FS: Motobecane cockpit
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Hello Moto lovers looking for the perfect turkey lever, plasti-grip ready-command center.
Weinmann levers, SR stem and Pivo bars...no bends. Barely scratched grip and not much wear...they must have made those to last.
How about $40 plus shipping? If anyone has a really good idea for shipping them cheaply I am all ears.
Ooo....nice
Will polish well, methinks.
Ooo....nice
Edumacator
Liked 3,119 Times
Also,
Might have a DS Motobecane Takagi crank arm/rings, Weinmann Vainqueuer CPs, and Sun Tour ratcheting shifters depending on the owners preferences for rebuild. PM if interested in the original items, and I will let you know.
This is from a 1978 MB GT that is being converted to a straight bar gravel/road hybrid.
Edumacator
Liked 3,119 Times
No one needs a conversion van unit? Make me an offer!
Edumacator
Liked 3,119 Times
I can check that for you. I hate to cut through that beauteous plastic though...
Quoted: 767 Post(s)
Liked 1,898 Times
No worries if not. If so, let me know what you want for it.
Maybe someone else will come along and want the whole package.
edit: Just remembered, that setup likely has threaded inserts instead of brake lever clamps. If so, the stem can't slide off without destroying the rivnut.
Edumacator
Liked 3,119 Times
Quite the dilemma, I know.
Edumacator
Liked 3,119 Times
Bump to see if anyone wants this and the DS Motobecane crank (Takagi)
Quoted: 1106 Post(s)
Liked 1,326 Times
And those brake levers might well have a band, the pic shows what looks like a bit of a bump where the band would be; would be pretty easy for the op to tell.
Edumacator
Liked 3,119 Times
That plastic sleeve will slide off. It takes some doing, and a can of lube with a spray-tube, but it'll come off, mine did. Went back on the same way.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
I wonder what procedure was used to instal these?
Ben
Ben
Voltaire
Voltaire
Edumacator
Liked 3,119 Times
Sent to Satan's demons for installation using the sludge from the bolges... then sent to those of us in the 6th circle of Dante's Inferno as punishment for using Cateye cellotape instead of Benotto.
Honestly, I think heat to expand the plastic then in cooling it shrinks.
Liked 1,326 Times
There is a trick to using the spray-lube tube. You want to get lube as far down as possible, so open a gap at the edge of the wrap and force the tube by itself into your gap and as far as you can get it. THEN attach the can and give it a squirt. Take off the brake levers entirely, leaving only the band, stick the tube in from there as well.
