Converting between Power, VO2, and METs
climber has-been
Quoted: 3427 Post(s)
Liked 3,561 Times
Putting this here to make it searchable, so when anyone (I) needs to do a conversion, they (I) can find it. Please comment if you think I got something wrong, and I'll update.
These conversions are based on a leg ergometry equation from ACSM's Guidelines for Exercise Testing and Prescription, (a paper book that I am too cheap to buy).
Definitions:
Conversions from PWR (W/kg):
Source: PowerPoint from immagic.com
UPDATE:
Since the ACSM formula is limited to "sub-maximal aerobic effort", it doesn't apply to VO2max.
However, this paper:
Hawley, J. A., & Noakes, T. D. (1992). Peak power output predicts maximal oxygen uptake and performance time in trained cyclists. European journal of applied physiology and occupational physiology, 65(1), 79–83. https://doi.org/10.1007/BF01466278
has a formula for VO2max and peak power, based on a ramped power test, starting at 100 watts and increasing by 25 watts every 150 seconds.
Definitions:
Definitions:
- MET: Metabolic Equivalent of Task. A common measure used by scientists. One MET unit is roughly the energy expended when sitting quietly, set by convention at an oxygen consumption (VO2) of 3.5 ml/kg/min.
- VO2: A person's rate of oxygen consumption, typically in units of milliliters per kilogram body mass per minute (ml/kg/min).
- PWR: Power to Weight Ratio. Power produced at the cranks divided by body mass (watts/kg).
- VO2 (ml/kg/min) = (10.8 * PWR) + 7
- METs = 0.286 * VO2 = (3.09 * PWR) + 2
- steady state sub-maximal aerobic exercise
- power range 50-200 watts
UPDATE:
What About Power At VO2max?
Definitions:
- Peak Power Output (PPO): highest power achieved (Watts)
- Body Mass (BM): body mass of cyclist (kg)
- Peak Power to Weight Ratio (PPWR): PPO divided by BM (W/kg)
- VO2max: maximum oxygen consumption (ml/min/kg)
- Calculate VO2max from PPO: VO2max = (1000 / BM) * (0.01141 * PPO + 0.435)
- Calculate VO2max from PPWR: VO2max = 11.41 * PPWR + (435 / BM)
- Calculate PPWR from VO2max: PPWR = 0.0876 * VO2max - (38.12 / BM)
Likes For terrymorse:
Quoted: 1273 Post(s)
Liked 1,392 Times
a (probably) dumb question that doesn’t seem to be readily explained or answered.
if using the formula above to calculate VO2 MAX, what duration does the power output need to be sustained for? is the watt value intended to be FTP, a power output level the can be sustained indefinitely, peak for 5 min, etc?
climber has-been
Liked 3,561 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
Seems like pretty good rules of thumb. Thumbs up.
FTP and VO2 max relationship does vary especially older athletes. Maybe they get more efficient as some have proposed to explain the high capacity utilization or maybe oldtimers just more stupid
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,852 Times
A third and, to my mind, more likely, possibility is that VO2max falls faster than FTP with age. Certainly true in my case. Longitudinal studies are needed to answer the question.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
I started doing rando when I started getting dropped on the hills in competitive group rides, and did very well with rando. I also see that trend in various event rides. We lose the high end first. Experience in pacing might have something to do with it, too.
Results matter
Results matter
Likes For Carbonfiberboy:
climber has-been
Liked 3,561 Times
When you no longer can go fast, go long.
This was the inspiration for some of the "death march" rides in California. We olds may no longer contest the city limit sign, but we tend to do okay on the longer stuff.
Liked 1,938 Times
There was a saying going around in the clubs, I don't know if it's still around:
Results matter
Results matter
climber has-been
Liked 3,561 Times
