NOS 80's Krapf Frameset
Bikes: Paletti,Pinarello Monviso,Duell Vienna,Giordana XL Super(2)Lemond Maillot Juane (2) & custom,PDG Paramount,Serotta CSI,Fuji Opus III,Davidson Impulse,Pashley Guv'nor,Evans,Fishlips,Prologue TT,Y-Foil,Softride, Tetra Pro, CAAD8 Optimo,Klein Quantum II
Quoted: 2106 Post(s)
Liked 3,207 Times
This one is NOS. No sign of anything being mounted that I can see. Paint still on BB threads, no insertion marks inside seat tube, headset shows nothing mounted, etc.
Steel is real...and comfy.
Likes For jamesdak:
Liked 3,207 Times
Plenty of room with the bare dropouts!
OFG in Exile
I have a feeling that will be a 'quick handling' bike.
I would imagine if your left lung has more air than your right, it will pull left.
Looks like fun.
What are you going to build it with?
Looks like fun.
Edumacator
Quoted: 1854 Post(s)
Liked 1,997 Times
There's certainly some similarities with the Victoire lugs but I think Losa did that signature "Y" cutout to blanks and did not modify existing Prugnat piercings.
Note they also appear on the top sockets of the headlugs and also the BB shell, plus another signature motif (tear drop) is on the chainstay sockets of the BB shell.
I think Losa made all his own frame bit piercings (or had them done to his spec).
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1980s Vanni Losa Cassani thingy, 1985 Trek 670, 1982 AD SLE, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981? Faggin, 1996ish Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe (most not finished of course), 1989 Fauxsin MTB, 1981 Ciocc Mockba...I...am...done....
Quoted: 956 Post(s)
Liked 1,538 Times
Beautiful frame @jamesdak
You may have seen this one which has a few similarities to yours which is pegged at '82: https://www.flickr.com/photos/401964...7637818644045/
Related bicycles.net.au thread here: https://www.bicycles.net.au/forums/v...30249&start=25
Liked 3,207 Times
Likes For jamesdak:
Stop reading my posts!
Quoted: 1188 Post(s)
Liked 726 Times
he blue/white example does have the same date on a (different graphics) head tube decal but is this "Schweizer Meister 82" an actual date of manufacture for either of these bikes OR does it just commemorate a championship victory in a 1982 Swiss race?
Some other details to point out re: the blue example It has "Losa touches" but some differ such as the lugs appear to have only his "teardrop" piercings, not the "Y" shape. The stay caps are a different shape to the OP's, and there's the top-tube cable routing. Otherwise it has many similarities...but no Columbus SL decal?
(I can't see any pix for any Australian example)
EDIT: Ooops I took another look and there ARE "Y" shaped piercings in at least one of the headlugs, but a teardrop in the seat lug socket.
Edumacator
Liked 1,997 Times
Liked 3,207 Times
The frameset is back from The Bike Shoppe. They did the needed facing work, installed the headset,and checked alignments. Now to get serious about the build plan. I like the silver wheels on it but these are nothing fancy with what appears to be lower end Shimano hubs and the rims have been a total pain to mount two different set's of tires. Hubs weren't too bad but I serviced them anyway. I've got two other 126mm wheelsets I could use but they are dark grey anodized rims and I'm not feeling that on this bike. It also seems stupid to go hunting for another 126mm wheelset when I have 3 spare sets on hand already. I am going to see if the beautiful silver tubular wheels on the Opus III will fit this with the tires on it. I doubt but those tires probably have less than 200 miles on them so there again, stupid to pull them off.
Little mocking up today to check fit and to see what size stem I need.
Don't mind the seatpost, just put in there quickly to get the saddle position so I could reference the proper stem size.
And a couple of shots to see how the different housing colors would look.
Red
White
Yellow
Red
White
Yellow
Edumacator
Liked 1,997 Times
I like the yellow, but the red pops.
Liked 3,207 Times
These are the Superbe hubbed arc en ciel rimmed wheels with 700 x 25 Velox tubulars glued on.
This may be the ticket!!!
But unfortunately there is something tweaked, out of alignment in the rear. When I put a wheel in with the axle all the seated in the dropouts the front of the tire is almost against the non-drive side chainstay. If I push the one side of the axle forward in the dropout a bit to center the wheel between the chainstays it's then canted off center up top. So... beyond my crude skills to figure out or fix. May be time to see if there's a frame guy somewhere in the northern Utah area that can sort this out. I know the drive-side rear dropout is pinched a bit in the opening because I can't slide the axle in, I have to go in from the side if that makes sense. Don't know if that's what's causing all the issues or not.
Liked 3,207 Times
Figured I should post this picture here too. I got the Krapf Jersey in the mail finally and it compliments the bike perfectly.
I also think I'm going to make one concession on this build with the brake levers. Probably going to use these new Tektro's vs Superbe ones to give me a cleaner look. And....my hands are getting old like the rest of me so to be honest these will most likely be more comfortable. Although......I have been looking at a set of the Suntour SL's also.
Likes For jamesdak:
Liked 3,207 Times
Got back onto this project today. Still trying to sort out the proper wheel/tire solution based on the tight rear end.
Mounted up some new Vittoria Corsa G 2.0 in 700 x 23 size today. Was a bit of challenge finding good 23c skinwall tires this time.
As expected mounting was a bear even after I warmed up the tires. These rims are a bit difficult to mount anything on and the flat, tight Corsa tires where a challange. Had to break out the VAR tire tool for these.
I also dealt with the rim tape issue on these wheels. They had those crappy rubber things on there. I didn't have the right width Velox tape but wanted to get these tires on. So for now I put down a layer of cloth first aid tape and then put the rubber liners back on. I'll order some Velox in so I can do this properly eventually.
If I have time and the right BB I may build this one up over the weekend.
Now there's a reasonable amount of room between the rear tire and the crimped seat tube.
Otherwise these tires clear quite well.
Liked 3,207 Times
Big thanks to Doug Fattic . He pointed out that the FD braze on installed on this bike was an early Shimano one made to work with the Dura Ace Ex FD's So I found a NOS on ebay and it just came in. Quick mock up shows that all should fit just fine now and clear the chain ring. I might actually get this built up this weekend now.
Of course that means I have to make a final decision on what color housing to use. I am leaning towards white today as that then allows the colors on the frame to pop more instead of taking away from them like the red or yellow would.
Likes For jamesdak:
Liked 3,207 Times
Well, I'm supposed to be doing a good cleaning of the house today but keep getting drawn back to the bike. Went ahead and properly mounted the BB and crank and then switched over the Soma Hwy One bars I'm going to use on this. Temp mounted the saddle and seatpost. I want to find a highly polished silver one for this if I can though. Last weekend I took the ball hone to the seat tube as the 27.2 seatpost were barely going in and there was something sharp scratching things up.
Seat post clamp on this is not keyed. So I had to jerry rig a bolt setup to work on this.
One quick shot before I get back to cleaning.
Don't freak, seat post height not set. Still deciding which one to use.
Likes For jamesdak:
Quoted: 956 Post(s)
Liked 1,538 Times
Likes For P!N20:
Quoted: 1818 Post(s)
Liked 632 Times
Dang I missed this thread until now. Cool frame! It screams 80s.
two things:
WHITE housing.
And, what makes the FD hanger specific to that DA fd?
two things:
WHITE housing.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,207 Times
Hi jamesdak , sorry if I missed it, did you sort out the alignment issue?
Liked 3,207 Times
"Your front derailleur braze-on looks like it might be the earliest one Shimano made. It was designed for their Dura Ace EX front derailleur. What is different about this braze-one (then more modern ones) is that the back concave shape has uneven thickness. In other words the thickness at the top of the boss is thicker than at the bottom. This shape is going to rotate the derailleur a bit counterclockwise. Or to say it another way, the derailleur cage nearest the chain stay will be even closer to the chain ring unless using an old Dura Ace EX.
I've mentioned this in old posts but different models of front derailleurs have different pivot points and so their setting heights (for the same size chain ring) can be quite different. If I remember right, your boss has quite a bit of meat so the slot can be filed higher to raise the height of the derailleur."
Likes For jamesdak:
Quoted: 567 Post(s)
Liked 874 Times
Beautiful frame, love that wheel cutout on the seat tube, don’t know how I missed this thread either, if me I’d go with the red or white cable housing, as the yellow housing doesn’t quite match the golden yellow accents on the frame. Waiting for the fully rigged pic.
Tim
Tim
I don't know.
Bikes: '90 B'stone RB-1, '92 B'stone RB-2, '89 SuperGo Access Comp, '03 Access 69er, '23 Trek 520, '14 Ritchey Road Logic, '09 Kestrel Evoke, '17 Surly Wednesday, '89 Centurion Accordo, '15 CruX, '17 Ridley X-Night
Quoted: 134 Post(s)
Liked 312 Times
such a gorgeous bike. I'm partial to silver cable housings. I wonder if they'd look good on this.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1997KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon(to be built),1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 197 Post(s)
Liked 328 Times
Seems so. That tubular setup is not a 126mm rear like I thought. So when I tightened down the QR it seemed to pull things off center. Weird because I've been using the same wheels on the 1985 Opus III with no issue at all. Had just borrowed them to mock up on the Krapf since the set of wheels I have on the Krapf now are heavy. Thinking of finding another high-end 126mm wheelset or maybe having one made.
Liked 3,207 Times
Finally got time to get back to this one. Pretty much finished for now. I've gotten about another foot of snow though over the past two days so I still don't know when I'm going to get out on any of these new rides.
This one came in at 21 lbs 9 ozs as in the snapshot here.
Wound up literally flipping a quarter to decide on the chain. Silver won, LOL!
Used red bar tape today but still wondering how white would look on it. Got a really nice looking Nitto seatpost on it now to give me the setback I needed along with the polished finish to match the stem and bars.
Likes For jamesdak:
Edumacator
Liked 1,997 Times
Is it Dura Ace RD and shifters as well (can’t see the picture well).
