Snow
Quoted: 286 Post(s)
Liked 261 Times
Snow
I’ve ridden on snow in one of two ways: first, renting fat bikes and getting out on mtb trails; second, on my gravel bike, on paved/gravel when it starts snowing and you hope you make it home safely.
I would like to try my gravel bike on snow, but I’m guessing everything has to be just right; I wanted to see if folks with more experience riding gravel bikes on snow have tips (including, don’t do it ).
I have all the winter riding gear and ride regularly when the roads are dry/safe.
Here are some things I’ve been thinking of:
- treaded tires with low pressure (I have Rene Herse Pumpkin Ridge, tubeless)
- maybe 1-2” of fresh snow, hopefully no ice anywhere
- get out before others so as to avoid riding over bumpy footprints and other ‘craters’ that make for a jarring experience
- where to ride, hmm, I have two rail trails I can drive to, though both are well used, so I would have to get there early after a fresh snowfall
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
You have good ideas.
Getting out when it is fresh is best (I love going during a storm).
Old snow that has been walked on (or ridden on) is a pain.
Several trails around here are groomed for fat bikes). Not something I'd take a gravel bike on though.
I do like skinnier tires as they slice through the snow (were a fat tire acts as a snow plow, and you have to push the snow away).
Ice can be a problem - I've sprained an ankle and been off the bike for 6 weeks. Its the "clear" patches during freeze/thaw cycles that make the worst glare ice. Its actually better when things stay cold and don't thaw. Do be aware of flat surfaces in depression - these can be puddles that have frozen over with ice then covered with snow. You can't see the ice under the snow, but you will go down fast.
I like Schwalbe G-One, as they don't shed the snow and have surprising traction. snow sticks to itself better than it sticks to rubber.
Keep those feet warm. I use over boots, and there are some pretty effective heated shoe inserts (one time use kinda thing).
Likes For chas58:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
But "snow" can mean a whole lot of different things. Snowy roads like the one pictured above some studded winter tire would be nice. I have a set of studded Schwalbe Marathon Winter tires that do great in just a inch or two of snow, be it fluff, packed down, or icy. Once the snow has any depth, I want my fat bike… but That’s more trail riding than on the road.
Lots of good advice here. I ride my fatbike a lot in the snow, in fact I did so yesterday.
2"-4" of fresh snow is the best.
Fatbikes are marginally better in snow, but you can do almost as much on a regular mountain, cross or gravel bike.
Ice is a much bigger problem than snow. Freeze/thaw cycles are a killer, especially on pavement as the water can't drain away as easily and will quickly refreeze.
Studded tires are a really good idea if you plan on riding a lot in the snow. The Schwalbe Marathon Winter studded tires are really durable, relatively affordable compared to other studded options and offer great grip.
Take care of your bike after any ride in the snow, especially if you ride on salty roads. Use a heavy waterproof lube (I like Finish Line Wet) on the chain and put some of it in all bolts to prevent them from rusting. T9 works great as a rust protectant as well. I like to use a garden sprayer filled with hot water to spray down the bike after each ride and then wipe everything down with a rag and some WD40.
Thread Killer
Quoted: 3132 Post(s)
Liked 1,700 Times
I’ve been riding dirt roads in winter for years, but don’t have a lot of experience, particularly for the fact that I’d choose to go out on those roads when the conditions were pretty good, which is to say below freezing and with a good layer of car formed hardpack snow. Like chas58 , I found the Schwalbe S-One / G-One Allround to be pretty good for that kind of stuff in relatively narrow 30c, which is what my bike, the Kinesis Racelight 4S, would fit at max. I could see that in some conditions I was getting outclassed by those with wider, knobbier rubber, but I managed pretty well. I was a winter commuter, on pavement, for 25 years, so I developed good handling and surface reading skills, which helped out on winter dirt roads. The Kenda Kwick K879 was my go-to winter pavement tire for about 15 years, and what a tire, but that’s another story…
Fast forward to spring of ‘21, when I pick up my first proper gravel bike, primarily so that I could fit wider rubber. This is my first winter, then, on 42c— yeah, I’m still skewing towards dry, hardpack conditions; we seem to get less snow every year!— and I’ve only ridden in dirt road snow twice now, both times quite fresh over a thin layer of mud. I decided to run the Ultradynamico Rosé JFF, and so far, it has handled those conditions just fine, offering more sure-footedness than I remember from the Schwalbe, so I’m happy.
I’d closely considered the American Classic Krumbein before choosing the Ultradynamico, which I did largely for lower weight, but also for that supple casing; I run Herse Bon Jon Extralights for summer gravel, and Switchback on the gravel cruiser, so I’m pretty addicted. However, at just $35/tire, the American Classic rubber is really attractive and makes experimenting with tread patterns and sizes as affordable as it gets for a quality tire. They’re on sale at their AmClassic.com site for $31.50 right now! I guess I gotta go buy something…
Quoted: 5224 Post(s)
Liked 3,581 Times
check the winter subforum, bunch-o-nutz over there ... ;-)
Likes For rumrunn6:
Quoted: 427 Post(s)
Liked 339 Times
Hah, we were just on a snowy gravel bike ride 3 days ago in N Central PA; it was wet slushy stuff. IMHO, riding on a gravel bike in snow is best when early in the season and the surfaces underneath are still a bit warm so no ice has formed and your tires can get down to the traction underneath. Best to avoid ice and deep snow on the gravel bike. You cannot get tires on a gravel bike that are wide enough to stay on top of the snow so better to have a 35 - 40 mm tire that cuts down to the better traction easily, and probably ride a well-treaded cross mud tire with decent cleats. The best thing is you will be the only gravel bike out there most likely and you can dust any fat bikes lurking about!
Quoted: 1088 Post(s)
Liked 1,022 Times
I've taken to studded only; transitioning from a partially clear/partially slushy small uphill in the sun to just over the top, out of the sun, and a complete sheet of ice that took the bike out from under me and caused my head to just brush the guard rail convinced me. If there's snow there's ice somewhere and you go down fast when its black ice you can't see. Studded Hakkas changed everything for winter riding. Though fat bike and low pressure might be different.
Likes For Russ Roth:
Liked 3,581 Times
Advanced Slacker
Liked 2,537 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Once there's frozen water of any kind on the ground, I'm on studded tires exclusively.
Since it only recently snowed in my area, yesterday's ride was good for recalibrating expectations... sections of heavy snow 3-4" deep brought my 1.9" tires to a halt and I couldn't get going again. A fat bike would probably have worked there. Other sections of 1-2" deep heavy snow were doable with some effort.
It's hard to get as many outdoor miles in the winter, but they can really count!
Quoted: 286 Post(s)
Liked 261 Times
I’ve contemplated a fat bike over the years, but here in Ontario (just outside Toronto) we don’t get a lot of snow.
I got out tonight, with lights as it was dark, and it was 5C and the roads were wet, not slippery. It was perfect, and is like half the reason I bought such a bike with wider tires (I wouldn’t have done this ride on my road bike with 25’s). These conditions this time of year are far more frequent than ideal snow conditions.
Liked 2,568 Times
That doesn't stop some folks in my area from riding them all year.
Advanced Slacker
Liked 2,537 Times
Sure, if you are getting out when it is 4+" deep fresh stuff a fat bike is great, but most of the time I'm on roads, they are plowed or packed down before they get that deep.
Liked 1,022 Times
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I found this to be true with my bikes--one has 650bx47 Senderos--very knobby for a "gravel" tire, tubeless, low psi. My bike with 700cx40 Nanos seems to do better!
Quoted: 427 Post(s)
Liked 339 Times
If there is a decent surface underneath to grab then a narrower tire that will cut down to it more easily can often be a better answer. in sand or mud where there is not a good layer to grab easily close under the surface then you want to go the other way and use wider tires...
Liked 415 Times
I rode home thinking I had bent my pedal or something - but on checking it out at home I realized that my pedal wasn't out of whack, my knee was. Oooof!
So yeah, studded tires.
Likes For chas58:
Liked 415 Times
Fat tires work on hard packed bumpy stuff where I need the flotation, but not in softer fresh snow. Skinny tires really don't work at all when the snow has been packed down with car's driving on in or pedestrians walking on it.
Likes For chas58:
