Vintage Shimano Compatibility Check
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 270 Times
Hello fine fellows.
Wondering if this XT GS 7-speed cassette will be compatible with my Shimano Ultegra 6400 7-speed derailleur. And is 28 teeth too much for that road derailleur?
Running non-vintage Velo-Orange hubs, hence the need for Hyperglide. Need easier gearing for my beloved Masi.
-Calamarichris in Carlsbad, CA
Thanks in advance for any guidance. Stay well and ride safe
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
By rule of thumb, should be fine - anything (except front derailleurs) Shimano MTB 9 speed and below will work with anything road 10speed and below, except the current 10sp stuff that uses the same cable pull as 11sp - Tiagra 4700 & GRX400.
Shimano never messed with cassette spacing between MTB & road that I know of.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
You should be fine. Might have to mess some with the B screw on the RD to be happy with the 28 tooth rear cog, but indexing should be fine.
All Shimano cog spacing for 7 speed is the same.
Quoted: 389 Post(s)
Liked 270 Times
Thank you kindly gents!
Quoted: 1528 Post(s)
Liked 718 Times
I'm confused - your beloved Masi is rocking ST-6400s, which are 8s.
Quoted: 389 Post(s)
Liked 270 Times
Dammit.
Ah well. Let's see if the Ebay seller has already shipped it. (Hate it when I do dumb stuff.)
I got it confused with my other bike, a Team Stuttgart Merckx that has those same brifters but on Sante (7-speed) hubs. I guess the guy I bought it from must have manipulated the limit screws to get the 8 speed brifters to work with the 7 speed freewheel.
You have a keen eye. Thank you.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Hack
Quoted: 347 Post(s)
Liked 189 Times
Dammit.
Quoted: 1083 Post(s)
Liked 686 Times
According to Velobase, the RD-6400 has a maximum cog size of 28 and max chainwrap of 26. That of course is independent of whether your shifters are compatible.
https://velobase.com/ViewComponent.a...2-d3236e2fd096
Liked 2,568 Times
What?? That is completely wrong.
aka: Dr. Cannondale
Liked 3,402 Times
Shimano:
5 speed and 6 speed = 5.5mm center to center cog spacing
7 speed = 5.0mm
8 speed = 4.8mm.
So…with regard to 8 speed shifters idexing a 7 speed cassette, they are close, but not the same. If you set 8 speed indexing to be perfectly centered in the middle of a 7 speed cassette, it would be off by .6mm at either end.
Which means it might work, but not that well.
7 speed = 5.0mm
8 speed = 4.8mm.
Liked 2,568 Times
Shimano:
7 speed = 5.0mm
8 speed = 4.8mm.
7 speed = 5.0mm
8 speed = 4.8mm.
Hack
Quoted: 347 Post(s)
Liked 189 Times
You're right, I made a mistake there. Though it's not completely wrong that you can make this stuff work together, I exaggerated compatibility quite a bit.
You can use 8sp with 7sp, and 7sp with 5 or 6.
Spacing per gear:
You can use the same trick to use 8sp with 7sp - though they're close enough you might be better off with standard routing, depending.
Spacing per gear:
5 & 6 sp - 5.5mm
7sp - 5mm
8sp - 4.8mm
You can use 7sp shifters with the alternate cable routing described by Sheldon Brown here to pull more cable. (Shimano also publicized this at the time)7sp - 5mm
8sp - 4.8mm
Liked 2,568 Times
Spacing per gear:
Spacing per gear:
5 & 6 sp - 5.5mm
7sp - 5mm
8sp - 4.8mm
8sp - 4.8mm
Hack
Quoted: 347 Post(s)
Liked 189 Times
Likes For Viich:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Shimano:
7 speed = 5.0mm
8 speed = 4.8mm.
7 speed = 5.0mm
8 speed = 4.8mm.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
