(9) Speed Derailleur on 8 Speed Drivetrain
Old 09-25-21, 03:52 PM
Rick53
Bikes: Verve, Dual Sport 2 and FX3
Quoted: 78 Post(s)
Liked 13 Times in 10 Posts
I was given a New Acera Rear Mech from Trek under warranty . It took so long to get it out of them . I purchased a Deore for My Verve 3 Disc .so I could continue riding this summer . Since I have no intention of taking the Deore off my Verve 3 . Can I use this Acera on a Trek Verve 2 with 8 speeds that currently has an Altus RD ? I'm assuming I can . Would I need a different chain ? Thanks
Rick53 is offline
Old 09-25-21, 04:50 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,217 Times in 2,364 Posts
Yes, you can use the 9 speed derailer on an 8 speed system. Won’t make a difference.
Stuart Black
cyccommute is offline
Old 09-25-21, 05:05 PM
Troul
Troul's Avatar
Liked 2,968 Times in 1,917 Posts
in your specific case, i don't think the idler/jockey matters much if any regarding chain type.
The der moves positions based on the shifter's cable preset specifications. The main concern of the der is if it is capable in sweeping the across the cogs without exceeding designed mechanical capabilities.
-Oh Hey!
Troul is offline
Old 09-25-21, 05:56 PM
Rick53
Quoted: 78 Post(s)
Have you ever seen something like this . This derailluer doesn't have threads to install this barrel adjuster housing . It's supposed to correct ? Sorry for the big picture . There's no threads in that housing to screw in my barrel adjusting screw or nut . Or whatever it's called . I am assuming either it needs a different kind or they forgot the threads in this one
Rick53 is offline
Old 09-25-21, 06:32 PM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times in 570 Posts
No -- the Deore level and above Shadow derailleurs from Shimano do NOT have barrel adjusters at the derailleur. That pocket there is sized for the cable end cap to sit in. These derailleurs require you to use the barrel adjuster at your shifter (or install an inline one somewhere).
The Alivio, Acera, and Altus series Shadow derailleurs DO have barrel adjusters on the derailleur.
hokiefyd is offline
