View Poll Results: What should I do?
Repair crank with current L pedal (So both pedals Left)
1
4.00%
Repair crank with new pedals (R + L)
4
16.00%
New crank with new pedals (R + L)
20
80.00%
Voters: 25. You may not vote on this poll
New pedals stripped crank
Quoted: 10 Post(s)
Hi, wondering if someone could advise..
I recently bought 2 new pedals for my pinarello bike. They arrived as both LEFT pairs, I didn't realise this until cycling and the R pedal kept unscrewing itself and falling off.
I then tried to replace my old pedal, but this didn't fit in the crank, so I think the crank has been stripped.
I'm not really sure how to proceed, I would guess my options are the following:
1) Repair crank with current L pedal (So both pedals Left)
2) Repair crank with new pedals (R + L)
3) New crank with new pedals (R + L)
Any advice appreciated!
Travis
Travis
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Wait...how does this happen? What kind of pedals are they? How could you not notice the left pedal was nearly impossible to get into the right crank arm?
Likes For cxwrench:
Quoted: 303 Post(s)
Liked 136 Times
As above, the mind boggles, it would take incredible persistence and determination, to say nothing of the torque needed
after 2-3 turns and a strange blindness to the bits of aluminum falling out of the end of the crank for this to have happened.
Best have a qualified bike mech look this over and verify what happened. Best approach would be having the crank
repaired with an insert and the pedals replaced IMO. Scatological terms not available, it is nearly impossible to thread
a L hand thread into a R hand receptacle without so much force being needed that......
Another ? if pedal is cleated then how did the OP ride, the cleat would have been backward on one pedal...
Absent some pix maybe a troll hunt is in order. BMX pedals on a pinarello?
Another thought: a more likely by far scenario than getting a L male thread into a R female crank is that
the OP simply cross threaded the pedal when it was screwed in. This requires significantly higher torque
than properly screwing in the pedal but still a LOT less torque than driving a L male into a R female which
would be extremely difficult to get started as the threads would never engage.
Likes For sch:
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,381 Times
Bikes: lots
Liked 2,932 Times
One screwed in fine and the other was a massive effort...and you didn't think that was somehow weird?
Likes For cxwrench:
Quoted: 211 Post(s)
Liked 198 Times
I think I would bring it to a bike shop and have them repair it. Depending on how bad it is, shouldn't be too bad.
If you do bring it in to the shop, I would clean the bike first.
Good Luck and keep us posted !!!
Likes For bikemike73:
Quoted: 2304 Post(s)
Liked 2,742 Times
option 2 or 3.. options 1 you will have the pedal falling out all the time if it is even feasible
and I do not want to arm wrestle with you
Quoted: 10 Post(s)
Hahah thanks for the advice. It took a bit more effort to get the R pedal in, but it still went in... so I didn't question it... until the pedal fell off.
Is rethreading quite a big job then? I think I'll get a fresh set of pedals...
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
Bikes: lots
Liked 2,932 Times
A 'bit' more effort? C'mon, it doesn't happen like that. You're basically cutting threads with...threads. That doesn't happen easily.
Likes For cxwrench:
Generally bewildered
Quoted: 1152 Post(s)
Liked 340 Times
Unless the threads were non-standard, the effort of threading a 9/16x20tpi LH into an RH or vice versa would be huge.
Droid on a mission
Quoted: 316 Post(s)
Liked 276 Times
The (right) crank arm may need a heli coil or replacement arm I wouldn't trust just a rethreading.
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
Something in this story is wrong.
I can’t see how it would even be possible to get the wrong pedal screwed in past the first few turns. Pretty sure my wrenches would break or strip where they grab the pedal before the pedal went half way in.
And even if you did manage - through the use of a breaker bar, pipe wrench and a vice, maybe -to screw it in, it would never come loose without the same breaker bar and vice.
Get a new crank arm and set of pedals.
Likes For Kapusta:
I had to helicoil two cranks this summer at the shop for the exact same blunder! Is it something in the food we eat? The air we breathe? The vaccine? LOL no matter what it is, seems to be a thing this year.
Liked 2,742 Times
looking at you pictures I would suggest finding a replacement cranks set and ensuring that you have a right and a left pedal
Quoted: 6100 Post(s)
Liked 4,732 Times
Options 2 or 3 are the best, IMO.
If you repair the crank then take it to someone that knows how to properly insert helicoils. And it needs to be a left threaded helicoil. Some bike shops might not have experience with helicoils nor may they even have a left threaded tap. So if they have to buy the tools, then they'll probably charge you more. So try to find a shop that has done this before and since they'll probably still have the tools it won't cost as much... hopefully. Nor do you really want a noob installing your helicoil.
You might also find a local machine shop or job shop that has experience with helicoils, but they might be more unlikely to have a left threaded tap.
You might find it just as inexpensive to get a new crank if you can find one. Either way you need a left side pedal. Are the people you ordered from going to send you one?
Option 1 you don't want to consider at all unless you always pedal backwards. Normal pedaling will might loosen a right threaded pedal on the left side. I lost the link to a very good motion graphic that explains and shows why.
Quoted: 476 Post(s)
Liked 575 Times
Happens more than one would think. I've seen them inserted all the way in. Had an English cup in an Italian bb and vise versa too. The power of YT video experts I guess, It's all good, makes me money. We don't do thread inserts, new crank. 27.2 seat posts in a 27.0 seat tubes are fun too.
Likes For wheelreason:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 958 Times
When working on bikes, NEVER force anything and whenever possible, thread parts by hand (no wrench until final tightening), At this point, find a replacement drive side crank arm, ebay, bike co op, or whatever.
If something is giving you resistance, stop. Don't grab a wrench and force it. Steel pedal spindle into an aluminum crank arm, you have seen what wins. Helicoil repairs work, but are often more costly than replacement.
Likes For wrk101:
Quoted: 2430 Post(s)
Liked 2,891 Times
As suggested earlier in the thread but not yet confirmed, trrrrrev almost certainly cross-threaded a (correctly threaded) right pedal when installing it into the right crank.
Friendship is Magic
Bikes: old ones
Quoted: 26251 Post(s)
Liked 10,232 Times
...for an alloy crank like the one you show in the photo, the only repair that will work long term is to bore out the pedal mounting holes a little larger with the appropriate ream and tap, so that either a threadsert or a helicoil can be inserted. The stuff to do it is available on the web, but given what has transpired thus far in your adventure, your best bet is to call around and see if anyone does these repairs local to you.
I have done them for myself, and over at the bike co-op for people locally. I don't do them for other people any more.
Anyway, when you talk on the phone, ask if they do helicoil or threadsert repairs to alloy crank pedal holes. Without that, I fear your crank is more aluminum recycling fodder.
Liked 4,732 Times
None of you chastised me for this! What's becoming of BF? Is this some new tolerance for the mistakes of others or are y'all just use to me rambling incoherently about absurd hallucinations I have? <grn>
Friendship is Magic
Bikes: old ones
Liked 10,232 Times
...I missed it because I was listening to "Rage Against the Machine."
Quoted: 581 Post(s)
Liked 921 Times
I find it hard to believe, as I am sure many others do, that a L threaded pedal was 'accidentally' threaded into a R handed thread crank. Unless I see a picture of two identical pedals both with L threads I don't believe it. Much more likely the R pedal was just not threaded in straight and was not fully threaded in, leading to it pulling out the threads of the crank.
Likes For ClydeClydeson:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
