Kicker has 4 points of contact
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,181 Times
with the ground. anyone have one and find that odd? i ride in the garage and it is not exactly a perfectly level surface so getting the kicker to mate properly with the floor can be a challenge at times. 3 points would have made that much easier. looking at the kicker bike i think it only has 3.
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I do have a level surface for the Core so it's not an issue for me. To give me a little side to side sway (and comfort), I put a thick foam mat under the Core.
Would a mat like that be enough to level out your KICKR? Otherwise, I'd figure out which of the KICKR feet aren't touching the ground and tape shims to them.
Liked 1,181 Times
i've been wanting to try the mat thing not for the leveling but for the feel, just never got around to it.
Randomhead
Liked 3,693 Times
It's a little compliant, so it's not too much of a problem. I think if they didn't have a support at the back in the middle that it would break more readily.
Mine is bolted down to a rocker plate right now, so it's really stable. I should probably put an anti-slip mat under the rocker plate base though
Liked 1,181 Times
my trouble is my 17 year old. last year we got another car (the spit in my profile pic). when i was riding in the garage i had a fairly decent setup but now with the additional car (and being a classic) it had to be garaged. that meant a big change, a lot of rearrangement in the workshop garage to fit the spit in. its small enough that i can still ride in the garage but now i need to take the bike off every time and occasionally move the trainer. mostly the setup remains the same but sometimes not and i need to always check for stability each time i set up again.
you are probably right about the back oval foot needing to be there for weight distribution.
Liked 1,181 Times
good idea. i've already marked out the feet with a sharpie and it works well. its just that sometimes the adjusting feet move even though there are locks on them.
