I bent the nut on the valve and it came off. Can I ride?
Quoted: 12192 Post(s)
Liked 1,495 Times
I want to commute manana. After I pumped the tire up, I managed to bend the valve nut while taking the nozzle off.
I really need to get a different nozzle put on that.
Anyway, I was hoping to commute by bike, is the idea nuts? Pressure seems to be holding.
Bikes: Something Canadian, something Italian, something American, and something German
Quoted: 64 Post(s)
Liked 16 Times
Valve nut? The ring that screws onto it so it doesn't get pushed into the rim?
Bikes: Trek Madone 5.5, Klein Q Pro Elite, Surley LHT
as long as the tube is holding air you should be ok. If you are concerned replace the tube. I would replace the tube as you will not be able to put air in.
Liked 1,495 Times
Thanks, I need to go to the bike shop anyway, so it looks good to go.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
The nut on the presta valve serves as a valve lock. It keeps vibration from letting a little of the air out on each bump. You will be fine but may have the tire go soft a little faster than normal. When you fill other tubes in the future, don't back off on the nut so much. It's only necessary to unscrew it 12 to 1 turn to let air in.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
It'll hold long enough to ride down to the bike shop and get a couple of tubes. Always have a spare so you don't have to wait to hear back from Bikeforums because it's 9:30 at night.
