Show us your Vintage Touring bikes
Old 04-26-21, 08:18 AM
  #2526
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
Liked 745 Times in 546 Posts
now, why couldn't they have put a barrel adjuster on the eco? seems a trivial thing and could still remain more "eco" than the ti version
thook is offline
Old 04-26-21, 10:00 AM
  #2527
daka
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Quoted: 250 Post(s)
Liked 314 Times in 197 Posts
I'll let the repressed retired manufacturing engineer in me speak for a second - Note that the stop on the ECO is formed from the same piece of metal that the parallelogram arm is made from. Other than the original expense in fabricating the forming dies, no added cost. The Ti version, on the other hand, has three additional components, a riveting operation and (likely) manual assembly of the spring and barrel adjustor. Definite increase in production cost.
daka is offline
Old 04-26-21, 10:25 AM
  #2528
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
perhaps. otoh, instead of bending the metal over to form the cable stops, leave it flat and drill a hole using the same barrel adjuster as the ti. moreover, use the same basic design/die for the eco as the ti, just make it all steel as they did. one die...two different materials. save even more over having two dies (i'm no engineer, but i'll mildly play the devil's advocate, here )
thook is offline
Old 04-26-21, 11:03 AM
  #2529
daka
Quoted: 250 Post(s)
That component part in steel cost pennies, even with the cost of tooling amortized. The cost of assembling the barrel adjustor, if it had been in the factory where I worked, would have been more than a dollar. Not to mention the cost of the three additional parts.
I don't have enough experience with titanium to know whether the same dies could be used - off hand, I'd guess no, since the design of the die includes compensation for how much a particular metal "springs back" after forming.
daka is offline
Old 04-26-21, 11:19 AM
  #2530
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
my point is really, daka, it would still be more economical than the ti. and, ultimately, i'm just finding something pointless to gripe about...lol. i do have the idea, however, to see if i can add a barrel adjuster to mine as the suntour downtube cable stop doesn't have them. may not be doable, but i'm gonna see...dang it!
thook is offline
Old 04-26-21, 11:31 AM
  #2531
daka
Quoted: 250 Post(s)
Point taken. The real cost difference in manufacturing is likely the more expensive raw material, the finishing and the absence of economies of scale. As to the adjustor, before indexing many derailleurs didn't have them. It only became important when fine-tuning the lateral position of the derailleur to correspond to an indexed position at the shifter was required. BITD, you'd only use the barrel adjustor, if you had one, to take up slack in the cable.
daka is offline
Old 04-26-21, 11:45 AM
  #2532
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
exactly. titanium is just expensive. i also realize, with either version, the nature of it's multi pivot design is costly
none of my cyclone derailleurs have one, but ironically the "lesser" BL does. i like having one back there for more convenient installation and adjusting as cables stretch...ie. not having to fuss so much with the pinch bolt
thook is offline
Old 04-26-21, 09:00 PM
  #2533
Cycle Tourist
Quoted: 195 Post(s)
Liked 207 Times in 126 Posts
I Think there was probably no incentive to add an adjustable barrel to bikes being used with friction derailleurs. It looks to me like a properly sized barrel adjuster screw and nut would fit and give you the adjustment your looking for. It's a little unglamorous so I'd use the adjustable down tube hardware. They will screw into frame lugs or, if none are available, into an old clamp on style derailleur minus the levers. Understand that the screws that come with the hardware may or may not work on the old clamp-on. Sometimes the screws that came with the levers are perfect and add a touch of class to the set up.
Cycle Tourist is offline
Old 04-26-21, 09:34 PM
  #2534
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
what i have is a suntour clamp on downtube cable stop. i don't think barrel adjusters will work on it. i could give it a go if there's enough clearance from the frame to spin the barrels. otherwise, i have a late 70's 600 rear derailleur with an adjuster that looks like it might work on the duopar. i'm juggling honda work, little home repairs, and another bike build. but, i should squeeze in 15 min's tomorrow to look at the logistics for the adjusters
thook is offline
Old 04-28-21, 11:44 AM
  #2535
Cycle Tourist
Quoted: 195 Post(s)
I was referring to adding a new adjustable mech. to an old set of down tube clamp on levers. I'm a fan of barend shifters for touring bikes. Sometimes I forget that not everyone has a box of old shift levers.🤗
It looks like this:
Likes For Cycle Tourist:
Old 04-28-21, 11:57 AM
  #2536
Cycle Tourist
Quoted: 195 Post(s)
Originally Posted by bicyclegirl1961
I didn't like that my 1986 Royce Union 12 speed was all black when I bought it new so I went to a bike shop and bought Peugeot decals.
Royce Union has a certain cache so I'm a little sad to see it go. I realize Peugeots have a following too. Sorry to be a wet blanket but the vintage look kinda got lost in the translation. All that notwithstanding it's a nice looking bike and you look very pleased with the results and that's all that really matters.👍
Old 04-28-21, 12:08 PM
  #2537
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
It looks like this:
and, that's what i figured even if my reply didn't reflect that. i've done that, also, with an arabesque clamp on. require some dremeling to make the adjusters fit flush, but it worked nicely. i just don't want to run modern looking bits on my gran turismo. keep it vintage looking as i can
thook is offline
Old 04-28-21, 04:04 PM
  #2538
GeoffroyFromLux
GeoffroyFromLux's Avatar
Bikes: Motobecane CT2 1984
Quoted: 8 Post(s)
Liked 51 Times in 9 Posts
84 Motobecane CT2 650b with some vintage/modern components upgrades.
not the lightest frame I have but un breakable and reliable!
GeoffroyFromLux is offline
Old 04-28-21, 05:34 PM
  #2539
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
Originally Posted by GeoffroyFromLux
that is super nice!! is it indexed in the rear??
thook is offline
Likes For thook:
Old 04-28-21, 10:34 PM
  #2540
GeoffroyFromLux
Quoted: 8 Post(s)
Thx
Yes it is indexed; 7 speed
Old 04-30-21, 10:30 PM
  #2541
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
the barrel adjuster off of an old 600 RD will work on the eco with a little tinkering. however, i found the perfect solution for the suntour clamp/cable stop; jagwire mickey barrel adjusters. they can snug right up to the frame and still spin since the barrel has such a narrow profile. to top it off, they look the classic part....mostly . now i can fine tune both derailleurs
thook is offline
Old 07-13-21, 08:08 PM
  #2542
casanewt
casanewt's Avatar
Bikes: Wow, where to start? A collection of 1980's and early 90's road, touring, and MTBs from the likes of Trek, Schwinn, Cannondale, Fuji, Miyata, Univega, Panasonic, and GT. It has gotten rather out of control.
Quoted: 140 Post(s)
Liked 173 Times in 78 Posts
Run, don't walk...https://www.facebook.com/marketplace...4625428360275/
casanewt is offline
Old 07-13-21, 08:20 PM
  #2543
Jasongrace313
Jasongrace313's Avatar
Bikes: 82 John Howard built by Dave Moulton, 06 Lemond Croix de Fer, 85 trek 620, Trek Fx 7.2, Giant escape 2, Gt Karakoram, Electra Townie 7D,
Quoted: 30 Post(s)
Liked 65 Times in 34 Posts
1985 Trek 620 Cirrus
Just acquired this fine steed.
Jasongrace313 is offline
Likes For Jasongrace313:
Old 09-25-21, 09:18 AM
  #2544
ehcoplex
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 760 Post(s)
Liked 1,562 Times in 756 Posts
By automotive standards I think my '97 T900 is technically a year away from being 'classic', but close.....
1997 Cannondale T900
ehcoplex is offline
Likes For ehcoplex:
Old 09-26-21, 05:03 PM
  #2545
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2607 Post(s)
Liked 1,694 Times in 933 Posts
Level top tube, silver components... "classic."
Looks great! Love to see more pix of it!
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 09-26-21, 05:35 PM
  #2546
ehcoplex
Quoted: 760 Post(s)
Ha, well...... originally it did have a black seat post, stem and chainrings. I took the opportunity to rectify the aesthetics while fixing the fit!
ehcoplex is offline
Likes For ehcoplex:
Old 09-26-21, 05:39 PM
  #2547
Oldsledz
Quoted: 66 Post(s)
Liked 185 Times in 80 Posts
I got this 1973 Fuji Special Road racer at a online auction cheap last week.
Oldsledz is offline
Likes For Oldsledz:
Old 09-26-21, 09:24 PM
  #2548
ZudeJammer
ZudeJammer's Avatar
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times in 96 Posts
Frame bag upgrade for this summer on my Fuji Touring Series V and the Mountech FD (seized from road salt) replaced with a Cyclone
ZudeJammer is offline
Likes For ZudeJammer:
Old 09-27-21, 12:39 AM
  #2549
thook
(rhymes with spook)
thook's Avatar
Quoted: 919 Post(s)
ZudeJammer love it!! and, where'd you get that frame bag?? can't quite make out the brand tag on there
thook is offline
Old 09-27-21, 01:35 AM
  #2550
polymorphself
Quoted: 837 Post(s)
Liked 1,080 Times in 521 Posts
Looks like it says Rockgeist.
polymorphself is offline
