anything. I have clearance now. I just need to find some touch up paint!
Likes For williamskg6:
bike whisperer
Liked 716 Times
Liked 2,560 Times
bike whisperer
Liked 716 Times
That's not a coincidence, since it's the cleverest option by far
Likes For Kimmo:
