Cannot get tire to let go of rim
Old 03-31-22, 05:01 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3690 Post(s)
Liked 2,175 Times in 1,372 Posts
Originally Posted by Camilo View Post
He's having trouble getting the bead of the "shelf". He isn't to the point where he can even get it to the center.
Aw shoot, you're right!
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 03-31-22, 06:07 PM
vespasianus
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 370 Post(s)
Liked 336 Times in 189 Posts
Originally Posted by Telkwa View Post
I hope the soap and water works.
Pridedog, you describe the exact thing I worry about.
I've been carrying levers and pump and spare tube with me. Might as well leave that stuff at home.
Any luck?
vespasianus is offline
Old 04-01-22, 08:42 AM
Telkwa
Quoted: 30 Post(s)
Liked 4 Times in 4 Posts
It might be weeks or months before I even try again. Added some sealant and riding as is. The tire has almost no wear so barring catastrophic failure I should be OK for a while. I'm picking up some tubeless stems, rim tape, sealant, etc. so if/when I try to break the tire free from the rim I can try something different as far as tubeless setup.
I hate calling the Trek bike shop and bugging them with questions, but I called yesterday. The mechanic I talked with said he's had much better success rate with the Bontrager rim strips than rim tape. He did suggest trying a different valve stem if I was unhappy with the Bontrager stem. He mentioned the Muc-off stem.
One of you guys suggested the same thing - keep the rim strip, replace the valve stem.
I've got several woodworking clamps. Parallel ones, on the long bars. I wonder if those might work to squeeze the tire off the shoulder? I think the jaws are deep enough to reach past the bulk of the tire.
Telkwa is offline
Old 04-01-22, 10:48 PM
tankist
Quoted: 76 Post(s)
Liked 81 Times in 38 Posts
I had the same problem with tubeless tires installed by LBS - they glued to the rim too well. So I took my favorite pliers and carefully pried the tires open. No tires were hurt during this operation.
tankist is offline
Old 04-03-22, 03:18 PM
Camilo
Quoted: 832 Post(s)
Liked 797 Times in 506 Posts
Originally Posted by alcjphil View Post
Tube type tires on the same rims will likely be just as difficult to dislodge from the rim shelf
I can vouch for that. Using tubes doesn't affect this type of problem (getting the tire bead off of the rim "shelf")
Camilo is offline
Old 10-17-22, 10:57 AM
Telkwa
Quoted: 30 Post(s)
I finally got the tire off the rim. Soap/water, clamps to force the tire to the center, piece of wood and hammer, screwdrivers, etc. A standard size plastic garbage can worked good as a work surface.
I'm done with tubeless. Going back to tubes with Slime.
Telkwa is offline
Old 10-17-22, 12:30 PM
smd4
Quoted: 1766 Post(s)
Liked 1,319 Times in 834 Posts
Originally Posted by vespasianus View Post
Has nothing to do with tubeless. Can happen with any tire.
I've never come across a standard tubed tire that I wasn't able to remove with my bare hands at minimum, or perhaps a single tire lever, and was able to install using no tools.
smd4 is online now
Old 10-17-22, 03:04 PM
vespasianus
Quoted: 370 Post(s)
Most likely the use of older rims. Newer rims will be tighter and have lower tolerances. As will the tires.
Likes For vespasianus:
Old 10-17-22, 04:39 PM
smd4
Makes sense.
smd4 is online now
Old 10-19-22, 08:29 AM
Mr. 66
Mr. 66's Avatar
Quoted: 899 Post(s)
Liked 1,195 Times in 686 Posts
I agree but I wouldn't bother with the slime
Mr. 66 is offline
Old 10-19-22, 10:09 AM
Telkwa
Quoted: 30 Post(s)
Geez, two days ago I wrote an exhaustive account of what I did to get the tire off the rim. It took so long to write that I had to Reload, then all my efforts were lost.
Next time I'll write it up, then copy/paste into the forum.
I was so annoyed with myself that I quickly wrote the above and moved on. I've never used Slime before. So I shoulda wrote "I'm going back to tubes, and I'm gonna try Slime for the first time".
The rails-to-trail that we ride has sharp crushed basaltic rock. Our Conti Protect tires can't stop the basalt chips. We need something more rugged than just dry tubes and tough tires. A friend of ours who rides the trail 3X a week uses Slime. He hasn't had a flat in a long time so I thought I'd try it.
EDIT: I had to reload the tab again. This time I copy/pasted first. Bike Forum kicks me off pretty quickly!
Our friend has a fat tire e-bike. He told me his tires fit so loosely on his rims that he has to make sure the tire stays on until he gets a few pounds of air in. Our Contis are tight to the Bontrager rims. When putting this tire back together the other day the bead wouldn't fully seat at 40#. I deflated, sprayed on some soap/water, reinflated, tire finally snapped on fully at about 30#.
Telkwa is offline
Old 01-28-23, 10:34 AM
Telkwa
Quoted: 30 Post(s)
I finally got both tires off the rims. Used the top of a plastic Rubbermaid garbage can as a working platform. I used some vice grips to squeeze the tires toward the center. Soap & water. I think I damaged one tire, because it has a small sideways "whoop" to it now. &$%@ tubeless.
Maybe t/l wroks for some people, but it's been a fussy nightmare for me. I think the Bontrager rims and Conti Protect tires are a poor match. I had to gas the tires up to about 60 # before they seated with loud "snaps". Nobody has responded to my comments about offset rims causing poor contact with the valve stem nuts. I don't see how you can get a tubeless valve stem well secured when the valve stem nut only contacts the rim on one side.
Went back to tubed and got a flat on second ride.
Telkwa is offline
Old 01-28-23, 12:16 PM
alcjphil
alcjphil's Avatar
Quoted: 1589 Post(s)
Liked 1,316 Times in 773 Posts
I I don't see how you can get a tubeless valve stem well secured when the valve stem nut only contacts the rim on one side.
The nut serves to hold the valve stem in place. The seal is formed where the rubber base of the valve stem contacts the rim bed
alcjphil is offline
Likes For alcjphil:
Old 01-28-23, 04:06 PM
Telkwa
Quoted: 30 Post(s)
Thanks for taking the time to reply.
I understand that the seal is at the base of the valve stem. It's just that when the valve stem nut doesn't contact the rim evenly it can't be as secure as even contact with the rim. Plus, since the nut is only contacting the rim partially, the nut is more likely to loosen due to vibration, etc.
FSA makes neat little wedges that fit between the offset rim and the valve stem nut. I bought a few of them. I think they do help, but it all feels a bit like Band-Aids to me.
Telkwa is offline
Old 01-28-23, 10:08 PM
Camilo
Quoted: 832 Post(s)
On Youtube there are several videos of people getting difficult tubeless tires off of rims. The main (and pretty much only) issue is getting it started - pushing the bead in towards the center low spot, across the "shelf" between the low spot and the rim. If that makes sense. Anyway, do a youtube search, you might find something that works. I had a rim like that and I had to squeeze the tire in a bench vice to get it to release. Carefully of course so as not to harm the rim.
Camilo is offline
Old 01-29-23, 07:11 PM
Telkwa
Quoted: 30 Post(s)
I feel like an idiot for not googling, but apparently there are some tools that might help with this.
Such as this Bikehand gizmo.
It's plastic so who knows if it'll hold up. I think I'm gonna give it a try. There are other strange little tools like the Rehook Tire Glider. Anyone have any experience with these alternatives to plain old levers?
I like the idea of a clamping device like the Bikehand. Seems like a person could keep some pressure on the Bikehand while using the other hand to check that the far side of the tire is in the channel.
Camilo, I used two of these to squeeze the tire off the bead. Worked OK. Gripping the tire, then pulling away from the rim and twisting seemed to help break the death grip.
Telkwa is offline
Old 01-30-23, 10:23 AM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 646 Post(s)
Liked 360 Times in 221 Posts
If all else fails, try orange citrus degreaser sparingly in one spot to see if it will soften the "sticky"...or hurt the tire. Let it sit and seep into the bead for a few minutes then try to separate. I don't think it will hurt the tire but you will want to wash it off with sudsy water before putting it back on the rim. Orange degreaser does a good job of removing some glues and adhesives.
drlogik is offline
Old 01-30-23, 12:29 PM
Mojo31
Quoted: 7226 Post(s)
Liked 4,547 Times in 2,485 Posts
Rather than using levers to pry off the tire, try getting all of the beads into the center well, grasping the tire in one spot, and pulling it laterally until a bead comes over the rim sidewall. That's not a great explanation, and I'd like to make a video or something someday, but it works well for me when dealing with tight or really stiff tires. It's annoying to my "just use a tire lever!" friends, but I nearly always triumph in the end.
That brilliance only works if you can get the beads off the hook. OP cannot get his beads off the hooks.
Mojo31 is offline
Old 01-30-23, 01:03 PM
ThermionicScott
Yer a little slow on the draw there, pardner.
RUSA #7498
Old 01-31-23, 03:12 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 747 Post(s)
Liked 649 Times in 433 Posts
Some tire/rim combos are simply impossible to work with. You could use a bead jack, but not sure that you want to carry that around with you in case you get a flat.
I had a pair of WTB KOM rims and WTB Byway tires that were an absolutely impossible combo to work with. I ditched the Byways, replaced them with Panaracer GK's.
Lombard is offline
Old 02-01-23, 08:32 AM
drlogik
drlogik's Avatar
Quoted: 646 Post(s)
Try the old toe strap trick. Works every time. Get the bead started and when you get to the point where it won't go on the rim, tie on a toe strap tight at that spot then push the other side into the bead. The toe strap holds the bead for you so you can use both thumbs to roll the other side of the bead onto the rim.
If you don't have a toe strap a zip tie or shoe lace will work also.
drlogik is offline
Old 02-01-23, 11:56 AM
Telkwa
Quoted: 30 Post(s)
Thanks for the help, guys -
I'll share something real quick. Although I've changed tires since I was a kid, I was missing something that some of you mentioned several times above. I didn't pay much attention to where the far side tire bead was while prying. Yesterday I put extra effort into keeping the tire bead in the center channel. I got the tire off with just one levering action, then sliding the lever sideways.
What really amazed me was I got the tire back on with no levering tool at all. Just made sure to keep the far side bead in the center channel.
This was with the Bontrager Duster Elite rims and Conti tires that I've been complaining about.
I was so proud of myself!
I used soap and water, which is now part of the routine instead of something I do when things are really stuck.
Stumbled onto something during installation that might help others. I set the wheel halfway onto a countertop. Pulled it back a little bit until the center of the wheel dropped off the countertop, then pushed the wheel against the counter edge with my stomach. That helped keep the tire bead in the channel, and freed up both hands to work the tire back on the rim. Worked really good.
Telkwa is offline
Likes For Telkwa:
Old 02-01-23, 01:54 PM
ThermionicScott
Nicely done!
RUSA #7498
Old 02-01-23, 04:18 PM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 747 Post(s)
This is key.
Lombard is offline
Old 02-01-23, 07:31 PM
smd4
Classic bike shop tip!
smd4 is online now
