Road/Bike rules for upcoming tour
Quoted: 138 Post(s)
Liked 17 Times
What are the rules? Is it only interstate highways you can't ride on or what? I know I have been on stretches that the maps show as limited access that the highways aren't marked as off limits to bikes. I've even passed a cop out on highway construction duty on one stretch and he didn't say a thing to me. I have a route I'm trying to plan right now that some stretches of the same highway are limited access and some aren't. What are the actual rules. I know from recently driving the one stretch, earlier this week that all the highway is four lane divided and some parts have surface crossing while other stretches don't. Another stretch of highway much closer to home is all limited access. What gives on the rules?
Every day a winding road
It is going to depend on the country and what part of the country you are in. As a rule bicycles are not allowed on "limited" access roads in the US but there are some interstates that allow them. Also allowed in small segments in other parts of the country such as where the interstate crosses a river.
bicycle tourist
As Spinnaker mentions, generally varies by part of the country and by state. Not 100% but often eastern US doesn't allow and in western US is allowed outside urban areas - though it varies by state. I've ridden short stretches of interstate highways in following states: OR, CA, NV, ID, UT, MT, WY, CO, NM, TX and with exception of a little piece of NM (Raton Pass but no obvious alternative) all were legal riding.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Which country or countries are you referring to?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 18413 Post(s)
Liked 15,536 Times
As noted, some specifics would be helpful. For example, in MT, every inch of interstate highway is open to bikes. I have also ridden legally on interstates in OR, ND and WY. And I know of at least one limited access state highway in NJ that is open to bikes.
Quoted: 1182 Post(s)
Liked 833 Times
Generally, Access is allowed on freeways where there are no reasonable alternatives. We've never been kicked off a freeway in the US or Canada, but have been told to take an alternate route in Europe. Ironically the freeways, while noisier, often have wider shoulders and are safer to ride than the alternative route. There is a 60 to 80 mile section through southern Idaho where it is the only road.
Sometimes there are no other choices.
Quoted: 3375 Post(s)
Liked 5,513 Times
In CO, interstates are open to bikes when there is no nearby alternative road.
CO map with prohibited roads marked in alternating yellow/black: https://www.coloradodot.info/programs...bicycling-maps
Quoted: 138 Post(s)
Liked 17 Times
I'm looking at stateside. For right now, in the eastern/northeastern 1/4 of the US(north of the Ohio/east of the Mississippi Rivers). I've been on two lane limited access and two with an uphill passing lane where there were no signs on the on ramp that indicated bikes, pedistrians, etc were off limits. Looking at Rand McNally shows them as being "off limits" because it shows them as being limited access. This in reality appears not to be the case though. Their limited access but not four lane limited access. Is that typically part of the rule or not(they have to be four lane limited access before bikes aren't allowed). If the highway in question is only partially limited access while other parts have surface crossings how does the rule then apply? Hence why I'm asking the question.
I understand the rule on using federal money to build/maintain interstates requires alternative access if you are shutting down a main artery for bikers(hence the bike paths in NH that sit right beside the interstates), so I can easily see allowing bikes out west where the alternatives are practically non-existent.
In the east I see no reason to use limited access roads. There are plenty of back country roads to be had. In addition Ohio has tons of bike paths.
Limited access roads are noisy and full of road debris. I'd avoid them any chance I could.
Quoted: 138 Post(s)
Liked 17 Times
Direct access. Highway are typically the shortest distance between two points. Bike paths take you where ever the old railroads use to go. I'm looking for a faster/shorter trip hence the focus towards the highways. I know the highways typically have the best maintainence and the most services as well. I always stick to the highways when I ride unless I'm riding locally.
Quoted: 659 Post(s)
Liked 7 Times
As already indicated in other responses, other states have a variety of different rules. NJ prohibits bicycles on most of their limited access roads but you can apply for a free permit which allows access to many of them.
Yes, in California you are legally allowed to ride freeway shoulders when no reasonable surface alternate route exists. There are even a couple short sections of I5 and I805 in the San Diego urban area that this applies to (I-5 north downhill to Sorrento Valley Rd., I-805 between Main and Palm just south of Chula Vista)
On one tour, I was headed along frontage roads west down from Donner Pass along I-80 towards Sacramento, which I knew would end and dump me onto the freeway. That eventually happened, though the shoulder was pretty rough from the bad winter weather. Soon I came up to a section where the shoulder was blocked off by K-rail for construction, and the highway workers insisted I ride out into the freeway lanes populated by trucks screaming downhill at 80 mph, since the shoulder under construction was "way more dangerous". Realizing there's no use arguing with idiots or crazy people, I went down the freeway, around the bend, and hopped over the rail onto the empty, perfectly ridable shoulder for several miles, not seeing a single worker the rest of the way.
A few miles further on, they had the uphill section of the Interstate closed for resurfacing for fifteen miles, diverting all traffic onto the downhill section and using the shoulders. A sure death trap. I asked the highway patrolman guarding the closed freeway entrance if I could ride the closed half of freeway, and after some thought, he said "be careful" and let me through.
There were a few highway workers with shovels and a backhoe off into one lane every few miles, otherwise I had the empty, freshly-paved, downhill fifteen miles to myself, until I had to exit onto the maze of side roads in the gold country...
