Substitute headset spacer
Bikes: 1994 Raleigh MT200,,2022 Marin Four Corners ,1994 Cannondale T700,2019 Trek Domane SL7
Quoted: 35 Post(s)
Liked 269 Times
Does anyone have a makeshift 1 1/8” headset spacer substitute hack?I ordered a proper one and it would be a temporary fix only.Dumb idea but it doesn’t hurt to ask,right?
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Something like this or a seatpost clamp?
Definitely an amateur...
Bikes: Obed Baseline, Stumpy FSR
Quoted: 33 Post(s)
Liked 93 Times
An obvious solution would be to cut an appropriate diameter pvc or metal pipe into whatever length you needed.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,982 Times
Just get a headset spacer? Your local shop probably has one.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Quoted: 35 Post(s)
Liked 269 Times
I live in Bumfuq,Alaska. No bike stores.Amazon is my lbs.
Likes For IcySwan1:
Quoted: 35 Post(s)
Liked 269 Times
I live in Craig.You’re still 500 miles away Mike,but thanks for the tip. I got one on the way so what I really need is patience.
Quoted: 35 Post(s)
Liked 269 Times
This is my fix. A stiff plastic split ring under the hose clamp.
Temp fix
Temp fix
