Leaving single pawl in a 120pt Chosen hub for noise reduction
Since I'm unable to find any similar wheels with cartridge bearings in similar price range then the last option (after trying out PFPE miracle grease which is supposed to last way longer due to good wetting ability on metals (low surface tension)) is to go with a single pawl instead of three. Some people on forums said that they "don't see the reason for more than one pawl from mechanical standpoint other than to fallow the trend of increased noise level, anyone who thinks otherwise has been skipping engineering lectures, more pawls will just accelerate the wear of engagement ring".
These pawls with multiple teeth seem to have the load spread over wider area anyway and the teeth are too small to break, seems like they can only wear down.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
A single pawl puts all the load on that one pawl. Three pawls can distribute the load over all the pawls, even better than four pawls (think of how a three-leg stool automatically sits without wobble, while a four-leg stool will wobble unless the legs are precisely the same length).
Quoted: 6191 Post(s)
Liked 4,806 Times
I guess if I ever have a freehub or freewheel wear out, maybe I will start to be concerned about such stuff.
Quoted: 1818 Post(s)
Liked 1,693 Times
Read this article, describes a painful crash during the Giro a few years ago caused by removing pawls from a freehub
https://www.velonews.com/gear/road-g...lost-the-giro/
Likes For alcjphil:
Quoted: 2026 Post(s)
Liked 1,096 Times
If you are looking for a quieter hub, get Shimano's as they are nearly silent while coasting. My FH-7700 Dura Ace hub makes no noise at all. Shimano even makes a series of hubs intended for Police bikes that are completely silent.
Those who ride Campy, Chris King, etc. hubs claim their infernal racket is a feature, not a bug.
And, no, don't remove pawls from an existing hub.
Likes For HillRider:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Since I'm unable to find any similar wheels with cartridge bearings in similar price range then the last option after trying out PFPE miracle grease which is supposed to last way longer due to good wetting ability on metals (low surface tension) is to go with a single pawl instead of three. Some people on forums said that they "don't see the reason for more than one pawl from mechanical standpoint other than to fallow the trend of increased noise level, anyone who thinks otherwise has been skipping engineering lectures, more pawls will just accelerate the wear of engagement ring".
Likes For cxwrench:
Quoted: 581 Post(s)
Liked 921 Times
This is a stupid idea. 'People on forums' are telling you to remove 66.6% of parts of a critical component of the drive system because they 'don't see the reason' for them? Are these forum people mechanical engineers? Are they sharing the data that they analyzed to come up with this plan?
When I said 'stupid idea' I may have misspoke It's a phenomenally stupid idea.
Likes For ClydeClydeson:
Liked 2,966 Times
if you prefer to walk your bicycle, you can do so & not have to remove mechanical parts.
-Oh Hey!
-Oh Hey!
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
As someone who has gone over the handlebars and landed on my chin due to trying to optimize improperly (and who grew up working in a machine shop and now has a PhD in Engineering) I would suggest that removing 2 of 3 pawls (or any, really) is exceptionally unwise.
I've also broken a dura ace cassette and it's pretty unnerving. If you're willing to risk 13 cracked teeth, and having the doc scrape the dirt out of your broken jawbone, or a broken neck, or your genitals bashed...
If the strength of materials were such that one pawl would hold, that's they way they would have designed it. In addition to leveling the stress on any individual pawl, having 3 of them offers some degree of fail-safety. If one breaks, the others catch you. If using grease instead of oil (the usual approach ) doesn't quiet the hub down enough, get another hub. It's really, really hard (and way more expensive) to get a lot of caps on your teeth as I did.
Expired Member
Quoted: 3660 Post(s)
Liked 5,408 Times
Do you suffer from misophonia or some other affliction that makes freehub noise a major issue? If so, move past your preference for cartridge bearings and go with perfectly silent Shimano hubs. I like quiet hubs when I ride alone but some noise can be useful when others are involved. Give pedestrians or other riders a heads up when you approach.
The cup and cone bearings are hard to adjust just right in general. Shimano now makes few wheels with cartridge bearings such as WH-MT601
using 145mm OLD truough axles and disc brakes only as far as I know. Since I happen to have available rim brakes only at the back of the Thorn Audax Mk3R frame then Shimano is still out of the question. Also couldn't find any videos with WH-MT601 hub sound.
And since I have spare bearings for current wheel already stocked up then buying new wheels is not justifiable.
Quit coasting!!!!!
If those hubs are half as loud in person as they are in the online videos, they make Chris King sound like Shimano Silent Clutch. VERY obnoxious! They would be gone from my bike in one short ride. I can't imagine them on a plastic bike. And I've got pre DT Hugi hubs to remind me to keep pedaling. Interesting technology though. You need the Chosen "Silence" hub where the pawls retract when not pedaling.
Cartridge bearings are over rated for hubs and cup and cone are easy to adjust properly. Shimano sez cup and cone have less friction and are more durable. But more expensive to make.
One of the great joys of night riding IS the quiet-
Phil Wood grease will quiet your pawls..
I have some Lucas engine assembly oil which is supposed to be even more tacky and snotty than Phil Wood Tenacious oil, but it still creeps away in about one hour leaving nothing behind. Grease just gets displeased. Could use ferrofluid as a lubricant if engagement ring was magnetic, but people said it will attract metallic road grit so...
During long rides coasting provides some rest and allows to periodically concentrate on the surroundings since during peddling mind is at more tensed up state. Other reasons are reduced brake usage before stopping and high speed descents where keeping still is safer.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Liked 4,806 Times
If a quiet freehub is desired, why not get a hub with a quiet freehub? Or just do your single pawl thing and not worry about what we say.
Without knowing how that particular freehub is designed, I'm wondering what the asymmetrical forces might do when only one point of the freehub is taking all the load of you pedaling.
Randomhead
Liked 3,693 Times
I use hope hubs and I have gotten so tired of listening to them on long rides that I pedal instead of coasting. This usually takes quite a bit longer than 8 hours for me though. Shimano is a good lower priced option, but I don't know if you can buy them right now. There are silent but expensive options like onyx. There are some others, but nobody has much experience with them yet.
I recommend against loading a freehub up with lube since that can cause engagement problems too.
Liked 1,096 Times
As I see it you have two choices:
1. Buy an inherently quiet hub like a Shimano and learn the not-difficult art of adjusting cup-and-cone bearings every year or so.
2. Learn to live with the noise.
Removing pawls from your current freehub is a dreadfully poor, dangerous idea and grease will be a temporary fix and may cause cold weather engagement problems. I.e. the hub will freewheel both ways.
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 2337 Post(s)
Liked 2,820 Times
Might be misophonia or the harsh noise just adds to mental fatigue/anxiety during longish 3-8 hour rides at night/early morning.
Bikes: lots
Liked 2,932 Times
Quoted: 2482 Post(s)
Liked 2,952 Times
And would a loud single-pawl hub be less annoying than the 3-pawl version? If I'm in bed and a faucet's dripping, it's infuriating whether it's a slow or a fast drip.
In fact:
"In ancient times (and probably sadly in modern times as well), a slow form of torture was used that involved tying someone up, holding them in place, and letting water slowly drip on their head for hours, even days."
In fact:
