So. New England Winter Cycling Question
I'm feeling lazy about putting on the winter tires this winter. Do I really need to put them (Cost: $50 for labor plus a possible tune up costing $$$)
More Detail
* These past 5 winters have been mild!
* I only cycle once a week for groceries
* When I go out and cycle, it's daylight and it should be 0C / 32F out
* if it's brutal out I can always grab an uber
Other side of the coin:
* There's usually white ice on the road all winter
* Uber can add up really quickly
I'm wondering, do I really need the expense or better safe than sorry?
More Detail
Sr Member on Sr bikes
I live in coastal RI. Can’t tell you if you really need to change (I don’t but I’m strictly a road cyclist). But if you want the tires on…this is really 30 minutes or less job.
Dan
Dan
Thanks Dan! Whenever I try to change a tube, a get a flat almost immediately. That's about when I give up and call the mechanic. is there a source you can point me to in terms of how to change a bike tire?
Quoted: 358 Post(s)
Liked 136 Times
I'm in the same boat. I live in CO and man it gets cold and Snowy here. Studded tires are worth it. Ok, they are costly but worth it. Maybe you can find "almost new" tires on E-Bay or somewhere else. Check with your LBS. I often look through their scrap pile for bargains. (You never know what you will find.)
Quoted: 817 Post(s)
Liked 1,651 Times
"Black Ice" is one of the most dangerous situations you can encounter on the road. Dumping your bike on a patch of black ice while returning from your grocery run could mean more than a few broken eggs. You could end up in the middle of the road, and those vehicles coming towards you won't realize that THEY are on the same patch of black ice, and cannot stop or turn to avoid you. Usually, the snowbanks from the plows along the side of the road make the streets narrow anyway, so your options are limited.
Check into grocery delivery services. They may be less expensive than Uber, and would definitely be safer and more convenient than riding.
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
I've been cycling for over 20 years in northern NY winters and I've never run winter tires. Just 26" wheels with cruiser tires.
Changing bicycle tires is easy and anyone can do it.
When you say winter tires, do you mean studded tires? I guess if you have ice, either black ice or white(?) ice, studs might be necessary. I don't ride on ice, and I don't really like salt, so there are days I don't bike.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4376 Post(s)
Liked 3,013 Times
Mounting "winter" (=studded?) tires is hard, for sure. It's those thick sidewalls that get me. I struggle with it, and it takes more than 30 minutes. Definitely.
Though it hasn't ever occurred to me to pay somebody else to do it.
Now, were I to get a flat tire out on the road, I don't think I could manage it. The tires are super-hard to mount indoors, when they are warm. It's that much harder when the rubber is cold. And my hands.
Fortunately, I've never had a flat with studded tires. Road debris is less of an issue when there's snow on the ground. Pinch flats could happen, I s'pose.
Quoted: 5224 Post(s)
Liked 3,581 Times
if it isn't dangerous, it isn't fun. just kidding. ride 'em if you got 'em
but I hear ya. I do the same internal argument for my car's winter tires
Thanks everyone! I took your advice, I put the studs on ... myself this year !!! with a $$$ ton of savings. If it works, it's a Christmas miracle.
So I just wanted to say thanks to everyone, especially Force D, because the Park Tool video was very helpful! Thanks, Dan!
Likes For parkbrav:
