9 speed shifting problem
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
I have two 3x9 speed bikes, both mountain. One shifts perfect, one doesn't like the 4th from the bottom cog and shifts past it every time on the stroke up or down. swapped wheels and the problem shifted bikes swapped cassettes and the problem stayed with the XT CS M750 9 speed cassette. (used when it came to me) what are the odds that someone respaced it for other than mountain use?
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
If the cassette is used it is probably worn out at least in that cog, I would just toss it and get something new. There is no more troubleshooting needed it is an old used cassette of unknown usage. XT or not it is a wear item that just needs replacement. Luckily you can still get CS-M770s which is the latest XT 9 speed cassette if you want to keep it XT otherwise PG-970 or 950 will work.
Likes For veganbikes:
Likes For oldbobcat:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 971 Times
Likes For georges1:
