Why use foldable tires? Any specific advantage?
Quoted: 206 Post(s)
Liked 38 Times
I just recently became aware of foldable tires. All the tires I've had have had solid wire beads.
Why would someone use a foldable tire? What if any advantage do they have over tires with a solid bead?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
you can fold one up and stow it in saddle/frame bag of some sort. plus, wire beads are stiffer to mount if the rim to tire tolerances are especially tight. folding tires can stretch a bit making it easier in the same scenario. lastly, and it's a minor issue really, is wire beads can rust with age. but, if you ride often enough, you'll wear the tread out before that happens
2-Beads made from foldable fibrous materials generally weigh less than wire beads.
3-People nearly always use folding-bead tires on tubeless setups, because tires designed for tubeless generally use folding beads.
4-Tire manufacturers generally don't make high-end models with wire beads, so if you want quality rubber, the best options usually have a folding bead.
Likes For HTupolev:
Likes For Geepig:
Expired Member
Quoted: 3672 Post(s)
Liked 5,430 Times
First for me is expanded tire choice. As mentioned above, nicer tires aren't readily available with wire beads. Next would be ease of shipping because I usually buy tires online. Final reason would be weight. I can't recall if there is a difference in mounting, it's been a long time since I used a wire bead tire. Nevertheless, if you are content with what you use, all is well.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Why does Costco sell mixed nuts in square-ish plastic jars versus the former round jars? Efficiency in packing and transporting, which equals cost savings.
Quoted: 2604 Post(s)
Liked 1,933 Times
Though you have only asked for advantages, there are a couple disadvantages to folding tires:
1. Generally a bit more expensive.
2. First installation can be a hassle, as the tire wants to fold itself back up while you're trying to wrestle it onto the rim.
Quoted: 6193 Post(s)
Liked 4,809 Times
Foldable are lighter too. Or so I've been led to believe. Hard to fact check that since there aren't any high dollar wire bead tires that I'm aware of to compare with a high dollar folding bead tire.
I'd think most people are on folding bead tires and maybe they just don't realize it. Especially if on a road bike made in this century and sold by other than the big box discount stores.
Quoted: 837 Post(s)
Liked 1,061 Times
Lighter being one of the advantages in addition to everything else mentioned previously. Kevlar or whatever gets used for the bead is lighter than steel.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
Another "apples-to-apples" comparison using Continental Ultra Sport III:
continental bicycle Ultra Sport III (continental-tires.com)
Scrolling down to the 28" (i.e., 700C) models, there is a 70 g difference for the both the 25 mm and 28 mm wide tires.
Likes For SoSmellyAir:
Quoted: 4806 Post(s)
Liked 3,928 Times
1-One advantage of folding beads is that they can be folded. While wire-bead tires can be packed into reasonably small hoops if you know what you're doing, tires with folding beads can be safely packed into an even smaller volume. This is useful for things like storage, shipping, or carrying a spare tire while touring.
I've used near identical Paselas on my commuter. Never weighed them but the folding are clearly lighter. But for a commuter I'll take wired every time. They go from the shop home folded in thirds nicely and that is the only time they'll travel by bike not mounted. They mount easier first time. Yes, maybe more strength required but it is very straightforward every time. And on the road flats are easier because getting the bead seat right is easier. Real advantage at night, in the rain, when my attention is not all there.
The 38c Paselas only come folding. Beautiful tires. Wonderful ride. But my wired 28s are so much easier to deal with in the shop. And brainlessly easy on the road. (Commuter - flats happen,)
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For 10 Wheels:
Liked 1,468 Times
Expired Member
Liked 5,430 Times
Likes For shelbyfv:
Quoted: 1438 Post(s)
Liked 1,092 Times
Did Costco happen to sneak in a size/weight reduction in with the change of shape? Similar tactics have been used e.g. when the US changed its liquor bottle sizes to metric; the bottles all got a little smaller but the price did not go down. Or the "New! Fun Size!" candy bars which seem to shrink year over year.
Quoted: 206 Post(s)
Liked 38 Times
Can you expand on this? What characteristics define a high-end tire? To put it in terms of a tire I'm familiar with, in what ways would a high-end tire be superior to a Schwalbe Marathon Plus?
Liked 2,568 Times
I'd consider the SMP to be a "high-end" tire. It's just that the priorities are not the same between all high-end tires.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
superiority is relative, though. you aren't going to commute on boutique handmade $110 tubular and you aren't gonna race on a marathon plus. iow's...application is the scale.
