What you guys do about right pant leg getting chewed up by chainring?
#51
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
I loop about a 6 foot piece of string over my right arm and tie one end of the string to my outer pants cuff. The other end of the string is tied to the inner pants cuff. Then when my foot spins through the bottom half of its revolution the string pulls my pants up and clear of the chain.
...I'm thinking this might be a trick question.
Likes For fishboat:
Likes For Steel Charlie:
#53
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
I would connect a string to your left pedal that goes over the top tube that attaches to your right pant leg cuff. Every left pedal downstroke will pull your right leg cuff up and out of the way. Be sure to always dismount to the left. You’re welcome.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#54
Quoted: 759 Post(s)
Liked 810 Times
Might ponder that a bit more..it won't work. It raises the pant leg when raising isn't needed.
#55
Quoted: 961 Post(s)
Liked 1,628 Times
On each of my bikes I keep a few Reflective Snap Bands. Usually on the handle bars or seat post. Very easy to use. They are real cheap if ya get them through the ChiCom outlet AliExpress, but I prefer the Euro ones at 17"/43cm. They last a real long time but have a tendency to walk off with human help...
Amazon
Amazon
#56
I still have old toeclip straps laying about. They work around your pant leg, or strapping your spare tubular to your seat, or when your frame pump is a bit loose, or......
Likes For big chainring:
#57
Grupetto Bob
Liked 5,636 Times
So busted. Not an engineer. OK tie the string to the top tube and connect to the pant cuff in the top most position. When reaching the maximum downstroke it pulls the cuff up. Ta da!
Likes For rsbob:
#58
Quoted: 1109 Post(s)
Liked 1,200 Times
Originally Posted by SpeedyBlueBiker
I forgot about these! I used to have a pair to wear on each leg. Hey, it was the 70's and I had bell bottom pants. You needed one for each pant leg while cruising around on your Schwinn Varsity 10 speed. LOL!!
Likes For Camilo:
Likes For Lombard:
#61
Grupetto Bob
Liked 5,636 Times
Likes For Lombard:
#63
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,144 Times
I used to do that. Seven years ago I woke in an ambulance on the way to the ER with broken bones in my face and a partially flattened helmet, plus various other incidental injuries. I couldn't remember what happened, but much later when I got a look at my bike I saw it was in good(ish) shape but with a bent chainring. My hypothesis is that the rubber band broke and my pant leg got caught and I went over the handlebar. The pants had been cut off me and my wife threw them out so I couldn't verify it, but that's my best guess. My solution is that now I use two rubber bands so that if ever one breaks there's a backup.
#64
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
Wow! Glad you're still with us. Maybe I should use three lol. Currently using this velcro strap.
#65
There are a Lot of good ideas here. Up 'til now I've been using a very large safety pin. I pull my pant leg tight at the ankle, fold the excess over towards the back, and put in the safety pin just above the heavy sewing at the bottom of the pant leg. When not in use I keep the safety pin on the brake line under the seat. Works.
#66
Cantilever believer
Quoted: 531 Post(s)
Liked 1,828 Times
My solution is simple.
First, I figure out if the bike will be OK as a 1x or double.
Then I find the most-worn large (typically 48t+, although I've used smaller ones on occasion) chainring in the needed BCD in my Pile O' Rings, say to it in a booming voice "Your time has come", clamp it in a vise, and hacksaw off the worn-out teeth as smoothly as I can (an action which is usually very therapeutic for other life stresses). Then use a file to smooth and even out the edges.
It is then installed in the outboard position on the crank, with the other selected chainring(s) inboard. Note: the then-largest chainring must be smaller than the diameter of the sawed-off one, but these days with my relaxed riding style and readily-available 11-12 tooth small rear cogs it typically isn't an issue. If I think I must have a triple up front, I'll install it outboard of the large chainring using old-school long triple chainring bolts.
An example:
An example:
#67
Cantilever believer
Quoted: 531 Post(s)
Liked 1,828 Times
