Touring Bike (rim brake) for Allroad Riding
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
This topic interests me. I broke my old Madone rim brake bike last year and instead of taking the rim brake Elmonda frame offered used for the credit for a Domane SL6. Love it but should have gotten a Checkpoint. Did not want to wait 6 month.
So looked for a rim brake calliper frame. Wanted for the trainer mainly but to run to the store and light rail trail touring. Found a Trek 1000C frame on eBay and built it up. Works well but needs a new fork for more tire clearance. I fit a 32mm on the rear but 25 is max up front. Really should get another frame.
This brings up the question which may help the OP. Any disk frames that will accept calliper rim brakes? I saw the Poseidon X is standard dropouts and reached out and asked about it I can fit calliper brakes. Edit: The X does not have a hole in the rear for a rim brake calliper.
Here痴 my current all road build. Needs a fork. And yes I知 crazy running the carbon wheels. But they have held up better than any aluminum wheels I致e had. Including 36 spoke. Never touched a spoke. And they look cool.
Quoted: 3459 Post(s)
Liked 1,465 Times
But, the OP is asking about 40mm tire clearance. You would be looking for brakes with unusually long arms. I assume they exist, but your standard brakes probably will not fit.
And a front fork that does not have the conventional crown might not work. I am pretty confident that a carbon fork that was not designed for a sidepull brake would not be a good fork to experiment with.
Quoted: 270 Post(s)
Liked 447 Times
When you say caliper brakes, which I would assume you mean side pull brakes. Or since center pull brakes fit on the same frame mounting point if you can add a cable hanger, I am sure that a lot of disc brake frames and forks would be able to have one fitted. (I think some people call a center pull brake a U brake.)
Liked 1,465 Times
Photo below is the only bike I have that has sidepull brakes, this is my road bike. The tires are 28mm. Manufacturer said that the bike can take 28mm tires but I suspect I might be able to fit 32mm. But those brakes clearly do not have the arm length needed for a fork that has enough clearance for a 40mm tire.
Quoted: 270 Post(s)
Liked 447 Times
The Ultegra side pull was too short for the 1000 frame. I had to switch to mid reach Shimano brakes. There are longer reach. Now in the rear with the mid reach brake the 1000 frame will fit a 32mm tire. There is more room on the sides. A 38mm will fit to the sides but the seat stay bridge is too close. Maybe a low profile tire if that exists or tread on the sides. Spare bike for now.
Is that a Soma?
Is that a Soma?
Liked 1,465 Times
Likes For Tourist in MSN:
Palmer
Quoted: 1662 Post(s)
Liked 1,816 Times
I wouldn't have put a caliper brake on it but I got a rrreeeaaalllyyy good deal on a non-disc Rohloff hub. Perhaps somewhat shockingly, my group has not gotten more cavities.
OP:
1) There must be a gazillion existing bikes out in the world built over the last decades that meet your stated requirements. Check craigslist in your local market.
2) Soma New Albion Privateer, perhaps? Mini-Vs, sure, but Paul cantis would be the cat's pajamas.
3) You want what you want. I get that. I certainly want you to be happy with your new bike. I did the 'roll your eyes at yet more new whizzbangs the bike industry is trying to sell us' thing with discs. Anyway, to combat lockdown ennui I built up a new bike and fitted TRP HY-RD cable-actuated hydraulic disc brakes with Shimano ICE discs. WOW. Massive power but with minute modulation. I'd suggest not investing in a new rim braked bike without at least taking a ride on a modern spec bike with quality discs.
Liked 1,465 Times
It's a 650 conversion. This undoubtedly voided my warranty as the Disc Trucker is strictly an ISO559 or ISO622 bike.
Surly had a big batch of red LHT bikes over a decade ago, that is the only time I have heard of Surly actually doing a warranty on one of their frames, but when the paint (or powdercoat) falls off, it is rather evident that something is wrong. They can't pretend that it did not happen.
Congrats on the Rohloff. I have no clue how much the disc conversion costs, but it is not cheap. And Rohloff discs are four bolt so that is an expensive rotor. My Rohloff is staying on a frame designed for rim brakes, although that frame can also handle disc.
Quoted: 2604 Post(s)
Liked 1,926 Times
I'm curious. I've ridden tens of thousands of miles with dynamo cables wrapped around the forks without issues. What kind of serious trouble can I expect, and when will it start?
Likes For pdlamb:
Quoted: 581 Post(s)
Liked 921 Times
I use mini-Vs on my touring bike but I think they would be a very tight fit for 40mm wide tires. I currently have 35mm tires and there is not a whole lot of room left. IT might work but I wouldn't make the assumption without trying it first.
Quoted: 286 Post(s)
Liked 261 Times
I致e talked to a shop about this and it depends on the length of the arms on the brakes. 90mm arms are on a bike in the shop and clear a 41mm tire.
Quoted: 598 Post(s)
Liked 283 Times
I have these particular mini v's on 3 of my bikes including my touring bike. These are 85mm length arms and you're looking at a 33mm tire. Obviously if you're not going to be using fenders, a 40mm would be no problem and you might be able to squeeze in a 45mm.
Liked 1,465 Times
My folding bike uses 85mm length Tektro mini-V brakes and has 40mm Schwalbe tires. No fenders.
I think it depends on exact placement of the canti posts on the frame.
If you needed longer V brakes, you could use Travel Agents (not sure if they are still made) to allow you to use longer full size V brakes with road bike brake levers.
I think these V brakes in the photo below are 110mm long Tektro, I use road brakes, note the Travel Agent in place of a noodle.
If you are not familiar with Travel Agents,
https://www.parktool.com/blog/repair...and-adjustment
Quoted: 1182 Post(s)
Liked 833 Times
I'd suggest checking out the Bianchi Volpe. It is a very good all-purpose bike. If you have feet the are size 10 or smaller, you can get most panniers on it without heel strike.
It does fully loaded well, and holds it own on gravel and club rides. Our son started his cyclocross racing career on a Volpe. I have 2 other touring bikes, a Surly LHT and a Cannondale T2, but the Volpe has been my choice for a ride across the U.S., and 3 months riding through 7 European countries It is my go-to bike.
My first Volpe (with 28 mm tires), riding across the U.S.
Liked 833 Times
Liked 1,465 Times
My heavy touring bike, I can't fit the fenders in the S&S case when I travel, so the brakes will catch a lot of mud on rainy days on dirt and gravel roads or trails. I had so much mud on my rear brake one day that the springs in the brakes were not strong enough to open up the V brakes. Thus, if I used my rear brake, I had to get off the bike and use my hands to pull the V brakes apart. Once I cleaned the mud off in the campsite, they worked fine again. That is the only time I had trouble with travel agents.
Quoted: 286 Post(s)
Liked 261 Times
OP here. I decided to build up a Surly Cross Check frameset. I have boxes of parts I値l be putting to use in this fun project. And I may even do a light tour on her! Thanks for the replies
Likes For Noonievut:
Likes For robow:
Quoted: 1034 Post(s)
Liked 1,290 Times
Interestingly, Surly still lists the original LHT on its website, finding one is a different story altogether.
Liked 1,290 Times
Yeah, the photo of the rear brake that was posted by TCS in post number 20 above looks like a centerpull brake with really long reach.
On the other hand, your brake and headlight looks like a work of art. Nice.
Liked 1,465 Times
I really did not think this bracket would work, but you do not know until you try it.
https://www.bumm.de/en/products/mehr...kt/475du.html?
And it worked perfectly, the bolt through the fork crown is long enough that there still are plenty of threads holding the brake to the fork, the brake arms do not touch the light bracket, I was just lucky.
The light I have is 70 lux, they apparently upped it to 80 lux now.
https://www.bumm.de/de/produkte/dyna...di-silber.html
Liked 1,290 Times
Thank you. And it works too.
