Raising Handlebars
Quoted: 14 Post(s)
Raising Handlebars
I have a Cannondale SuperSix 2013 model year. I'd like to raise the handlebars, if I can. I know that I can't raise them any more with spacers. Can I do it with a longer neck?
Likes For Rick:
Quoted: 836 Post(s)
Liked 1,059 Times
Some stems have a steep downward angle that can be turned upside down to give a higher position for your bars. Not sure what a "longer neck" refers to but if you have no more room for spacers to raise the stem you're left with using the first suggestion, getting a new stem with a steeper rise or getting a steerer extender such as these. (1) bicycle steerer extenders - Bing or the dreaded adjustable rise stem as a last resort (but still works). (1) adjustable rise stem - Bing
Expired Member
Quoted: 3657 Post(s)
Liked 5,395 Times
Unfortunately, the things you can do include some that you shouldn't do. Try flipping the stem or going to an angled stem within normal parameters, about 30 degrees max. If these don't give you a comfortable fit, you need a different size bike or a different type of bike. Having said that, folks proudly post all sorts of kludge contraptions on BF!
Likes For shelbyfv:
Quoted: 6178 Post(s)
Liked 4,796 Times
Riser bars can get you a little higher too without having to go to weirdly angled stems or extender tubes which I wouldn't do.
Many different brands have them. These get you 15mm higher, but I'm pretty sure I've seen other brands that get you almost an inch higher.
https://www.specialized.com/us/en/ho...=230548-156001
If you don't have drops, then there are risers in other versions too.
Likes For Iride01:
Quoted: 94 Post(s)
Liked 151 Times
Either riser bars or a stem riser will allow you to raise your handlebars. The Cannondale SuperSix is more of a racing road bike but the Cannondale Synapse road bike is designed with a more relaxed, upright riding position. You may consider switching to a road bike like the Synapse that is more comfortable due to the handlebars being set a little higher.
Quoted: 14 Post(s)
Thanks.
Quoted: 405 Post(s)
Liked 430 Times
Given that there are many ways to solve this problem, (higher-angle stems, steerer tube extenders, etc,) all of which can be done for less than a hundred bucks, why in the hell would anyone suggest that the OP would be best served by spending a couple of grand on a whole new bike??!??
Hell, if you want the OP to spend lots of unnecessary money, advise them to buy a new, uncut fork and run a big stack of spacers. Suggesting a whole new bicycle is utter nonsense... you wouldn't do that if it was your money, so why would you suggest it to anyone else?
--Shannon
--Shannon
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
I have installed extenders on a number of bikes with great success but one thing we noticed was that the screws on the collar of the extender we purchase are short and doesn't engage all the threads. We typically will swap the screws with ones that are 5mm longer and then all the threads are engaged and bolts can be torqued up without damage to the threads of the collar.
Quoted: 14 Post(s)
Quoted: 567 Post(s)
Liked 563 Times
If you want a new bike go for it, but to answer you question; Yes, now in my 70's I have found this site helpful to materially raise the bars with little impact on handling which should be considered, such as reducing the weight pushing forward on the bars makes the bike less stable:https://www.habcycles.com/fitting.html
My customs, even with quills thanks to Nitto, and a Litespeed have been raised as much as 70mm with little impact on handling at my now less aggressive riding. While I don't agree with the fashion police comments about +30º stems I will admit I can not put them on my Italians.
The need for higher bars can be due to other fit problems. A saddle that's too far forward can put too much weight on the hands and the cure is often thought to be higher bars. I'm 68 years old and still use a 10cm saddle to bar drop. I'm a relatively small rider, at 5'-6" or 168cm, but I have long legs, so my saddle height is 72-73cm.
